Old 12-04-2022, 08:28 PM   #15
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Don't use a Verus clutch fork. I just had mine pulled and an OEM fork put back in by a performance subi shop. The Verus forks are pretty, but the tolerances were not up to snuff. Gave a problem from day one, shop mentioned they've seen several Verus fork equipped cars with the same issue.
jeepmor is offline   Reply With Quote
Old 12-04-2022, 08:38 PM   #16
RedReplicant
Drives: None
What issue did they see?
RedReplicant is offline   Reply With Quote
Old 12-05-2022, 02:32 AM   #17
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I just had the Verus clutch fork and pivot installed 2 days ago along with the Exedy OEM clutch kit. Still breaking it in/driving gently, but zero issues so far.
Never heard of any issues with the Verus fork before. Have you discussed with Verus directly about it?
Old 12-06-2022, 09:44 AM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Love how this is the 2nd post I've seen of jeepmor bashing the Versus fork where nobody has heard bad about it and they ask what was seen. And all he does is ignore them.
Double checked to make sure they didn't disappear for a few days.... Yeah no. They were here 6 hours ago.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
Jdmjunkie (12-06-2022), Spuds (12-06-2022)
Old 12-07-2022, 08:27 PM   #19
Grady
Grady's Avatar
My thought exactly, Verus does not make sub par parts! And if they did mess up on his I guarantee they would stand behind it and do what it takes to fix it.
The Following User Says Thank You to Grady For This Useful Post:
Jdmjunkie (12-07-2022)
Old 12-09-2022, 11:29 AM   #20
e_lunatic
Drives: 2015 Scion FR-S
it's a jeep thing, we wouldn't understand
e_lunatic is offline   Reply With Quote
The Following User Says Thank You to e_lunatic For This Useful Post:
Pat (12-09-2022)
Old 09-20-2023, 09:32 PM   #21
Randoman5
I am currently testing the Gen 2 clutch in my 2013. First impressions are that it feels just like the clutch in the new car, and that is much grabbier than my 100k mile worn out clutch, as to be expected. I will update on whether I have any problems. I had it done by real pros and while they confirm the pressure plate and friction disc are indeed different parts numbers, they have no idea if it's any stronger. They did say it's a slightly different color.
Randoman5 is offline   Reply With Quote
The Following User Says Thank You to Randoman5 For This Useful Post:
Teseo (09-21-2023)
Old 09-21-2023, 09:02 AM   #22
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I haven't had a chance to dig into it, obviously you have, what are the differences between Gen1 clutch and Gen 2?
Old 11-11-2023, 02:32 PM   #23
FrickingReallySlow
Drives: 2015 FR-S
Just saw this twin disc clutch www.uniclutch.com Has anyone tried this? a bit on the expensive side but seems like they got some unique tech inside
FrickingReallySlow is offline   Reply With Quote
Old 11-12-2023, 12:15 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
5.0MG !!
I've had those in all my Japanese bikes since the 60's.
I guess they're really selling fitment on an industrial scale.
If my stock clutch is about to go out should I replace it with a stock or a stage 1? Bread1 Engine, Exhaust, Transmission 6 01-28-2018 01:24 AM
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
ACT clutch and LWF or stock clutch and Evolution industries LWF Hawk77FT Engine, Exhaust, Transmission 13 12-21-2014 02:14 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
