#267 | |
Proud of BOXER
Drives: Subaru Boxer
lol. Good answer.
| The Following User Says Thank You to Clipdat For This Useful Post: | ML (02-23-2023) |
#268 |
So much win in this thread.
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
| The Following 2 Users Say Thank You to jflogerzi For This Useful Post: | ML (02-24-2023), RedReplicant (02-24-2023) |
#269 |
Drives: Q5 + BRZ + M796
Where is the dyno?
#270 |
Drives: 13 White MT FR-S
I’m at an endurance race so I guess he didn’t get to it yesterday. Hopefully Monday!
| The Following User Says Thank You to ML For This Useful Post: | Irace86.2.0 (02-26-2023) |
#271 |
Update: Oil pressure is too low at idle indicating an issue, so we are forgoing the dyno and pulling the oil pan to take a look at the oil pump and double check a few things.
#272 |
At the track
Drives: '14 FRS - Former e92 M3
Oh nooo
Was really looking forward to seeing the results. Hopefully nothing major
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following User Says Thank You to Kelse92 For This Useful Post: | ML (02-27-2023) |
#273 | |
race cars are stupid
| The Following 5 Users Say Thank You to ML For This Useful Post: | Jdmjunkie (02-27-2023), Kelse92 (02-28-2023), RedReplicant (02-27-2023), Takumi788 (02-27-2023), villainous_frx (02-27-2023) |
#274 |
so I got it back from the tuner after he told me he didn't feel comfortable with it. A little more clarification; the main bearning clearance is stock and the rod bearing is half a thousanth larger. The oil pressure is 24 or so cold but once to operating temp it is hitting 8psi. but at 5k rpm its around 60 psi, so am I missing about 20 psi everywhere? We are going to pull the oil pan tonight and take a look at the pump and a few other things. (huge pain cause I'm going to have to drop the subframe)
#275 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'm curious how much of a pain the subframe drop will be for you. I still need to drill my oil dipstick hole and am thinking of the easiest way to fix that without pulling everything. With that said, hope it's nothing difficult or expensive to sort out for you. |
#276 | |
I emailed kpower and they said even they had not done it before! but we have a strut bar engine holder thing to keep the engine in place on the lift, but just a couple bolts, leave the steering rack in place and maybe the control arms too is the plan
| The Following User Says Thank You to ML For This Useful Post: | captain awesome (02-28-2023) |
#277 | |
Drives: None
#279 |
So the tech that assembled the motor didnt put the oil jet plug back in. This is what I suspected, and easy enough to fix after putting it on the lift and dropping the sun frame. Only took 3 hours total. Now I have 85 psi at idle cold haha!
| The Following 8 Users Say Thank You to ML For This Useful Post: | captain awesome (03-06-2023), Code Monkey (03-01-2023), endless_pain (03-01-2023), gt5759 (03-01-2023), Irace86.2.0 (03-01-2023), Jdmjunkie (03-01-2023), NoHaveMSG (03-01-2023), RedReplicant (03-01-2023) |
#280 |
Drives: None
What a relief, I'm glad that worked out for you
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | Irace86.2.0 (03-01-2023), ML (03-01-2023) |
| Whiteout FRS | Eric_86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 08-28-2012 11:27 AM |
| MT Whiteout available now... | JohnATL | Southeast | 8 | 08-09-2012 01:12 AM |
| Another WHITEOUT in the bay.. :) | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 08-06-2012 02:13 AM |
| My new Whiteout FR-S! | Flawless22 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 07-05-2012 02:46 AM |
| My whiteout fr-s | F3dzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 07-04-2012 07:25 AM |
