Old 02-04-2023, 11:18 AM   #113
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by nissanfanatic View Post
It would be nice to test this on a skidpad or something where you can load the car laterally and then mess with accel/decel to try and reproduce the pressure drop.
Yes and no. A skidpad is a very specific condition and Suby boxer engines don't like them. It's a sure-fire way to blow them up if you're not careful.
In short, the outside facing head fills with oil given enough time. We see the same thing happen on long and/or banked corners like the Nurburgring's Karussel. It's banked and +180°. Competitive Subies would slow down considerably on this corner until oiling solutions were developed.
IMO, this starvation is happening because oil is sloshing into the timing cover, which is a big cavity, and roping on the chain causing a significant drop in oil level. The pan is perfectly shaped to channel oil up and forward, and the upper pan/block have more open area on the left side for oil to pool under braking right turns.
Horizontal baffles are not the solution for this type of condition, which is why some have seen no change when using them. I have a handful of prototype baffles that are to be made next week and will be testing them. Anyone who seriously tracks, has datalogging capabilities, and is brave enough to test prototype parts is more than welcome to reach out to us for upcoming beta testing opportunities.
KillerBMotorsport is offline   Reply With Quote
Old 02-07-2023, 07:33 PM   #114
DriveDriftDogfight86
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
Originally Posted by zeroomega View Post
No wonder why Japanese GR86/BRZ cup recommends oil pan baffles. But at the same time, I am wondering how much these baffles could help as some designs seems to be blocking oil return flow.
I'm not going to read all 9 pages of this, but I thought the stock GR86/22+ BRZ already comes with oil baffles from factory.
Start @ 6:34
DriveDriftDogfight86 is offline   Reply With Quote
Old 02-07-2023, 10:36 PM   #115
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Start @ 6:34
Funny, I've watched this a few times back when it came through, but I didn't recall these nuggets at all. Getting old!
But yeah, are there any full teardowns videos of the FA24D yet?
Blighty is offline   Reply With Quote
Old 02-07-2023, 11:44 PM   #116
Blighty
I forgot there was one with FTSpeed. I couldn't see both sides of the casing, didn't noticed anything special compared to an FA20 breakdown, but I dont know what this might look like.
What I did notice was the new block has a LOT more ribbing. There is almost none that I could see on the old FA20.
Old 02-08-2023, 12:14 AM   #117
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Upper oil pan has some metal shielding below the crank shaft, if that can be called as baffle. The same structure is already present in gen1 FA20.
Lower oil pan (the one people drop for RTV cleaning) doesn't have any baffle at all.
What is already present on the car to prevent oil sloshing is actually not very relevant now. They are not sufficient to prevent oil pressure drops. The pressure readings doesn't cheat, the engine does have oil pressure drop behavior at certain right turns with large lateral G. We just don't know for sure if that is severe enough to be a problem.
zeroomega is offline   Reply With Quote
Old 02-08-2023, 06:24 AM   #118
KillerBMotorsport
^ this right here.
The design changes are marginal. The guy in the vid seems to express 'significant upgrades', but the data says otherwise.
Old 02-12-2023, 02:58 PM   #119
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
Just more observations: I just watched the last three of @zeroomega's videos (since another new one popped up on youtube for me today) and on each of them, it really seems like combined gees of 1 in lateral/long on right handers (quadrant 2) is where this occurs:
Each of the significant drops starts around that area on the gee circle. It also occurs in situations where I'd think there has been enough time for oil to return to the pan, such as at 30 seconds in on this video:
It doesn't seem to be braking alone as I don't see it occur under straight line braking, but it does occur at the slightest amount of lateral accel on right handers (again, anything in quadrant 2) that exceeds 1g combined...
nissanfanatic is offline   Reply With Quote
Old 02-12-2023, 06:20 PM   #120
KillerBMotorsport
IMO, braking followed by a right-hand turn is causing sloshing into the timing cover and into the left had side of the timing cover, where there are no drains. As the car straightens out, oil can flow back into the pan through the center drain back from the timing cover.
The timing cover is a HUGE cavity and the oil pan shaped like a finnel into it, doesn't help. Additionally, you have a high-speed chain in there that will draw (rope) and hold for a period, a decent amount of oil.
This would explain why flat horizontal baffle plates (in the pan or between upper and lower pan) do little, since the upper pan holds more oil than the lower.
If this baffle that blocks the timing cover opening works well for us, it will be a simple and effective solution. We'll find out...
Old 02-14-2023, 08:41 AM   #121
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Does the timing cover need to come off to install this?
Old 02-14-2023, 09:05 AM   #122
KillerBMotorsport
No it does not. The baffle is installed with the pan removed.
AD08R tire pressure Drag Race pro_turbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-13-2021 04:04 AM
Oil pressure drops to zero after a cold start? MINOCIN Engine, Exhaust, Transmission 24 07-10-2014 02:57 PM
Darren drops his phone onto the Formula D track... DarrenDriven Northwest 2 07-22-2013 03:30 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
FRS @ willow springs (1.8 mile race track with 12 corners) scionnut Southern California 7 08-04-2012 02:29 AM
