Old 02-02-2023, 01:59 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by daniloneil8 View Post
What is the door check issue?
The door does not stay open?
I would like to fix this, if possible
Please advise.
Yeah on flat ground the door will shut instead of staying open. Sucks worse in a caged track/race car to have it shut on your leg/hand when climbing over the door bars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
x808drifter (02-03-2023)
Old 02-02-2023, 02:08 PM   #16
Tokay444
Originally Posted by MCD73 View Post
I am looking at a 2014 BRZ Limited... however, it's got about 155K on it. The Clutch was done at around 106k. Thankfully, this car is a timing chain and not belt.
As far as I know, so far, everything is stock thankfully. So, my questions are...
What should I be looking for with that kind of mileage as far as long-term issues?
Is there anything that is no longer available for this car that could be a potential issue?
I learned the hard way with an 84 RX7 a few years ago, A LOT was no longer available to replace. I know this BRZ is going to be only 9 years old, but... have to ask.
Why are we thankful it's a timing chain and not a belt?
Old 02-03-2023, 09:23 AM   #17
WNDSRFR
Drives: FR-S,GTI
I guess you've never had a car with a timing belt.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
Dadhawk (02-03-2023), soundman98 (02-04-2023), x808drifter (02-03-2023)
Old 02-03-2023, 09:46 AM   #18
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Nor one with an interference engine.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
Old 02-03-2023, 09:56 AM   #19
WNDSRFR
Drives: FR-S,GTI
With a timing belt.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 02-03-2023, 09:56 AM   #20
Tokay444
Many, in fact.
Question stands.
Old 02-03-2023, 09:58 AM   #21
WNDSRFR
Drives: FR-S,GTI
I've had one break on a GTI. Bent 18 valves. Had to replace the head.
Had one break on a CRX Si. No damage. Just replaced the belt.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
norcalpb (02-03-2023), soundman98 (02-04-2023)
Old 02-03-2023, 10:00 AM   #22
WNDSRFR
Drives: FR-S,GTI
And chains are much harder to break than a rubber band.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
Dadhawk (02-03-2023), soundman98 (02-04-2023), Teseo (02-05-2023), x808drifter (02-03-2023)
Old 02-03-2023, 10:07 AM   #23
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by Tokay444 View Post
Many, in fact.
Question stands.
My first car was a 3rd Gen Eclipse. 2000 car. Happened in 05.
The belt snapped on the freeway one night.
11 vales bent. 1 piston damaged enough to need replacement.
Old 02-03-2023, 10:14 AM   #24
Tokay444
Blanket statement is blanket.
The ONLY timing system I ever had break was a chain.
Chains are not impervious to stretchy and breakage. They have a life expectancy and many can't even make it that long.
Old 02-03-2023, 10:19 AM   #25
Tokay444
And? Would the damage have been less if it was a chain that broke?
Old 02-03-2023, 11:02 AM   #26
WNDSRFR
Drives: FR-S,GTI
How the hell did you do that?
What kind of car was it?
I've had chain tensioners wear but how do you break a timing chain? Massive boost with no oil?
Old 02-03-2023, 01:04 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's just the classic "I had this experience so it is so" argument. Anecdotal, nothing more.
I've dealt with hundreds of engines, belt and chain. In general I find chains to be far more reliable. There are systems out there that have issues, looking at you 22re, but for the most part a chain is more durable. The issue with the chain is it and it's components are not easily serviceable and more likely to be neglected, though for the most part they are considered lifetime parts and don't even have called out service intervals in many engines I have come across. They do typically have wear limits that are specified. My opinion, also anecdotal, so take it for what it's worth.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (02-04-2023), Ultramaroon (02-03-2023)
Old 02-03-2023, 01:19 PM   #28
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Civic S - Water pump froze up and broke the timing belt that was driving it. Bent valves.
Typically, an automotive timing chain is running in the engine interior oil bath.
That's a very benign environment for them as long as you change the oil.
Bicycle and motorcycle drive chains are usually out in the dust and grit that requires they be replaced periodically.
There have been timing chain recalls for BMW, Audi, Nissan, Chevy and MINI.
Most of those have been due to cost cutting and under specification in design.
The Following 3 Users Say Thank You to bcj For This Useful Post:
NoHaveMSG (02-03-2023), soundman98 (02-04-2023), Ultramaroon (02-03-2023)
Advice on replacing oxidized parts Llilith BRZ First-Gen (2012+) — General Topics 8 11-02-2022 11:15 AM
NO LONGER AVAILABLE kinghurl Cars for Sale/Trade 3 11-22-2021 12:05 AM
Need new rotors - advice on correct parts stayclam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-22-2019 01:54 PM
no longer available AllOutApex Australia Classifieds 0 01-20-2016 09:08 PM
No longer available funx Canada Classifieds 3 10-29-2013 10:10 AM
