Old 04-04-2019, 12:01 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Anyone Using Stock STI Injectors?
I've been searching exhaustively, so I feel comfortable asking this here. Is anyone using blue or pink STI injectors? They are in near unlimited supply, and can be had far cheaper than new injectors.
If they require modification, what is involved? Seems like they just may need a spacer.
I am not looking for feedback on IF I should do this. I'm asking for the sake of asking, as I may be doing. If I had my car currently I'd just check and see.
Ok go.
Old 04-08-2019, 01:54 PM   #2
DarkPira7e
DarkPira7e's Avatar
Whooo, I guess that's a no. Not surprised. I'll document my efforts, whether or not I can get them to work for me.
Old 04-29-2019, 09:52 AM   #3
KingJon1991
Drives: scion frs 2015
not going to work your going to need a tune
KingJon1991 is offline   Reply With Quote
Old 07-02-2020, 08:45 PM   #4
2slowbrz
Drives: Boosted 13 bra
Would also love to know if any other injectors work there tons cheaper then brz specific
2slowbrz is offline   Reply With Quote
Old 07-02-2020, 09:02 PM   #5
DarkPira7e
DarkPira7e's Avatar
I ended up using them and had no issues. Just needed to fabricate a spacer for the rails.
Made about 330whp using them
Old 07-02-2020, 09:23 PM   #6
sato
sato's Avatar
Drives: Dodge Patitas
So what benefits are you seeing other than lower cost of new injectors? What are you up to?
sato is offline   Reply With Quote
Old 07-02-2020, 09:38 PM   #7
DarkPira7e
DarkPira7e's Avatar
The only advantage was that I had them from a bugeye I owned years ago. I'm going to be buying ECUTEK's 750cc injector package so that I have injectors that aren't 15 years old in my new build
Old 07-03-2020, 06:37 AM   #8
sato
sato's Avatar
Alright. Good luck with build but thanks for sharing your experience.
Old 12-17-2022, 03:54 AM   #9
ericfey7
Drives: 2013 JDM ZN6
sorry to bump old thread. Jsut curious do you need to mod the adapter or its' plug & play ? any other modification require to fit these injectors?
ericfey7 is offline   Reply With Quote
Old 12-17-2022, 01:07 PM   #10
DarkPira7e
DarkPira7e's Avatar
Had to make little spacers so the rails could seat properly. Plug and play otherwise
Old 12-22-2022, 12:16 AM   #11
ericfey7
awesome!
did you cleaning& replaced the o-ring prior install?
these injector are pretty aged though. assuming you still running them, any specific issue along the way?
Old 12-22-2022, 07:37 AM   #12
DarkPira7e
DarkPira7e's Avatar
awesome!
I didn't bother cleaning or changing anything when I threw them on. They worked flawlessly, I switched to ID1050x injectors because my goals changed. I trusted these injectors because they were my mine to begin with and I know they ran fine before I pulled them
Old 12-23-2022, 04:18 AM   #13
ericfey7
approx how many horse power are these injector limit to?
Old 12-23-2022, 06:52 AM   #14
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
182-2,912HP and anything in between. (even more if you add more cylinders)
Fuck I hate people who don't even search before asking a question.
Stock Frs Injectors 60k miles LetterVi Engine, Exhaust, Bolt-Ons 2 07-16-2018 08:20 PM
WTB: Stock MAP sensor, and stock port injectors Agent_D Want-To-Buy Requests 2 05-25-2016 05:08 PM
WTB: Stock Port Injectors asphaltkyle Want-To-Buy Requests 0 03-23-2015 03:57 PM
Anyone try ID2000 injectors on stock ECU? Revolutions Performance Software Tuning 14 03-26-2014 01:10 PM
