#183 |
Stig's dark passenger
Oddly enough, that very question led me here and ended up wanting to do the K swap.
#184 | |
Drives: Crapcan
I doubt that.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | Bach415 (12-16-2022), captain awesome (12-16-2022), RedReplicant (12-16-2022), Tatsu333 (12-16-2022), Teseo (12-17-2022) |
#185 |
Drives: None
Dyno either reads really high or there is a pretty decent bump in compression from would have to be the FA20 head combustion chambers being smaller than the FA24? Has anyone compared the two heads volume wise yet? The power rolls over at similar RPM as the full FA24.
#186 |
Drives: FRS
Anyone know if the BRZ FA24 US is different from JDM FA24?
#187 |
Drives: None
They posted their stock / stock w/ tune dyno in there, for a bit more context. This appears to be plotting whp but the corrections look different.
#188 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RedReplicant (12-16-2022) |
#189 |
Drives: 2020 BRZ Sport Tech RS
Not putting much stock in the dyno numbers, and I sure wish there were a bit more detail on what was involved in adapting the FA24 short block to everything else, but good to know that someone has made it work!
This is still my preferred long-term route forward, I think. Now to wait until there are some short blocks available for non-stratospheric prices...LOL.
| The Following 2 Users Say Thank You to Tatsu333 For This Useful Post: | NoHaveMSG (12-16-2022), RedReplicant (12-16-2022) |
#190 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (12-16-2022) |
#191 |
Weight Weenie
Drives: 15 FR-S
Pardon my ignorance, but If you're going to the trouble of doing this why not just drop in a FA24 long block and all the other bits and bobs out of a wrecked 2nd Gen?
| The Following User Says Thank You to new2subaru For This Useful Post: | NoHaveMSG (12-16-2022) |
#192 | |
ProCrastinationConsultant
as an example; 2013-2015 used one version of cam sensor wheel. 2016+ used an updated version that senses the opposite way. '13-15 was a 'tit' on a wheel the computer saw as momentarily 'on', and was otherwise 'off'. the '16+ cam sensor wheel was a divot-- the computer read 'on' all the time and read 'off' in specific points. meaning that even a 2016+ cam is not compatible with a 2014 computer. going straight fa24 is the same as doing a honda k-motor swap in terms of wiring/programming. many of the major sensors are in the cams/heads. by maintaining the fa20 heads and sensor suite, the motor becomes more plug-n-play with the oem ecu. it just takes a tune to adjust to get the full power out of it.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#193 | |
Drives: Crapcan
We just don't know yet though what it will cost since every one of these assholes that has done it won't tell you what they did to make it work
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#194 | |
Weight Weenie
Drives: 15 FR-S
#195 |
there would always be issues, but it's less of a concern because the ecu is already cracked and can be tweaked to however the new design needs it to operate.
#196 |
Weight Weenie
Drives: 15 FR-S
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
| Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
