| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#43 |
Drives: 2023 BRZ
I change wheels and tires about 40 times per year. I've done this for a long time. Swapping pads is no big deal. I know this. Admittedly, this is a bit of an experiment. But again, a couple guys that know a lot more than I do suggested this route, so I'm willing to try it. And the CP compound isn't your typical pad that is advertised as dual-duty.
Director of Rocky Mountain 86CUP
#44 |
Drives: 2022 GR86
We will watch your career with great interest
Follow the build thread for my GR86!
#45 |
Drives: Mini Cooper S
Planning on doing Ferodo DS2500 pads in the spring before track season along with rotors and fluid.
Has anyone found steel braided lines worthwhile? I did the above upgrade to my mini last year along with lines and the brakes feel amazing, really stiff and responsive. Last edited by BioRebel; 12-14-2022 at 12:22 PM. |
#46 |
Drives: 2023 BRZ
I'm unsure how to interpret your comment. Can you please help me understand?
#48 |
Drives: swift2020
The Z23 pads are a Carbon-Fiber Ceramic formula that offer great dust-free braking performance. This kit is designed for increased braking power for a daily-driven car, truck, SUV or crossover. The Z26, on the other hand is designed for extreme street braking performance on high performance vehicles.
watch stories cc generator Last edited by Kumar123; 05-02-2023 at 10:18 AM. |
#49 | |
Drives: '22 BRZ
No. Master cylinder brace does more. The factory lines are braided internally and they're new. Maybe worthwhile upgrading in years when the factory lines have had a lot of cycling/stretching of the braids.
| The Following 7 Users Say Thank You to DocWalt For This Useful Post: | BioRebel (12-14-2022), CSG Mike (12-14-2022), DylanJZA (12-14-2022), OkieSnuffBox (12-19-2022), Racecomp Engineering (12-14-2022), RToyo86 (12-14-2022), Teseo (12-16-2022) |
#50 | |
Drives: 17 Asphalt 86
Seems like more of a drawback as they generally require more attention. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Teseo (12-16-2022) |
#51 | |
If you like Ferodos, consider their actual track pads for track use. If you want to dual duty with a very mildly modified car, go CP. |
#52 | |
The compound should be fine in a car this light running 200tw tires. |
#53 |
Drives: 2023 BRZ
FWIW, changing pads with the OEM front caliper is no more difficult or time consuming than with an AP Sprint or Endurance kit caliper (8350).
#55 |
Drives: BRZ 2013
I run Ferodos DS2500 on the street and find them great for street use, but I can confirm they are not holding up to any substantial track use even on 300TW tires. My experience is that while they can « survive « the track environment, they degrade quicker and can start to fade and will not offer the consistency and confidence of a dedicated track pad, and won’t be money well Invested imho for any serious track use.
I’d offer they would be fine for a novice trying a one time hpde, but for anyone with track driving experience or wanting to do multiple days a year should move to a dedicated track pad. Last season I used Ferodo DS1.11 during the season and summer, and put back the ds2500 after the season was done. A track pad like the ds1.11 is in a complete different class in terms of consistency and safety, with no fading. Just as a reference, the burn in sequence on the ds1.11 requires about 26-30 back to back hard stops from about 100km/h to heat them up, whereas on a street pads you’ll need about 10stops. My experience with keeping the ds1.11 on the street in summer is that they squeal a little after the bed-in layer wears off, but by doing another burnishing they become quiet again. Since I don’t drive as much these days, that was fine for me. Cold bite was plenty fine. But I would not run those only for daily driving due to noise. I find the ds2500 have more than enough bite on the street and can last for years. Otherwise for track driving, higher temp (and fresh) brake fluid is a must in my book and stainless braided lines strongly recommended for safety. For street driving only however, as others have said, the stock setup is more than adequate, but just throwing a set of DS2500 for more initial bite can be nice for people who prefer a stronger initial bite feel. That’s more a personal preference for street use imho. Hope this helps. Cheers Last edited by falcon_wizard; 12-16-2022 at 10:46 AM. |
| The Following User Says Thank You to falcon_wizard For This Useful Post: | NoHaveMSG (12-16-2022) |
#56 | |
Drives: Crapcan
There is also a huge discrepancy in performance in the 200TW category. We talking RS4 or a "super 200" ?
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | CSG Mike (12-16-2022) |
| Safe oil temps for daily driving and spirited driving off the track? | MilkyWitness | Engine, Exhaust, Transmission | 15 | 06-12-2019 08:21 AM |
| Video Journal? Performance driving progression | Jordanwolf | Member's Car Journals | 3 | 05-07-2019 01:33 PM |
| Daily Driving/Spirited Driving Brakes | VABeachBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-12-2017 04:11 PM |
| Rev Works Braking Upgrade Sale! | Rev Works | Brakes, Suspension, Chassis | 4 | 11-04-2015 09:47 AM |
| Daily driven with upgrade specs | Tycocentrouz | Member's Car Journals | 0 | 09-16-2014 11:13 AM |
