Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-25-2023, 03:34 PM   #1
CSG Mike
CSG Mike's Avatar
Remote Tuning with Ecutek is now available for the 22+ BRZ
https://www.instagram.com/p/CnzmskGM4RF/
Old 01-25-2023, 04:47 PM   #2
Code Monkey
Drives: Subaru BRZ
Any dyno graphs as to what kind of gains can be expected from level 1 tune vs level 2? Why does level 3 require upgraded internals?
Code Monkey is offline   Reply With Quote
Old 01-25-2023, 05:19 PM   #3
Lantanafrs2
Drives: 2013 frs red
Forced induction?
Lantanafrs2 is offline   Reply With Quote
Old 01-25-2023, 06:21 PM   #4
Code Monkey
Drives: Subaru BRZ
Nope, says "level 3 naturally aspirated."
Old 01-25-2023, 07:09 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The different levels is based on the complexity of the service. Level 3 is categorized for vehicles with modified/non-OEM internals. It's not LEVEL 3 UNLIMITED POWERRRZZZ like Gran Turismo upgrades.
CounterSpace Garage is offline   Reply With Quote
Old 01-25-2023, 09:18 PM   #6
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Lantanafrs2 View Post
Forced induction?
That's separate from the NA tuning.
Just go to their site and read through all the options. It has the info you desire.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 01-27-2023, 07:14 PM   #7
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
2000$=20hp on 93 pump another 5hp with e85. That’s header catback intake tune. Is my guess… Pretty steep might as well wait for forced induction
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 01-28-2023, 09:19 AM   #8
PulsarBeeerz
Drives: JRSC BRZ SOLD
Eh, not so fast. lol FI gets even steeper. The catback and FF kit can be used with a NA or FI setup so there is zero savings. A different tuning company got 215whp stock, 232whp on 91 with the boltons you mentioned and finally 245whp on E60. You could omit the $800-1100 header and sub in around $8k+ in the form of an FI kit, clutch, oil cooler, injectors to run FF, and tuning/SW. Hopefully the new transmission is stronger because this engine is already doing 320whp on 9psi and pump gas.
PulsarBeeerz is offline   Reply With Quote
Old 01-28-2023, 11:11 AM   #9
vindiesel
vindiesel's Avatar
Depends on how much power you want you might be able to get away with stock clutch on low boost… but I get your point. 15hp (people that don’t care to change fuel type) gets you what in a 2800lb pound car? .2-3sec faster 0-60 maybe a more linear power band? I most be getting too old. I think of someone tunes one and does a 0-60 and 1/4 Mile time comparison vs stock would drum up more excitement.
Old 02-01-2023, 09:24 AM   #10
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Might. With forced induction, a lot is a MIGHT. That's far more steep than the 2k you can pay for an extra 20 ponies on a light weight car and keep it as reliable as it was stock for its lifetime. 0.2-0.3 on 0-60 and quarter mile is a pretty huge difference. Combine that with the light weight, at the minimum, I am sure the power feels plenty better. It did on the first gen for most.
Dzmitry is offline   Reply With Quote
Old 02-01-2023, 05:46 PM   #11
vindiesel
vindiesel's Avatar
I’m sure some yahoo will do all bolt on mods, e85 with an aggressive tune make 250hp to the wheels and 190ftlbs of torque, gut the interior, steeper rear end gears and run a 13.0 second 1/4 mile flat.
Old 02-04-2023, 12:16 PM   #12
eyeballs
Drives: '22 BRZ
So currently I've got a j-spacer in front of my downstream O2 sensor for CEL purposes. Can anyone confirm that the ecutek tunes for this gen will eliminate the CEL if I pull the spacer? My car is down due to a tire issue so I figure I might as well pull the spacer now(which I think means taking the header back out unfortunately, super low clearance with that spacer) as I've a tune kit coming in the mail.
eyeballs is offline   Reply With Quote
Old 02-05-2023, 12:19 AM   #13
eyeballs
Drives: '22 BRZ
Found out that the tuning can indeed eliminate the CEL, but leaving it in is fine too.
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Remote Tuning with Ecutek is now available CSG Mike GR86 General Topics (2nd Gen 2022+ Toyota 86) 0 01-25-2023 03:34 PM
Dyno Tuning vs Remote Tuning JR23 Software Tuning 4 12-10-2021 08:19 AM
In-Person vs Remote Dyno Tuning Mike_ZN6 Engine, Exhaust, Transmission 7 06-24-2021 02:26 PM
