Old 12-14-2022, 12:14 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Ragged on start up
2014 FR-S, Stage 2 OFT, E85 fuel, ESC. Fuel usually tests right at 85%. This setup has been fine for 10,000 miles or so, but lately started stumbling and quits on the first cold start attempt. Always starts on the second push but runs ragged for the first couple seconds then OK. No other problems evident. I was planning to change the plugs until reading some comments about 100K or more on plugs. Right at 60K now and I'm suspecting maybe spark plugs or fuel filter. ???
Qwimby1 is offline   Reply With Quote
Old 12-14-2022, 07:09 PM   #2
Grady
Grady's Avatar
Fuel filters cause issues at WOT. OFT is not know for its E85 cold start abilities. The ones reporting 100k on plugs are stock. When you up the power you wear the plugs faster. That is a good place to start. A log of the start may help some.
The Following 3 Users Say Thank You to Grady For This Useful Post:
humfrz (12-15-2022), Qwimby1 (12-15-2022), x808drifter (12-16-2022)
Old 12-15-2022, 10:04 AM   #3
Qwimby1
Excellent points. Thanks.
Old 01-08-2023, 12:52 PM   #4
Qwimby1
Switched from E85 to 93 just to test. Starts right away and smoothly now.
The Following User Says Thank You to Qwimby1 For This Useful Post:
whataboutbob (01-08-2023)
Old 01-08-2023, 01:11 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Has it been a little colder in Florida?
x808drifter (01-09-2023)
Old 01-08-2023, 03:40 PM   #6
Qwimby1
Yeah, it has.
Old 01-08-2023, 03:49 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yeah, it has.
I have a flex fuel kit. When I lived in Nor Cal and ran E85 I always got fuel at 87-85%. Even in Cal, in winter, it would start harder. I would put a bit of premium with the E85 to lower % a bit and it would solve the problem.
Old 01-10-2023, 11:19 AM   #8
Qwimby1
When I say cold in Florida its all relative. We had a couple of 40 degree nights and then back to 70. It didn't change the starting situation. Now running 93 and it starts normally. I hadn't checked for a while, but what I was getting ran right at 85%.
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 10:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
