GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
12-08-2022, 10:23 AM | #15 |
Mebmer
Drives: Sienna, GR86, FL5
+1 for stock setup being left as is for any level of street activity. If what you want is bling (nothing wrong with that) get a set of stoptech cryo slotted rotors. $300 or so. They'll probably hold up around as well as OEM and aren't a legit downgrade like cross drilled. And they look proper.
I went round and round in the last few weeks trying to decide what to do for track day setup. Initial plan was just to do pads and fluid. Went all the way around the block considering multiple pad sets/multiple sets of rotors, BBK, you name it. I'm back to pads and fluid. I'm banking on driving for a week or two on the track pads cleaning off the rotors before I swap back to stock to avoid problems with deposits on the rotors. |
12-08-2022, 12:14 PM | #16 | |
Drives: 2022 MT Neptune GR86 Prem.
On a related note, how hard/expensive would it be for Toyota/Subaru to make the stock calipers ones that cover the entire brake pad (and paint them)? Do they not do it to try to maintain desirability for the upgraded Brembos (or whatever) when they come out? I don't track so stock pads/calipers are more than good enough for me. But even painted, they still look like crap (although better). |
12-08-2022, 12:36 PM | #17 | |
Drives: GR86
And if they're even remotely willing to be talked into buyer-pays-shipping kind of deals, they probably wouldn't have said "local pickup only" to begin with. It just confuses me: wheels/tires take up enough room that - if you're storing them properly - you're probably motivated to get them sold fast. I wouldn't turn away any buyer if it were me. But I think the whole massive-camber gang are completely incomprehensible, so I fully recognize that different people have different perspectives. Everyone should be free to do what they want as long as they aren't messing with someone else's freedom. (I'll keep the full contact patch of rubber, personally. I like being able to turn and stop properly.) |
12-08-2022, 02:51 PM | #18 |
Drives: 2022' GR86 Premium 6MT
My $0.02 is that the stock rotors are fine. My planned upgrade over the winter is the following
Motul RBF 660 Brake Fluid (2x 500ml) - $55 StopTech Stainless Steel Braided Brake Lines (Full Set) - $125 ENDLESS Brake Pads (SSM Full Set.) - $225 (Would also recommend Project Mu if nothing from the Endless Catalogue catches your eyes. Can't go wrong with CSG Spec pads either.) You'd be looking in the ballpark of $450.00 for a full upgrade, retaining the perfectly fine stock rotors. I feel like this setup would be good for Street, Backroads, Twisties and occasional Circuit Driving. The rotors IMO are more of a bling factor than anything. Some argue that the slotted and drilled can actually have a negative effect over a flat face rotor. In my opinion, if you're not racing the car odds are the OEM rotors are fine. They're very good quality to begin with honestly. Living in Virginia with the mountain twisties we have here, I have pushed my car incredibly hard. If you're not on circuit I couldn't imagine really reaping a realistic benefit from aftermarket rotors or a BBK or anything of that nature to begin with.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
12-08-2022, 04:02 PM | #19 | |
Drives: '22 BRZ
It adds weight and a lot of cost for the only benefit being "it looks better" to a few people.
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
12-09-2022, 04:09 AM | #20 |
So then how come the aftermarket calipers don’t look like the stock? Seems pretty unbelievable that they would add that weight and sacrifice performance just to look good for “some” people.
12-09-2022, 07:44 AM | #21 | |
Drives: 2018 Subaru BRZ
My thought on this is that, usually, when a vehicle comes with an upgraded brake system, it is usually accompanied by other upgrades (Springs, sway bars, bushings,etc) that would compensate for the increase of unsprung weight, and balance the vehicle out in terms of performance across the board. Whereas a lower trim version wouldn't really see an increase benefit unless accompanied by said upgrades. |
12-09-2022, 08:52 AM | #22 | |
Mebmer
12-09-2022, 10:27 AM | #23 | |
Drives: '22 BRZ
Because aftermarket calipers are quad piston (or more) and you can't see the pads. and any painted calipers are going to be ruined with track use, proper track calipers don't get painted as fredzy commented on. If you just want calipers for looks, cool. Accept that it won't have better performance than the stock calipers though.
12-09-2022, 10:54 AM | #24 |
Drives: Laguna Seca Blue GR86
Aren't the 4 pot WRX calipers like 2 lbs lighter than the ones we have stock? The sliders are heavy.
12-09-2022, 11:00 AM | #25 |
Drives: 17 Asphalt 86
I was curious as well. They're 750usd which made my eyes water a little. Ferrodo Ds2500 are several hundred cheaper and are in the same category for usage.
I've been using stoptech sports on my gen one the better part of 3 years and 60,000-70,000km. Still seem to have some lift left in them as mostly daily use, with some canyon and 2 hours light track usage. The backing plate look like they're about to fall apart due to rust |
The Following User Says Thank You to RToyo86 For This Useful Post: | Teseo (12-09-2022) |
12-09-2022, 11:13 AM | #26 |
Drives: 2023 BRZ
Yeah, that's a LOT of money for pads, to be sure. I'm told with the AP 9660 (?) calipers they'll last a lonnng time. I guess I'll find out.
Director of Rocky Mountain 86CUP
12-09-2022, 12:23 PM | #27 | |
12-09-2022, 01:09 PM | #28 | |
Drives: X5 35d, D90, CX-5 Turbo
"Saves 20 unsprung lbs. from nose of vs. OEM brakes" Even the larger 325mm kit claims a 10 lbs total weight saving.. For daily driving, I agree there is probably no discernable benefit in braking performance with big brake kits, though its never a bad thing to lose unsprung weight.. |
Similar Threads | ||||
Safe oil temps for daily driving and spirited driving off the track? | MilkyWitness | Engine, Exhaust, Transmission | 15 | 06-12-2019 08:21 AM |
Video Journal? Performance driving progression | Jordanwolf | Member's Car Journals | 3 | 05-07-2019 01:33 PM |
Daily Driving/Spirited Driving Brakes | VABeachBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-12-2017 04:11 PM |
Rev Works Braking Upgrade Sale! | Rev Works | Brakes, Suspension, Chassis | 4 | 11-04-2015 09:47 AM |
Daily driven with upgrade specs | Tycocentrouz | Member's Car Journals | 0 | 09-16-2014 11:13 AM |
