| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
noautoBRZ
Drives: 2013 Subaru BRZ Limited MT
2017 MT FA20 engine swap into 13 BRZ
Just picked up a 24k ODO 2017 engine out of a totaled BRZ. Reason being is I threw a rod in my 13 FA20 a few weekends ago and settled with swapping after I got a great deal on this engine.
I've read a few threads on here from years ago saying the 2017 engine wont swap to the 2013 because of harness compatibility. I would just like to know how true this is. I have a buddy with a 2017 FA20 in his 13 BRZ and claims its plug and play but a shop did it for him and I'm choosing to do the swap myself. Any info/tips would be great.
#2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Read through this. Its not as simple as a harness swap
https://www.ft86club.com/forums/showthread.php?t=119729 |
| The Following 4 Users Say Thank You to finch1750 For This Useful Post: | NoHaveMSG (01-29-2023), soundman98 (01-29-2023), villainous_frx (01-28-2023), x808drifter (01-29-2023) |
#3 |
ProCrastinationConsultant
not impossible, but a lot of small pain in the butt changes. the block is stronger though.
#4 | |
noautoBRZ
#5 |
Drives: Crapcan
You didn't read the thread he linked it all, did you?
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#6 | |
Pavement Grey
With that said...no one seems to know whether or not doing a complete transplant (17+ motor and 17+ ECU and harnesses) if that would just completely bypass all the trouble getting a 17+ motor to work in a 13-16 car. |
#7 |
LMGTFY
Drives: 13 FRS, 91 Miata
OP asks for info/tips.
Tells us were wrong when we try to help. |
#8 | |
#9 |
#10 | ||
Drives: Crapcan
https://www.ft86club.com/forums/show...2&postcount=45 Quote:
https://www.ft86club.com/forums/show...7&postcount=31
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | finch1750 (01-30-2023), soundman98 (01-30-2023) |
#11 |
Drives: Crapcan
I think the easiest way to do this swap is to run the CPS out of the older car and use a degree wheel to index the old reluctor to the new engine and run that, or have a new one built. That is what solidsnake did to run his K24 on the stock BRZ ecu.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (01-30-2023) |
#12 | |
| The Following User Says Thank You to macuser27 For This Useful Post: | NoHaveMSG (01-31-2023) |
#13 | |
Drives: Crapcan
My guess is reindexed 13'.Edit: and it may not need reindexed or anything, I am pretty sure crankshafts are the same
#14 |
Pavement Grey
Is it safe to say dropping a 17+ motor into a 13-16 car is basically a poor man's engine swap?
Seems like the amount of trouble to get it to work is almost the same, except you don't have to do any custom fabrication to get it to fit. |
| 2017 fa20 engine into 2013 car? | ROADRACER | Engine, Exhaust, Transmission | 91 | 12-28-2021 11:52 PM |
| Performing FA20 swap with new FA20 | Ctoner2653 | Engine Swaps | 8 | 09-24-2021 08:40 AM |
| Timing CELs after 2017 engine swap into 2016 | mauly | Issues | Warranty | Recalls / TSB | 4 | 08-06-2020 06:54 PM |
| Blown 2016 FA20 swap 2017 FA20 | HRLQN | Engine Swaps | 11 | 10-15-2019 07:17 AM |
| 4UGSE/FA20 engine or swap? | jordydiaz | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-04-2012 06:00 PM |
