| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#1093 |
#1094 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
This is what you said. "Yet the J02 recall was done entirely voluntarily after very, very, few failures and it is the same manufacturer that we are currently talking about" Seemed like your are comparing the issues, so I dug into it. Pretty simple bud. |
#1095 |
Drives: '23 BRZ Limited
So just for fun I sent my dealer an email regarding pulling the pan for the first oil change, the mention of "oil pan seals" is very interesting. As well as needing to pull the engine to replace the strainer vs just cleaning it out.
"The oil change interval for the complimentary maintenance is scheduled at either 6 months or 6,000 miles (whichever comes first). I am showing that this should be due on March 03, 2023 if that is the case. Also, we would be more than happy to remove the oil pan during the oil change. But there are some issues I would like you to be aware of: The first issue is that the oil pan seals are not currently available. We looked up the part numbers and they show Backorder with no E.T.A. as of today. I would definitely avoid pulling the pan off until those seals were in stock and readily available. The second issue would be that it is not something that Subaru would cover under warranty unless there was a specific failure. If we were to remove the oil pan and found nothing wrong, they would not pay for the labor or parts needed for this. The cost would be $734.00 to do this. If we did pull it off and found something wrong or any excess RTV inside, then it would become a warranty issue and it would be covered entirely. My shop foreman informed me that if it were the case, we would need to actually remove the entire engine out of the vehicle to replace the strainer and the other items needed for this. In that case, I would just advise you to be prepared for the vehicle to be down for several days."
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | Ash_89 (01-05-2023), formulaBRZ (01-06-2023) |
#1096 |
~4,500 miles and it's pretty clean...
#1097 |
That's good to see. I just thought it was interesting they said "oil pan seals" are on backorder........when it uses RTV to seal.
#1098 |
Drives: 2022 GR86
I would not risk having them pull the pan and re-seal it if that's what they know about these engines.
Follow the build thread for my GR86!
| The Following 11 Users Say Thank You to timurrrr For This Useful Post: | DarkSunrise (01-05-2023), DocWalt (01-05-2023), DylanJZA (01-05-2023), formulaBRZ (01-06-2023), justinco (01-05-2023), KillerBMotorsport (01-05-2023), NoHaveMSG (01-04-2023), Ohio Enthusiast (01-04-2023), Pat (01-04-2023), soundman98 (01-04-2023), Teseo (01-04-2023) |
#1099 |
Drives: 22 BRZ limited
#1100 | |
But pulling the engine out instead of just cleaning out the pickup was the bizarre thing to me.
#1101 | ||
I could see an inexperienced service advisor mentioning seals, and just not know there are no traditional seals, but going a step further in stock and delivery of said seal, is just odd. |
#1102 |
Is there a reason this can't be expected with a scope through the oil drain, or am I missing something completely obvious? (I haven't looked at this at all, it just occurred to me).
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1103 |
There are baffle plates in the way.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-05-2023) |
#1104 |
Drives: 2020 GMC Canyon Denali Diesel
There are 2 rubber o-ring seals on the oil pan that are also supposed to be replaced each time the pan is removed, this is likely what they were referring to. Interesting to see that some on this forum don't know this but are pulling pans....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following 12 Users Say Thank You to Opie For This Useful Post: | DarkSunrise (01-05-2023), dawsonj87 (01-05-2023), DocWalt (01-05-2023), DylanJZA (01-05-2023), mn_ca (01-05-2023), NoHaveMSG (01-05-2023), OkieSnuffBox (01-05-2023), Pat (01-05-2023), Rustyoid (01-05-2023), soundman98 (01-05-2023), Tcoat (01-05-2023), Tokay444 (01-06-2023) |
#1105 | |
Drives: '22 BRZ
and those parts were out of stock, didn't bother checking to see if they're in stock just now. That said, I see no reason they can't be reused, they weren't deformed or smashed on my car.
#1106 | |
Pavement Grey
You usually never supposed to reuse a gasket? |
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
