Northern California NorCal
Old 12-26-2022, 05:39 PM   #11635
KEVdaGR8
Drives: Toyota 86 2020 AT
SOLD
Originally Posted by KEVdaGR8 View Post
Hi everyone!
I have a used mxp comp rs for sale because I want to try a different catback. I had it on for about a year. It is a good catback exhaust that's on the loud side, but it's not too loud, you can't really hear it sitting in another car. But pedestrians will be able to hear you coming. It has drone, but I got use to it after a few days.
Some notes:
1. It has some scratches on the tips.
2. I overtightened the exhaust clamp in the mid pipe so I used a clamp from o'reillys. It works great, I think it's better than the clamp that came with the exhaust. However, I also tightened that pretty tight so now the mid pipe is one piece cause the two pieces are stuck together. (it use to be two and they were slip joint connections) Theres no leaks, it's just that the two pipes are stuck together
I prefer local, SF/Bay Area.
Price:
$300 or best offer!
SOLD
KEVdaGR8 is offline   Reply With Quote
Old 12-27-2022, 01:12 AM   #11636
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by EAGLE5 View Post
Free: one stock alternator
FS: 949 steering wheel spacer. $200
FS: Carbotech race pads. XP10 front. XP8 rear. Brand new and unused. If you need more pad than this, you should probably have a BBK. $400
All in Castro Valley.
Do you still have the alternator?
Old 01-06-2023, 08:22 PM   #11637
sftateofmind
Evening Primrose
sftateofmind's Avatar
I'm looking to buy a drivers side BRZ seat that will fit a 2013. Heated alcantara preferred.
Also have some stock wheels from a 2013 I'm willing to let go for peanuts
sftateofmind is offline   Reply With Quote
Old 01-08-2023, 05:55 AM   #11638
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Alternator is gone. Steering wheel spacer has dissapeared into the black hole of my garage but will eventually be found.
FS: Carbotech race pads. XP10 front. XP8 rear. Brand new and unused. If you need more pad than this, you should probably have a BBK, and then you'll still have to buy pads for it. $380
Old 01-16-2023, 02:12 AM   #11639
jetvermillion
Drives: '22 BRZ Limited MT
FS: Raceseng Ashiko Big Bore
Asking $100 (original $150)
Looking for local sale only (San Francisco, can meet up within ~25 mile radius).
This ONLY fits the 2nd gen
Link to product:
https://raceseng.com/products/ashiko...39777546764390
Used it for barely a month. While I very much liked the improved shift feel with a heavier knob, it's just a tad too big to my liking by about 10%. Other than that I really liked the look. It feels very high quality.
I did not bother to remove the adapter from the shift knob to avoid potentially damaging or scuffing it. I initially adjusted it to have the pattern line up perfectly, but over time it needed to be retightened so now it is off by about 5 degrees. You can either remove the adapter with threadlock (apply threadlock onto your shifter arm), or just use the extra nut I'm including to help line up the shift pattern (I purchased the nut myself - it didn't come with the shifter)
jetvermillion is offline   Reply With Quote
Old 01-16-2023, 09:54 PM   #11640
norcalpb
norcalpb's Avatar
TRD front sway bar (21mm) - Sold
Comes with OEM TRD bushings (rubber) and AVO bushings (poly)
Old 01-17-2023, 12:36 AM   #11641
macuser27
macuser27's Avatar
Originally Posted by macuser27 View Post
FS: Nameless Dual Exit Axleback 2.5-inch inlet 5-inch mufflers $300 (vs. $800 new).
Bump. $300 OBO.
macuser27 is offline   Reply With Quote
Old 01-26-2023, 12:46 PM   #11642
derekguy123
Fellow BRZer
derekguy123's Avatar
ISO 30mm wheel spacers
Hi everybody, are any of you willing to part ways with a pair of 30mm wheel spacers? I've been searching for some for a while now. Please let me know! Thank you.
derekguy123 is offline   Reply With Quote
Old 01-28-2023, 01:02 PM   #11643
jdmwol2ks
Drives: 22' Model
2022 BRZ 18” Limited wheels
Selling a set of 2022 18” BRZ limited wheels. Comes with Michelin PS4 tires and tpms. Great upgrade for premium or gr86 base cars. Overall have about 6k miles of use and 2 wheels have a small 1in Knick which also hit the tire a bit too. They all hold air, no issues. Looking for $900 picked up in the east bay. Text me for pictures or if interested 510-224-5855
jdmwol2ks is offline   Reply With Quote
Old 01-29-2023, 08:52 PM   #11644
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Located in 94402
Buddy Club FRS coilovers
Asking $750
Enkei Raijin 18x9.5+45 5x100 with 235/40/18 Lionheart tires
Asking $1100
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 01-31-2023, 02:33 AM   #11645
macuser27
macuser27's Avatar
Did the steering wheel spacer reappear?
Old 01-31-2023, 01:42 PM   #11646
EAGLE5
Dismember
EAGLE5's Avatar
No, and I'm annoyed by this. I do have an oil cooler, though.
Old 02-01-2023, 11:57 PM   #11647
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Clear or red lens?
Red Lens!
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 02-06-2023, 09:23 PM   #11648
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Located in Santa Rosa:
FS: 2013 Manual Transmission
https://www.ft86club.com/forums/show...87#post3567487
FS: Exedy Stage 1 Clutch Kit
https://www.ft86club.com/forums/show...89#post3567489
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Clipdat (02-06-2023)
NW Marketplace v1.0 (CLOSED) DarrenDriven Northwest 2872 08-14-2015 02:48 PM
MCM FR-S now in NorCal!!! microcarmag Southern California 6 07-01-2012 06:01 PM
2nd BRZ in NorCal? Chauntalei BRZ First-Gen (2012+) — General Topics 15 05-29-2012 09:44 AM
Marketplace GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 3 02-08-2012 03:26 PM
