Old 01-10-2023, 05:40 PM   #57
Jynx
Drives: 2013 Subaru BRZ
Originally Posted by RZNT4R View Post
Clear them.
U0122 sometimes trips when a scantool hops on the network, P0700 is the transmission going "wtf dude there's a U0122!"
Mine doesn't do p0700 because it's manual, but half the time I connect a scan tool to mine it'll pop the U0122, even a dealership techstream made it pop. Clear and ignore.
i would say your right but when they test drive it, these codes immediately kick out so clearing it doesn't exactly work :/
Jynx is offline   Reply With Quote
Old 01-10-2023, 07:08 PM   #58
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Oh well of course, if they aren't a vestige of someone hooking up a scan tool and they come back then yes, a proper diag is in order
Old 02-07-2023, 08:24 PM   #59
Jynx
finale update. FIXED. FINALLY. a year and half later it is gone and car feels great other than some vibration in the steering wheel.
Old 02-07-2023, 08:57 PM   #60
And it was...?
Old 02-08-2023, 07:12 AM   #61
Jynx
And it was...?
so the cable going to the Purge Valve under the intake was shot. The Purge Canister above the rear diff was blowing pressure out the electrical plug so that was bad. After all that was replaced. we are good to go. the other two codes it threw was because the car battery died in idle while they were trying to fix the evap. the voltage just got too low.
The Following 4 Users Say Thank You to Jynx For This Useful Post:
blsfrs (02-12-2023), Tcoat (02-08-2023), Ultramaroon (02-08-2023), x808drifter (02-09-2023)
Help diagnosing P0441 code 1Saucyyy_brz Issues | Warranty | Recalls / TSB 3 09-18-2022 06:45 PM
Engine code p0171 and p0441 frscory Issues | Warranty | Recalls / TSB 6 02-20-2022 07:06 PM
Having trouble with code p0441 Jynx Issues | Warranty | Recalls / TSB 5 02-19-2022 06:17 PM
p0441 cel code bryan.catano93 Engine, Exhaust, Transmission 5 03-12-2018 12:38 PM
Check engine code P0441 Gibson Engine, Exhaust, Transmission 0 11-23-2016 06:39 PM
