Old 12-14-2022, 06:25 PM   #29
edit: ^^^yeah. Not slow, can't.
even if I'm FOS, I still think the secret is buried in those charts.
jonho (12-15-2022), NoHaveMSG (12-14-2022)
Old 12-14-2022, 06:28 PM   #30
jonho
Drives: 2013 FRS
so a new ECU could learn if it was a notched cam gear or tabbed is what you are thinking. So this ECU had learned with tabbed and with tabbed style in it now starts but its showing 18 degrees advanced on both intake cams. So could it be that with all new timing stuff its not exactly the same as it was before and it wont relearn?
jonho is offline   Reply With Quote
Old 12-14-2022, 06:34 PM   #31
I don't know! I can't study those charts now! Mrs. Ultra needs her washing machine. haha
Old 12-14-2022, 06:41 PM   #32
jonho
Drives: 2013 FRS
Good luck!
The Following User Says Thank You to jonho For This Useful Post:
Ultramaroon (12-15-2022)
Old 12-14-2022, 07:35 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by jonho View Post
Intake left and right both show 18* Exhaust left and right both show 0* in techstream
Not sure a 0* value means it is actually reading the position or not though.
Sucks you are having this issue, but this sure is an interesting one.
@tomm.brz thoughts?
Old 12-15-2022, 02:08 AM   #34
I don't know if this makes sense but it's how the old ECU would interpret the signal from the new reluctor wheel with the tabs. I've wondered about this exact scenario all these years. They definitely aren't compatible but would it run? It must. Yours did, right? I think I'd replace ECU and mount the old-style, notched wheels for the sensors.
jonho (12-15-2022), NoHaveMSG (12-15-2022)
Old 12-15-2022, 11:18 AM   #35
jonho
Drives: 2013 FRS
yes it did run and it ran well until had a ringland failure. I still have notched gears. Do you think I need a new ECU or maybe one from a wrecked car? I see 3 by me on car-part for under 60$ in wrecked cars.
Old 12-15-2022, 02:13 PM   #36
Buy 'em all and hope that at least one isn't locked with an ecutek flash.
Old 12-16-2022, 05:50 PM   #37
jonho
Drives: 2013 FRS
ok put a junk yard ECU in and no start at all with tabbed gears. So my morning project is to replace with notched gears and test. I will keep you pasted as to if that works. What is the best way to update VIN in ECU they link in this thread for techstream is dead https://www.ft86club.com/forums/showthread.php?t=102810
Old 12-16-2022, 07:45 PM   #38
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oh noooooo!
That is always the thread I sent other people. I'm not sure without digging around for more info.
Old 12-16-2022, 08:55 PM   #39
https://www.ft86club.com/forums/show...09#post3560409
can't yet vouch for it. *shrug*
wait.... don't you already have techstream? That link was just for the media.
Old 12-19-2022, 10:48 AM   #40
jonho
Drives: 2013 FRS
so new notched gears and junk yard ECU made it run normal Cams all look good and everything! I have a friend with techstream but he says he cant write a VIN is there different levels of license for it?
NoHaveMSG (12-19-2022)
Old 12-19-2022, 11:24 AM   #41
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's cool it's fixed.
Not sure, I need to buy techstream, I don't have it.
Old 12-19-2022, 01:19 PM   #42
jonho
Drives: 2013 FRS
Its odd that it ran fan the whole time we had it on the old ECU and tabbed gears then when we rebuild it runs but shows 18* advanced on intake cams. My theory is someone redid timing before we owned it did a replacement ECU tabbed gears and had the intake cams off a tooth then on startup thats how it learned it??
Timing Chain cover revisions / changes 2013-2020 FrickingReallySlow Engine, Exhaust, Transmission 0 09-21-2021 05:10 PM
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) MJones_RB Issues | Warranty | Recalls / TSB 9 08-22-2019 04:00 PM
Cam position - timing issue. cab33 Engine, Exhaust, Transmission 3 07-01-2018 11:52 AM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! CSG Mike Tracking / Autocross / HPDE / Drifting 47 06-24-2013 05:23 PM
