Old 01-20-2021, 08:34 AM   #29
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I know you guys have done a lot of swaps but are you 100% the harnesses are the same? I was missing at least one connector on the MT harness for the AT it looked like, unless the one I got was hacked. Plus the MT to AT transmission DIY claimed they were different.
Yes, 2013 - 2015 MT & AT cars use the same engine harness. The bulkhead harness is different, but the actual engine harness is the same.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
finch1750 (01-20-2021)
Old 06-06-2021, 05:28 PM   #30
mdavis
Drives: fr-s
On this same topic I just had to put in a junkyard engine into my manual FRS. There is one open coolant inlet/outlet on the back top of the block which I'm pretty sure wasn't on my old motor. Discovered it when adding coolant and water started pouring out. Is this a water line for the automatic transmission cooler?
The weird thing is that the car runs fine and there is a block off plate on the passenger side cylinder head. Maybe someone already did this swap?
Can I just cap off this inlet/outlet if it is indeed for the automatic transmission?
mdavis is offline   Reply With Quote
Old 06-07-2021, 10:28 AM   #31
mdavis
Drives: fr-s
Should've read this thread more carefully as it is explained in post #26. Looks like someone put an auto coolant crossover pipe on this engine for some reason. I'm just going to cap it off for now.
The Following User Says Thank You to mdavis For This Useful Post:
Ultramaroon (06-08-2021)
Old 02-23-2022, 01:49 AM   #32
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Hey,
So did you use the same engine harness? PnP? Are the engine harnesses same for both MT & AT throughout the years?
I need to replace my engine harness for 2013 AT GT86
I_amhassan is offline   Reply With Quote
Old 02-23-2022, 10:25 PM   #33
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by I_amhassan View Post
Hey,
Yes, engine harness is the same
Old 01-16-2023, 10:13 PM   #34
fancymalard
fancymalard's Avatar
Drives: 2013 Scion FRS
Anyone have any idea how to remove the dowel pins off the vacuum pump location?
fancymalard is offline   Reply With Quote
Old 04-17-2023, 03:56 PM   #35
Opie
Opie's Avatar
Vice Grips
Old 04-18-2023, 12:03 AM   #36
fancymalard
Originally Posted by Opie View Post
Vice Grips
Indeed vice grips and wd40 worked pretty good.
The Following User Says Thank You to fancymalard For This Useful Post:
Opie (04-18-2023)
Old 06-21-2023, 07:21 AM   #37
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Just went through this recently with my own swap. Although everything was described in words, it would have been much more helpful to have a visual comparison to identify all the parts. So I took some time to record it all in pictures.
Also few things I did differently compared to methods folks have mentioned/tried previously:
  1. AT Vacuum Pump Dowel Pins: Knocked them from the front, out the back
    • I didn't have a lot of luck with vice grips on the dowel pins. I mangled the top one trying to get it going. Eventually had to knock the top one out from the back, which wasn't perfect because I was lazy to remove parts for hammer clearance. There is probably enough clearance to knock the pin clear out the back. This is what I did for the bottom one. Much more consistent and clean.
    • Name:  IMG_20230612_220816.jpg
  2. AT Coolant Crossover Pipe: Used MT Cover with Coolant RTV
    • The metal coolant crossover pipe is physically different between the MT and AT. The MT has a machined o-ring groove and flat cover plate. The AT is just flat (with no groove) and seals against the AT thermostat. I didn't want to go through the trouble of swapping the entire pipe and didn't like the idea of capping and bleeding a thermostat.
    • I ended up using some Coolant RTV (Threebond 1282B) to seal the MT cover plate against the AT coolant pipe. The shadow of the o-ring/coolant against the MT cover plate made a perfect template to lay the bead, and I verified that the sealing location and surface matched using the AT plate. Used the short bolts from the MT configuration. Finally, used a magnet to help guide the plate on and align properly. (See below picture)
    • Name:  IMG_20230621_040623.jpg
    • Name:  20230608_180115.jpg
    • Name:  20230608_180351.jpg
  3. AT Vacuum Pump Oil Line Cap: Bought a new plug and gasket
    • I didn't transfer the MT oil galley plug and gasket near the DI ECU. I elected to just buy a new one from Toyota ($3 total: SU003-02193 & SU003-02155)
    • You only need one plug for the actual galley on the top of the engine. The port on the back is just left open to the elements in the MT. I just wanted to plug mine to keep it clean
The rest of the below images are the side-by-side of the parts you should expect to interact with during the configuration change:
  • Coolant tubes/hoses: Heater Core Line (MT) vs Heater Core Line & AT Cooler Line (AT)
  • Coolant Cross-over Pipe Connection: Pipe Block-off Plate & O-Ring (MT) vs Thermostat, Thermostat Housing, & AT Cooler Line (AT)
  • Brake Booster Vacuum Supply: Cam Cover Plate & Intake Manifold Hose (MT) vs Vacuum Pump, Vacuum Pump Hose, & Intake Manifold Plug (AT)
  • Vacuum Pump/Oil Galley Supporting Parts: Plug (MT) vs Banjo Bolts & Oil Supply Tube (AT)
EndlessAzure is offline   Reply With Quote
The Following 5 Users Say Thank You to EndlessAzure For This Useful Post:
Breadman (06-21-2023), DocWalt (06-21-2023), new2subaru (06-21-2023), NoHaveMSG (06-21-2023), Ultramaroon (06-21-2023)
Old 06-21-2023, 02:44 PM   #38
Oooo.... you sprang for the GOOD stuff.
Old 06-21-2023, 11:35 PM   #39
EndlessAzure
Wheels for Brains
If you gonna go shmoo, use the good goo.
ThreeBond 1207B also technically works (the RTV specified for Toyota oil pans), as Threebond says it's coolant compatible. I believe TB1207B is what Aisin calls for for their water pump installations. However from what I read, cured TB1207B is much harder to scrape-up/clean-off from parts if something goes wrong.
It's worth nothing: absolutely do not use ThreeBond 1217G/H (the RTV specified for Subaru engine block and oil pans), as it is not compatible with coolant.
The Following User Says Thank You to EndlessAzure For This Useful Post:
Ultramaroon (06-22-2023)
BRZ Manual Or Auto? JT2Swag Scion FR-S / Toyota 86 GT86 General Forum 45 06-29-2016 03:05 PM
2015 Engine differences nikitopo Engine, Exhaust, Transmission 112 02-15-2016 06:27 PM
Engine from Auto car into a manual car? John Rambo Engine, Exhaust, Transmission 8 11-26-2015 04:54 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
FR-S vs. BRZ Differences - Engine/Model Codes Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 5 05-07-2012 02:26 PM
