Old 12-16-2022, 11:07 AM   #183
D K
Stig's dark passenger
Oddly enough, that very question led me here and ended up wanting to do the K swap.
D K is offline   Reply With Quote
Old 12-16-2022, 12:24 PM   #184
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Bach415 View Post
Bumping this. Not sure if anyone else saw this but it was on FB group. Shop in Thailand was able to do a fa20 heads w/ fa24 shortblock. ~260 whp w/ ecutek on racerom on e75
https://www.facebook.com/permalink.p...97121510449973
Ugh, I hate posts like that. Why can't they tell us what they did, even if it is vague. Someone asked what they did to make the heads work and the response was "the bolt pattern is the same." So no CC machining required I doubt that.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
Bach415 (12-16-2022), captain awesome (12-16-2022), RedReplicant (12-16-2022), Tatsu333 (12-16-2022), Teseo (12-17-2022)
Old 12-16-2022, 01:05 PM   #185
RedReplicant
Drives: None
Dyno either reads really high or there is a pretty decent bump in compression from would have to be the FA20 head combustion chambers being smaller than the FA24? Has anyone compared the two heads volume wise yet? The power rolls over at similar RPM as the full FA24.
RedReplicant is offline   Reply With Quote
Old 12-16-2022, 01:28 PM   #186
Evil Rocky
Drives: FRS
Anyone know if the BRZ FA24 US is different from JDM FA24?
Evil Rocky is offline   Reply With Quote
Old 12-16-2022, 02:37 PM   #187
RedReplicant
Drives: None
They posted their stock / stock w/ tune dyno in there, for a bit more context. This appears to be plotting whp but the corrections look different.
Old 12-16-2022, 03:31 PM   #188
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not that I am aware of. Should be able to estimate it pretty closely being we know engine capacity and compression ratio. Being both engines are 12.5:1 they would have to be larger chambers on the FA24.
Old 12-16-2022, 03:37 PM   #189
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Not putting much stock in the dyno numbers, and I sure wish there were a bit more detail on what was involved in adapting the FA24 short block to everything else, but good to know that someone has made it work!
This is still my preferred long-term route forward, I think. Now to wait until there are some short blocks available for non-stratospheric prices...LOL.
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
NoHaveMSG (12-16-2022), RedReplicant (12-16-2022)
Old 12-16-2022, 03:50 PM   #190
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I agree. That dyno reminds me of the OTL header dyno. Just take the stock curve and bump it up a bit, nobody will notice
soundman98 (12-16-2022)
Old 12-16-2022, 08:05 PM   #191
new2subaru
Weight Weenie
Drives: 15 FR-S
Pardon my ignorance, but If you're going to the trouble of doing this why not just drop in a FA24 long block and all the other bits and bobs out of a wrecked 2nd Gen?
The Following User Says Thank You to new2subaru For This Useful Post:
Old 12-16-2022, 08:15 PM   #192
soundman98
ProCrastinationConsultant
soundman98's Avatar
one of the main issues is going to be sensor compatibility.
as an example; 2013-2015 used one version of cam sensor wheel. 2016+ used an updated version that senses the opposite way. '13-15 was a 'tit' on a wheel the computer saw as momentarily 'on', and was otherwise 'off'. the '16+ cam sensor wheel was a divot-- the computer read 'on' all the time and read 'off' in specific points. meaning that even a 2016+ cam is not compatible with a 2014 computer.
going straight fa24 is the same as doing a honda k-motor swap in terms of wiring/programming.
many of the major sensors are in the cams/heads. by maintaining the fa20 heads and sensor suite, the motor becomes more plug-n-play with the oem ecu. it just takes a tune to adjust to get the full power out of it.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
chaoskaze (01-09-2023), new2subaru (12-16-2022), Opie (12-19-2022)
Old 12-16-2022, 08:17 PM   #193
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Price. You can buy a new shortblock for like 2200 if they will sell it to you. Wreaked 2nd gens are still pretty expensive, I think the last full FA24 out of a wrecked car I saw was like 6500. So if you can slap some sensors, heads, come up with a different reluctor wheel(pre facelift car) it has the potential to be cheaper then buying a complete engine for the DIY'r.
We just don't know yet though what it will cost since every one of these assholes that has done it won't tell you what they did to make it work
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
new2subaru (12-16-2022), soundman98 (12-16-2022), Teseo (12-17-2022)
Old 12-16-2022, 08:18 PM   #194
new2subaru
Weight Weenie
Drives: 15 FR-S
Thank for the reply. Isn't there going to be issues with tuning with FA24 short block with FA20 heads? Will the stock ECU be compatible?
Old 12-16-2022, 08:23 PM   #195
soundman98
soundman98's Avatar
there would always be issues, but it's less of a concern because the ecu is already cracked and can be tweaked to however the new design needs it to operate.
Old 12-16-2022, 08:29 PM   #196
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks again. Good to know.
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
