Old 12-14-2022, 09:25 AM   #15
Grady
Grady's Avatar
Originally Posted by jonho View Post
yeah we are all lost on this one. I would get if it had some custom flash but the tuner starts with a fresh flash.
Is there a way to find out who did the engine swap?
What is the Part number on your current ECU?
What is the serial number on the engine?
At this point best thing to do is to try to determine what all components are original and what ones are changed.
The Following 2 Users Say Thank You to Grady For This Useful Post:
NoHaveMSG (12-14-2022), Ultramaroon (12-14-2022)
Old 12-14-2022, 11:07 AM   #16
jonho
Drives: 2013 FRS
ok so put new 2017 cam gears in and car fires right up. I now have 15-20 degrees advance on intake and codes p0011 p0021 p0019 and p0017.
jonho is offline   Reply With Quote
Old 12-14-2022, 11:19 AM   #17
Grady
Grady's Avatar
See my previous post.
Old 12-14-2022, 11:21 AM   #18
jonho
Drives: 2013 FRS
the block is stamped with the VIN from the car. I will try and get SN from ECU. I called the 2 dealers that showed on the carfax one had done an actuator repair other did a floor mat recall I have no other history.
Old 12-14-2022, 11:27 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It would be nice to see what the cam position values are in techstream.
Old 12-14-2022, 11:50 AM   #20
jonho
Drives: 2013 FRS
ECU shows 22765AC813
So looks to me like its factory block and factory ECU no swapping. Did they ever do tabbed gears on early production ones?
Old 12-14-2022, 11:57 AM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not that I am aware of. Like I said earlier, I have been under the impression the 13-16' ECU can't read the signal.
Old 12-14-2022, 03:06 PM   #22
jonho
Drives: 2013 FRS
Intake left and right both show 18* Exhaust left and right both show 0* in techstream
The Following 2 Users Say Thank You to jonho For This Useful Post:
Old 12-14-2022, 04:22 PM   #23
Grady
Grady's Avatar
Looks like it is time to go back to the pre 17 cam gears and programming.
The Following User Says Thank You to Grady For This Useful Post:
NoHaveMSG (12-16-2022)
Old 12-14-2022, 04:51 PM   #24
jonho
Drives: 2013 FRS
so its now on the cam gears and ecu flash it was on prior to rebuild that had no timing issues and its still the 18* both intake and 0* exhaust. This is how car was when I purchased it. The Rom still is and always has been ZA1JA01C which wont start with notched cam gears but will with tabbed
Old 12-14-2022, 05:39 PM   #25
I'll come back to this after I revive my dead washing machine.
Old 12-14-2022, 05:56 PM   #26
jonho
Drives: 2013 FRS
I think I hate fixing appliances worse than cars haha!! So I saw this difference in the link you sent. But if its using a stock ECU file how could it work? Did someone change the wiring because it looks to be as its just the opposite on triggering high to low
Old 12-14-2022, 06:16 PM   #27
those are views of first-gen and second-gen sensor outputs. The polarity reversal is solely a function of switching from valleys to hills. I wonder if the ecu can learn to compensate for the change in one direction. ...one way trip for the initial position values. I think that's what they're called.
Old 12-14-2022, 06:21 PM   #28
jonho
Drives: 2013 FRS
so I believe the dealer would replace an ECU if they redid timing stuff because it was slow to relearn I thought I read that somewhere
Timing Chain cover revisions / changes 2013-2020 FrickingReallySlow Engine, Exhaust, Transmission 0 09-21-2021 05:10 PM
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) MJones_RB Issues | Warranty | Recalls / TSB 9 08-22-2019 04:00 PM
Cam position - timing issue. cab33 Engine, Exhaust, Transmission 3 07-01-2018 11:52 AM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! CSG Mike Tracking / Autocross / HPDE / Drifting 47 06-24-2013 05:23 PM
