Old 10-29-2020, 07:49 PM   #1
trinidadj
Drives: '16 FRS-MT Ablaze Red
Rubber Cover Fell Into Transmission Bell Housing
Hi Everyone,
I'm currently in the process of changing my clutch and after removing the fly wheel I notice two broken rubber pieces falling to the ground. This appears to be the rubber boot that covers the bell housing. Looks like it fell into the bell housing and got chewed up by the flywheel/clutch. The rubber boot left a bunch of black gunk inside the bell housing. Has this happened to anyone before? and if so how do I go about cleaning this up? Will brake cleaner work?
Thanks for the help!
trinidadj is offline   Reply With Quote
Old 10-29-2020, 08:03 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Brake cleaner will work just fine.
Verus do a metal replacement that can't fall in. Apparently it happens enough to have made this product.
1974 TA22 Celica
2013 86 GT
Old 10-29-2020, 08:06 PM   #3
Gloonge
Drives: 2013 frs raven
Can confirm. I know of 2 other people besides me that it happened to. Had to go verus.
Gloonge is offline   Reply With Quote
Old 10-29-2020, 08:20 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I was skeptical about needing a better cover. Consider me convinced.
Brake cleaner should work fine. Use in tandem with compressed air (from an air compressor) to clean super well.
The Following User Says Thank You to DarkPira7e For This Useful Post:
norcalpb (10-30-2020)
Old 10-29-2020, 08:23 PM   #5
Gloonge
I thought it was a dumb product too when I first seen it. Thought it was just one of those products to rice up your engine bay. Until the morning I started my car and the God awful racket from that cover getting chewed up scared the shit out of me.
The Following 3 Users Say Thank You to Gloonge For This Useful Post:
norcalpb (10-30-2020), Tcoat (10-29-2020), Wally86 (06-03-2021)
Old 10-30-2020, 12:44 PM   #6
norcalpb
norcalpb's Avatar
Yup this thread convinced me to buy the Verus cover.
Old 10-30-2020, 02:20 PM   #7
trinidadj
Thanks everyone for the help so far. I got some brake cleaner but looks like it’s off to harbor freight to get small air compressor lol. I’ll post an update on this when I get done cleaning.
The Following User Says Thank You to trinidadj For This Useful Post:
DarkPira7e (10-30-2020)
Old 10-30-2020, 03:20 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If you have a shop vac, often you can swap the hose to the exhaust side and use one of the small tips for adequate pressure.
Then you can put it back to clean up the gunge you've blown all over.
Old 11-01-2020, 02:02 AM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Make sure the crankshaft tone wheel is in the correct orientation when you reinstall it. Teeth face in towards the sensor, away from the flywheel.
jcw99 (06-03-2021)
Old 06-02-2021, 05:36 PM   #10
afishl1
Drives: Raven FRS MT
Anyone know if this is an easy thing to see if it fell into the hole or do you have to essentially do a clutch job and take the tranny apart? If it fell in, how bad would it be to leave it there?
afishl1 is offline   Reply With Quote
Old 06-02-2021, 06:59 PM   #11
Ultramaroon
not playing cards
If it's missing, it fell in. Big fat meh. Just don't drop any tools in the hole.
Old 06-29-2021, 09:32 PM   #12
DarkSunrise
DarkSunrise's Avatar
Checked this recently and saw that my bellhousing cover was gone too. Installed the Verus cover today. I’m not convinced it’s necessary (especially at $37) but I do feel a little better knowing there’s not a gaping hole there anymore.
Install was pretty easy. Remove 12 and 14 mm bolts. Install cover. Replace bolts and torque to 10-12 lbs-ft (12mm) and 16-18 lbs-ft (14mm). I had to remove the rubber (pcv?) hose above the 12 mm bolt to gain access to it but it pulls off without any tools.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
bcj (06-30-2021), Ultramaroon (06-30-2021)
Old 06-30-2021, 01:19 AM   #13
Ultramaroon
not playing cards
It's nice! It screws into place and won't melt.
bcj (06-30-2021), DarkSunrise (06-30-2021)
Old 06-30-2021, 01:52 AM   #14
DarkSunrise
Haha yep basically that.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
FS: Verus Bell Housing Cover skylinekin Engine, Exhaust, Bolt-Ons 2 09-07-2018 10:21 PM
LCA PillowBall Joint Rubber Cover Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2016 02:01 AM
PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing slicktop Engine, Exhaust, Bolt-Ons 6 10-17-2015 10:53 PM
Clutch squeak inside bell housing? hukdizzle Issues | Warranty | Recalls / TSB 18 07-18-2015 11:54 AM
NEED HELP BACK UP LED ( fell in housing ) 21_nola_05 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-08-2014 04:53 PM
