Old 01-28-2023, 09:05 PM   #1
noautobrz
noautoBRZ
Drives: 2013 Subaru BRZ Limited MT
2017 MT FA20 engine swap into 13 BRZ
Just picked up a 24k ODO 2017 engine out of a totaled BRZ. Reason being is I threw a rod in my 13 FA20 a few weekends ago and settled with swapping after I got a great deal on this engine.
I've read a few threads on here from years ago saying the 2017 engine wont swap to the 2013 because of harness compatibility. I would just like to know how true this is. I have a buddy with a 2017 FA20 in his 13 BRZ and claims its plug and play but a shop did it for him and I'm choosing to do the swap myself.
Any info/tips would be great.
noautobrz is offline   Reply With Quote
Old 01-28-2023, 09:54 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Read through this. Its not as simple as a harness swap
https://www.ft86club.com/forums/showthread.php?t=119729
Old 01-29-2023, 09:56 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
not impossible, but a lot of small pain in the butt changes. the block is stronger though.
Old 01-29-2023, 04:44 PM   #4
noautobrz
noautoBRZ
You dont have to swap the harness at all. Its should be plug and play at least thats what i was told from a buddy who has a 17 engine in his 13. The only thing im unsure about is if he used the 13 ECU or the 17 ECU.
Old 01-29-2023, 09:15 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You didn't read the thread he linked it all, did you?
Old 01-30-2023, 01:30 AM   #6
Sasquachulator
Pavement Grey
sounds like a complete pain in the ass vs just getting a working engine that matches the year.
With that said...no one seems to know whether or not doing a complete transplant (17+ motor and 17+ ECU and harnesses) if that would just completely bypass all the trouble getting a 17+ motor to work in a 13-16 car.
Old 01-30-2023, 03:04 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
OP asks for info/tips.
Tells us were wrong when we try to help.
Old 01-30-2023, 04:04 AM   #8
finch1750
finch1750's Avatar
Pretty much. I file it in the more trouble than it's worth until junkyards run out of zenki engines. Then itll be time to buy a salvaged kouki and see what happens lol
Old 01-30-2023, 07:21 AM   #9
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
It cost money to learn, I see an education coming for OP.
Old 01-30-2023, 10:50 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have to bypass the immobilizer from what I have read. From what I understand from steve99's post, the ECU isn't actually different hardware wise, but the ROM's are not compatible with the older cars immobilizer.
https://www.ft86club.com/forums/show...2&postcount=45
This car fired up for the first time TODAY "properly", however I am still convinced it isn't possible now, without the bulkhead harness too. After swapping back, and having to purchase a bunch of new 2017 parts(the old ones were not provided back to the customer, minus the ECU, which we obvisously had to bypass the immobilizer in)
From this post.
https://www.ft86club.com/forums/show...7&postcount=31
Old 01-30-2023, 11:15 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think the easiest way to do this swap is to run the CPS out of the older car and use a degree wheel to index the old reluctor to the new engine and run that, or have a new one built. That is what solidsnake did to run his K24 on the stock BRZ ecu.
Old 01-31-2023, 01:45 AM   #12
macuser27
macuser27's Avatar
I have a 2013 BRZ with a 2019 engine in it. The engine was installed by the previous owner. It has 2013 wiring harness, coil packs, ECU, and sensors.
macuser27 is offline   Reply With Quote
Old 01-31-2023, 09:49 AM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am dying to know what the reluctor wheel looks like My guess is reindexed 13'.
Edit: and it may not need reindexed or anything, I am pretty sure crankshafts are the same
Old 01-31-2023, 10:36 AM   #14
Sasquachulator
Pavement Grey
Is it safe to say dropping a 17+ motor into a 13-16 car is basically a poor man's engine swap?
Seems like the amount of trouble to get it to work is almost the same, except you don't have to do any custom fabrication to get it to fit.
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-28-2021 11:52 PM
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 08:40 AM
Timing CELs after 2017 engine swap into 2016 mauly Issues | Warranty | Recalls / TSB 4 08-06-2020 06:54 PM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 07:17 AM
4UGSE/FA20 engine or swap? jordydiaz Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2012 06:00 PM
