Old 12-04-2022, 09:33 PM   #24011
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The mats on my 2013 have held up rather well. What kind of footwear do you use when you drive your car there in Idaho -
Are you kidding? My first drivers mat had almost worn out heal spot in about 5k mikes. I bought a second set that lasted the same. Then I had a company that makes mats make me some. They are exact size with all the same fittings in the right place, made with the material and colors you choose. They are still like new.
I wear ballet slippers when I drive the twin.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (12-04-2022), soundman98 (12-04-2022), Ultramaroon (12-04-2022)
Old 12-04-2022, 10:52 PM   #24012
^ I'll bet your ballet slippers get a lot of laughs down at the dive bar -
You haven't mentioned the dive bar lately. Do you not go because they ran out of money?
Old 12-04-2022, 11:01 PM   #24013
The stock mats are exactly what one should expect for an inexpensive auto geared toward performance. They're junk but I have zero complaints.
Old 12-05-2022, 10:53 AM   #24014
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I don't go very often these days.
humfrz (12-05-2022)
Old 12-05-2022, 01:08 PM   #24015
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Kinda like the engines.
DarkPira7e (12-05-2022), Ultramaroon (12-05-2022), Wally86 (12-06-2022)
Old 12-05-2022, 02:36 PM   #24016
lolol...
Old 12-06-2022, 12:26 PM   #24017
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed TBW underpanels. Actually fit really nicely. Left a little review here with a couple more photos for anyone interested
https://www.ft86club.com/forums/show...93#post3559193
Don't worry, the zip ties are not staying, it'll be attached to my bash bar when that gets put back on
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (12-08-2022), Wally86 (12-07-2022)
Old 12-06-2022, 03:06 PM   #24018
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Gonna get me one of those ASAP.
Qwimby1 is offline   Reply With Quote
Old 12-07-2022, 07:20 AM   #24019
Compelica
Compelica's Avatar
Drives: 86 GT
Put a bottle of Techron Concentrate Plus into the tank - LTFTs went from +/-3% to +/-1% on the subsequent fillups.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 12-07-2022, 09:18 AM   #24020
Pat
Pat's Avatar
Drives: 2023 BRZ
Huh. That's interesting. What can you tell us about the history of your engine?
Do you always us Top Tier gasoline?
Have other people experienced this?
Old 12-07-2022, 10:33 AM   #24021
WNDSRFR
Drives: FR-S,GTI
I'm guessing he uses Petronas.
It's pretty common in Malaysia.
Old 12-07-2022, 10:56 AM   #24022
Compelica
Compelica's Avatar
Drives: 86 GT
Was a bit surprised myself as well as I had not checked the fuel trims in a while. The weather here has also been rather constant for the past few weeks, within the same elevation as well with a half hour daily drive, back and forth from my workplace.
Engine wise - around 105k kilometers, typically on highway and city commutes since the TCP fillup. No engine mods except for a slightly tweaked off-the-shelf tune. The last fill-up with TCP was done at about 78k.
Fuel has been consistently been on Caltex RON95 for the last couple of months. Here, there isn't a distinction per se on what's considered top tier or otherwise; all fuels are sold at a fixed price per liter depending on RON, with the same base fuel coming from a single refinery plant here in Malaysia. The only difference between the brands are their additives.
The Following User Says Thank You to Compelica For This Useful Post:
Pat (12-07-2022)
Old 12-07-2022, 11:02 AM   #24023
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I just tossed a bottle of redline system cleaner into the tank this week. Been trying to do that every oil change to help keep the DI's from clogging up.
Idle is smoother after first morning commute. Gave her the Italian tune up merging onto the highway.
The Following User Says Thank You to RToyo86 For This Useful Post:
Teseo (12-10-2022)
Old 12-07-2022, 07:43 PM   #24024
Qwimby1
Do you know how that stuff gets along with E85?
