Old 11-06-2022, 09:50 AM   #15
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Take it back apart and inspect the pilot bearing. Never put a bolt in it to help line it up or pull it together. I would reset the clutch with your alignment tool. If you are using the plastic one it will flex down with the weight of the clutch. Support it and then eyeball it to make sure it looks straight. Once everything is lined up right it will push together all the way. As stated above if you do not support the front of the engine it will rock down and make it more difficult to install.
Old 11-07-2022, 08:55 AM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Completely agree with @Grady. I've always used the cheap plastic alignment tools and never have had a problem. They will droop, so hold a little upward pressure until 2-3 of the pressure plate bolts are snug. Once torqued, make sure the tool will easy slide in and out a couple of times. Then cuddle.
Old 11-08-2022, 06:55 PM   #17
carson.frs
Drives: 2014 FRS
Alright everyone. Here's a little update on everything. I had the car towed to a friends shop so I could use a lift and that definitely helps. What I ended up doing was removing the two bottom bolts that the trans sits on and instead aligned the dowels straight in and then I just screwed those 2 bolts back in. I think those bolts might have been a little bent but either way, that made the trans going on MUCH easier. One of those bottom bolts was already loose anyways so I decided to try it out and everything seems to have lined up just fine. I'll be testing it all tomorrow after I get everything back together so hopefully everything works but the engine and trans are flush and the transmission is engaged.
And by the way we used bolts for the last maybe 1/5 of an inch to just pull them together which helped a lot.
carson.frs is offline   Reply With Quote
Old 11-30-2022, 11:59 AM   #18
carson.frs
Drives: 2014 FRS
Ok sorry for no update. Took it to a friends shop and got it on a lift and I ended up taking off the bolts that the transmission actually slides onto because one was already loose and seemed to be bent. I then got it to the dowels and after some pushing, then pulled it in with the rest of the bell housing bolts very carefully. I screwed those bolts back in using the 2 nuts stacked method and it drives great. Also I’m not sure how much it helped but we did spin the crankshaft while pushing it in to make things easier.
Thanks everyone for the help!
Old 11-30-2022, 01:27 PM   #19
Great to hear! Thanks for the closure.
Old 11-30-2022, 10:49 PM   #20
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Super satisfying when people actually post that they resolved an issue, especially on an open forum.
villainous_frx is offline   Reply With Quote
Old 11-30-2022, 11:02 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Reminds me of this meme.
dowel pins, transmission, transmission install
Messed Up Bell Housing Bolts tobsadness Engine, Exhaust, Transmission 4 09-25-2022 01:07 AM
How bad did I screw up my bell housing? DigitalVeil92 Engine, Exhaust, Transmission 33 08-12-2022 12:06 AM
Rubber Cover Fell Into Transmission Bell Housing trinidadj Engine, Exhaust, Transmission 15 06-30-2021 11:58 AM
FS: Verus Bell Housing Cover skylinekin Engine, Exhaust, Bolt-Ons 2 09-07-2018 10:21 PM
Clutch squeak inside bell housing? hukdizzle Issues | Warranty | Recalls / TSB 18 07-18-2015 11:54 AM
