Old 02-24-2023, 02:37 AM   #1
DSW
Drives: 2016 BRZ
2017 Engine in 2016 BRZ
Backstory, Bought a 2016 BRZ in Mississippi while I was stationed there on my way back home to Washington the engine blew in California. Bearings were spun etc and had to replace the engine. Ended up finding a 2017 engine for 5k with less than 20k miles from a wrecked 2017 GT86. I imagined the swap wouldn't be insanely complex, and getting the engine in the car was not the hard part. I wasn't wrong. It went to shit when the car didn't start, and figured out that it was the immobilizer. More research on here told me it was a hard swap and required more work than intended. Returning or getting a 2016 engine is not an option like some people on other threads have recommended. This is the only engine I have, and I need to make it work. I have seen very few threads on here that don't beat around the bush about what needs to happen to get this engine running and driving once again. I know quite a bit of sensor's and some plates need to be swapped over, and from what I understand need to put the 2016 ECU back in there and get it tuned to make the 2017 engine run right but keep the 2016 engine electronics such as gauge and security system so if someone could shed any light on what I need to do to get the car running and driving. What parts, a tune or flash, what electrical. I'm not worried about putting time, effort, or money into this car. I just need help understanding what exactly needs to happen as far as this engine swap goes.
Thank you for your time in advance!
DSW is offline   Reply With Quote
Old 02-24-2023, 03:42 AM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
This is a big oof. In for info.
Sent from my SM-F936U1 using Tapatalk
Joveen is offline   Reply With Quote
Old 02-24-2023, 01:19 PM   #3
Sasquachulator
Pavement Grey
This story sounds eerily familiar.......
The Following User Says Thank You to Sasquachulator For This Useful Post:
NoHaveMSG (02-24-2023)
Old 02-24-2023, 01:43 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are so many threads on this a google search would have saved you a lot of headache.
https://www.ft86club.com/forums/show...2&postcount=45
https://www.ft86club.com/forums/show...7&postcount=31
https://www.ft86club.com/forums/showthread.php?t=119729
https://www.ft86club.com/forums/show...8&postcount=12
x808drifter (02-27-2023)
Old 02-24-2023, 01:44 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Groundhog's day. Didn't we just have one of these threads recently
Old 02-25-2023, 01:14 AM   #6
macuser27
macuser27's Avatar
macuser27 is offline   Reply With Quote
Timing CELs after 2017 engine swap into 2016 mauly Issues | Warranty | Recalls / TSB 4 08-06-2020 07:54 PM
2016 rims for 2017 Ernest72 NY / NJ / CT / PA 1 08-11-2019 07:32 PM
Will the 2017 oem spoiler fit my 2016 frs? dinfern22 Cosmetic Modification (Interior/Exterior/Lighting) 6 07-24-2017 12:52 PM
2016 BRZ vs 2017 BRZ CBR600RR FR-S / BRZ vs.... 175 11-16-2016 03:47 PM
Trading in 2016 BRZ for 2017 BRZ? acethebrz BRZ First-Gen (2012+) — General Topics 27 10-13-2016 11:02 PM
