#15 |
Drives: brz 2017 hksv2
Ops sorry, while typing i forgot OP is boosted, was thinking somehow he was NA still
anyway still not enough from him to enjoy 5th gear, apparently that is his goal So would benefit with a 4.56 fd |
#16 |
Drives: '23 BRZ
Still gonna have the same gap between 4th and 5th ratios even with 4.56 diff, you'll just experience it at a lower road speed for a given shift point.
Too bad the AT has such a wide 4-5 gap, should be more like the MT where you keep 5th gear closer to 4th and then have a wider gap 5th to 6th gear for lower-rpm and higher-mpg for highway cruise. Only solution is to hold it in 4th longer before upshifting. Upshifting at redline you'll land at 5276 rpm in 5th, shouldn't be a problem with TORBO! |
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#17 | |
Drives: 2018 Subaru BRZ Limited with PP
#18 | |
#19 |
vroooooooom
Drives: 86
Found this on youtube. It seems the higher fd does give 5th more acceleration |
#20 |
Right, it absolutely does, as there is more torque to the individual gears with a higher FD ratio. Math will dictate this. The losses you will have is more shifting in the same period of time, higher RPM in cruising gear, and lower mpg. You can see in this comparison video, as well as others out there, that there is little to no difference of actual results in terms of how much faster you get up to a certain speed. This is mostly attributed to the fact that you have more shifts involved. But purely in terms of acceleration PER gear and FEEL, each gear will be and will feel faster with a higher FD.
| The Following User Says Thank You to Dzmitry For This Useful Post: | x808drifter (12-06-2022) |
| Higher final drive ratio and increased engine braking | Purist | Engine, Exhaust, Transmission | 11 | 06-16-2019 12:25 AM |
| 4.556 Final Drive with a Turbo Setup | Sh1FTy | Forced Induction | 9 | 04-19-2018 06:13 PM |
| Final Drive Gearing, Auto vs Manual | KoolBRZ | Engine, Exhaust, Transmission | 9 | 09-11-2017 09:50 PM |
| 4.56 final drive with 6th gear from an auto?? | fr-s6MT | Engine, Exhaust, Transmission | 3 | 12-17-2016 11:47 AM |
| Any interest in 4.5 final drive from Auto Factory? | mike_ekim1024 | Engine, Exhaust, Transmission | 12 | 09-12-2013 08:41 PM |
