Old 02-22-2023, 03:17 PM   #1
mamamiaellis
Drives: brz
Gen 1 final drive ratio for socal tracks
Sorry if this is wrong section.
I wanted to see if there has been people running final drives on track in the socal area (willow, button, and chuck) what ratio has been beneficial overall?
Which ratio would also maximize forced induction.
Streets is where I frequent the most, and I find myself always out of revs.
Feel a bit stuck. I know driver mod is always the most effective
I don’t plan to get an fd anytime soon. But I want to extract n/a for as long as possible
mamamiaellis is offline   Reply With Quote
Old 02-22-2023, 05:01 PM   #2
CSG Mike
CSG Mike's Avatar
It'll largely be dependent on your personal pace, then modifications. You're 100% correct in that driver mod is most effective.
if you're out of revs, shift up. You can always practice strategically shifting up.
Old 02-22-2023, 05:46 PM   #3
mamamiaellis
Drives: brz
So my car is n/a on e85.
The area that are tough are
T3 (second hairpin CW) if I shift down to second gear, I feel this takes quite a bit of time and as opposed to staying in third and gas all the way around.
Same goes for the entry into the esses. I could shift to second but shift mid corner I feel unbalanced the car as opposed to just staying flat all the way to the bowl.
The left into the bowl, I am going fairly fast, I tried preemptively shifting to fourth (as I am at the rev limit of 3rd) I didn’t see much benefit here.
Last is the back straight. At the crest of the chicane I’m at rev limit on 4th. But I know I can go fast. (Being as safe as possible, I don’t want to shift there) also if I shift earlier I don’t think there would be enough torque entering the chicane.
Any tips? Sorry for the jumbled thoughts
Old 02-22-2023, 07:42 PM   #4
jflogerzi
jflogerzi's Avatar
The older models have the tallest gear set. Honestly the gains are going to be slim to know vs costs. Recommend is seat time and driver mod(coaching, video session and recording vital data)
2013 Series 10 FRS #553
Old 02-22-2023, 08:18 PM   #5
mamamiaellis
Drives: brz
Yeah I complain a lot about the gearing in my mind XD
power overall is great and a non issue. I always felt conflicted about where I was on the power band at any given moment.
I’m getting around 1:24:44 at streets . There’s more room, but the gearing has been frustrating . So I wanted to keep this option open
Old 02-23-2023, 01:36 PM   #6
jflogerzi
jflogerzi's Avatar
You could go up to a OEM 2017 rear in.
Old 02-23-2023, 04:05 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Thinking smaller tire/wheel diameter might be a way to use taller transmission gears.
Though I don't know if there are class distinctions that may grab the curlies.
Old 02-25-2023, 05:12 AM   #8
mamamiaellis
Drives: brz
Thanks for all the replies, suggestions and insights y’all
Never thought about running a smaller wheel since I was under the inpression that 17” was optimum for this chassis. But I shall look into it at least to educate myself.
17’ FD seems like a good idea.
Any insight on Oem ‘17 FD vs 4.556 (or 4.67)?
LS3 with T56 xl 2.97 - what final drive ratio? karlsson Engine, Exhaust, Transmission 0 02-14-2018 12:39 PM
Final Drive Ratio Help kbraun94 Engine, Exhaust, Transmission 33 04-17-2017 06:27 PM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 04:37 PM
About track cars' final drive ratio immo Tracking / Autocross / HPDE / Drifting 4 09-23-2014 10:04 AM
