Old 12-27-2022, 02:28 PM   #1
MCD73
Drives: 2014 BRZ Limited
Parts no longer available advice
I am looking at a 2014 BRZ Limited... however, it's got about 155K on it. The Clutch was done at around 106k. Thankfully, this car is a timing chain and not belt.
As far as I know, so far, everything is stock thankfully. So, my questions are...
What should I be looking for with that kind of mileage as far as long-term issues?
Is there anything that is no longer available for this car that could be a potential issue?
I learned the hard way with an 84 RX7 a few years ago, A LOT was no longer available to replace. I know this BRZ is going to be only 9 years old, but... have to ask.
MCD73 is offline   Reply With Quote
Old 12-27-2022, 03:01 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
There's nothing really mechanical that is likely to fail at a certain mileage. In 190k+ miles these are the only age related issues:
1) multiple bushings needing replacement
2) axle was stuck in the hub and I have to replace the entire knuckle now
3) coolant neck was so brittle that it cracked when I took the hose off. replaced with an aftermarket metal one
4) brake calipers needed a rebuild/replacement due to worn seals and pistons sticking
You can still get all parts pretty easily, though used engines are getting harder to come by and much more expensive as a result.
Tristor (01-03-2023)
Old 12-27-2022, 03:14 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
How's the bodywork?
Old 12-27-2022, 04:14 PM   #4
finch1750
finch1750's Avatar
How's the bodywork?
Im dont treat my car super well but i guess its help up fine. the paint hasnt gone to shit though if you put it next to someone who takes care of it im sure you ould notice a difference. Im also from California where so rust isn't an issue. The doors wont stay open at all though, so whatever piece gives those tension could probably benefit from replacement.
The front and rear ends have both been replaced from seperate accidents though lol.
Old 12-27-2022, 04:16 PM   #5
MCD73
Good, it doesn't sound like anything unusual fails with this car from the research I've done. I mean... it is Toyota after all (for the most part). Just was a little concerned with the mileage. But, if it was taken care of properly.. should be good. At least I am hoping!
Old 12-27-2022, 06:13 PM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Not to get too picky, but the twins are mostly Subaru. Market and aftermarket parts are readily available.
@WNDSRFER has 240,000 on his car. If you take care of them properly and drive it like someone's Nana, they will last.
The Following User Says Thank You to blsfrs For This Useful Post:
MCD73 (12-28-2022)
Old 12-28-2022, 07:28 AM   #7
WNDSRFR
Drives: FR-S,GTI
Or you can just beat the shit out of it.
Just change your oil from time to time.
The Following 5 Users Say Thank You to WNDSRFR For This Useful Post:
blsfrs (12-28-2022), Dave-ROR (12-30-2022), pope (01-12-2023), Spuds (12-31-2022), x808drifter (12-30-2022)
Old 12-28-2022, 01:21 PM   #8
MCD73
You're right. They are well-built though. So far the car I am looking at... seats are crap and the steering wheel is all marked up from someone wearing rings. 2 Projects right there. Still waiting on the mechanical analysis. Just going off pics so far. I know I want to keep it stock, but don't want a giant project on my hands either.
Old 12-28-2022, 03:08 PM   #9
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Always tricky to know based on the previous owner. But that's the risk you take with any used car purchase really. You do have to keep an eye out, as many people with this car will bring it back to stock to put it up for sale. So it being previously modified isn't out of the question. But as long as a fool didn't own it, like others have said, proper maintenance keeps this car in good shape like other good vehicles out there. Plenty impressive enough for a cheap sports car. Parts are fairly cheap and there is a wide variety of choices in the aftermarket world if it makes sense to switch over from an old OEM part that needs replacement.
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
MCD73 (12-29-2022)
Old 12-29-2022, 03:04 PM   #10
finch1750
finch1750's Avatar
Oh, yeah. I forgot about replacing my steering wheel because it peeled really badly. It was not a super common issue but common enough. No jewelry required to damage it even.
If you can't find a cheap OEM replacement just go with an aftermarket that lets you keep the airbag still.
norcalpb (12-29-2022)
Old 12-29-2022, 04:19 PM   #11
MCD73
Ha, funny you mention that.. the car I am looking at has a steering wheel all marked up, and was already looking at the potential project to replace it.. and looks like the seats as well. Pics I have show seat covers... so I know what that most likely means!
Old 01-02-2023, 11:54 AM   #12
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
"The doors wont stay open at all though, so whatever piece gives those tension could probably benefit from replacement."
Door checks, which apparently weren't available for a while, are now back. I bought one for $45, 15 minutes work and solved my biggest gripe about the car. If you can't find one they can be shimmed. There's a thread about that you could look up.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
finch1750 (01-03-2023)
Old 01-03-2023, 03:16 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
By far one of the most annoying things about the earlier cars. IIRC they changed the part at some point to fix it.. but I haven't bothered buying said part.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 01-25-2023, 05:52 PM   #14
daniloneil8
What is the door check issue?
The door does not stay open?
I would like to fix this, if possible
Please advise.
daniloneil8 is offline   Reply With Quote
Advice on replacing oxidized parts Llilith BRZ First-Gen (2012+) — General Topics 8 11-02-2022 10:15 AM
NO LONGER AVAILABLE kinghurl Cars for Sale/Trade 3 11-21-2021 11:05 PM
Need new rotors - advice on correct parts stayclam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-22-2019 12:54 PM
no longer available AllOutApex Australia Classifieds 0 01-20-2016 08:08 PM
No longer available funx Canada Classifieds 3 10-29-2013 09:10 AM
