Old 02-06-2023, 04:36 PM   #1
wheelhaus
wheelhaus's Avatar
Injector service, what else should I tackle?
Looking for a little advice/insight.
2013 BRZ with ~75k miles, with JRSC for about 1.5 years ~10k. Looking do pull all the injectors and have them sent out for service this summer now that the car is 11 years old. Wow, she's gonna be a teenager soon...
Anyways, in the name of preparedness while I've got the intake manifold off and the car down for a week or two, what else should be serviced/replaced? I've read several places from various car forums/articles the high pressure fuel lines should be replaced, they can be reused but its not recommended due to corrosion.
What else would be a good preventive measure? Forward/both 02 sensor(s)? Fuel pump? Any particular hard-to-reach vacuum or coolant lines that tend to poo the bed by 100k miles? VVT oil control valves?
Other stuff done recently- plugs, valve spring recall, and head/cam carrier gaskets (and coolant as well) were done at 60k in 2021. Last month I replaced the clutch due to a roached TOB, and checked oil pan pickup for stray silicone- there was some but it was minimal. Having the peace of mind was worth it after the valve spring recall but it appears they did a good job. The car has only ever had 91oct or better, (91 is our 93 at altitude). The only other problems I've run into have been a catch-can related vacuum leak throwing a code and replacing cyl 1 coil pack every few years.
Old 02-06-2023, 04:49 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
There shouldn't be anything worth worrying about on top of the engine really at any mileage. Your hoses and lines should be fine for at least another decade or two, if not longer with advancements made with automotive materials being used.
I redid all of my injector stuff and re-used old hard lines. There shouldn't be anything corroding your hard lines.. if there's anything on it, you can be that after a wire wheel touches it, it'll look like new. If nothing is leaking, no sense in fiddling with gaskets either if they're not already leaking. Same with your 02 sensors, just let them be.
Replace your serpentine belt, make sure not to re-use any gaskets from things you've taken off- cleaning off the gunk from within the throttle body is a great idea too. Good luck!
Old 02-06-2023, 05:58 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The whole swap the hard lines thing is an issue with different cars, haven't heard of an issue with the twins. I know the older Duramax had issues with their hardlines, they were chrome lined and it would flake off and cause issues.
Old 02-07-2023, 08:45 AM   #4
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
This is where you eyes come into play. Look everything over good. Replace anything that looks degraded or damaged.
Old 02-07-2023, 04:43 PM   #5
wheelhaus
wheelhaus's Avatar
Serpentine belt was new with the JRSC at 60k, still looks perfect. I'll definitely do IM and TB gaskets. I'm curious to see how much residue might be in there.
I saw a report showing internal pitting/corrosion as one reason, but otherwise everyone else says its due to the sealing surface deformation, same idea as reusing crush washers. One site (can't remember the vehicle) showed pretty reliable sealing after 1-2 reinstallations, but 3-4 would develop leaks at the fittings.
I'm having the injector shop install new DI seals, but I wasn't expecting this many seals to need replacement, geez. Referring to the 3 seals/o-rings on the port injectors and 6 on the direct injectors. I imagine the clips might not be necessary but sometimes they don't spring back to shape properly. If its all recommended then of course I'll do it, but sheesh. Are some of these just spacers that can be reused?
Old 02-08-2023, 11:47 AM   #6
Well now, wheelhaus, I do believe in preventative maintenance, however, I also believe in that "iffen it ain't broke, don't fix it".
Unless any of the injectors are leaking or miss-squirting, I'd leave them alone.
Old 02-08-2023, 02:32 PM   #7
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I would replace the high pressure fuel lines shop manual calls to replace them. I replaced my lines when I replaced my injectors granted I was at 170k miles when I did it. But the extra piece of mind of not worrying about having a high pressure fuel line leak was worth the $70 it cost. Just make sure to triple check everything when putting it back together, the port injectors sometimes don't seat right on the seals so they can leak. Happened to me once. Caught while running the engine after I finished putting everything back together.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 02-08-2023, 03:04 PM   #8
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Too often I use the alternative approach. Iffen bit ain’t broke I fix it til it is.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-09-2023, 03:27 AM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
That's engineer talk!
Old 02-18-2023, 03:40 PM   #10
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
PCV.
Remove and clean or just replace.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 03-21-2023, 02:49 PM   #11
wheelhaus
wheelhaus's Avatar
Definitely no external leaks, so I presume the o-rings can stay. I mean they're o-rings, you just replace o-rings right? They're over 10 years old now, but if that age is a non-issue then I'm happy to leave them be. The car is a daily, so it doesn't sit and rot. Well, maybe for some weeks during summer when its prime 2-wheel weather... Anyways, its the same reason why I replaced the rear main and trans seals when I did the clutch, technically they're not failing (yet), but I don't wanna pull the trans again down the road for something I could have addressed within 10 minutes while it was out.
Is there any other realistic way to check/diagnose flow issues/miss-squirting without pulling them for a bench service (aside from noticeably running rough/rich etc)? I figured this is a good way to ensure she's happy with boost for another 10 years.
A man after my own heart.
Originally Posted by Muskoka800 View Post
PCV.
Already on order. I've noticed some oil residue around it so its just getting replaced. I've had a few minor vacuum issues with the PCV side catch can, and the original PCV may have contributed.
Old 03-21-2023, 05:00 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
It's a 2013...
If the Intake Manifold is off, it's a GREAT time to update the wiring harness and coil packs to 2015+.
PRO86 | STL | LuckyDog
Old 03-21-2023, 07:14 PM   #13
wheelhaus
wheelhaus's Avatar
Originally Posted by rice_classic View Post
It's a 2013...
I have heard mention of the harness upgrade, but haven't done a deep dive into it yet. Repeated P0351 misfires, ultimately cyl 1 coil pack failures, have happened like clockwork every 2-2.5 years.
Old 03-21-2023, 11:36 PM   #14
Hell, I donno nuten bout fuel injected things. I fell off the pumpkin wagon when they quit putting these on engines.
Yep, life was simple, adjustments were made with two screws and if the float got stuck, ya jest rapped on the side of it with the handle of a screwdriver.
Fuel injector Service? HeadBanger CANADA 7 02-03-2016 10:52 PM
Best way to tackle the torque dip Kuri Engine, Exhaust, Transmission 37 02-27-2014 07:52 AM
