#1499 |
Drives: Q5 + BRZ + M796
If you have a manifold and gauge set that pulls vacuum then it should be good to go
#1501 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
#1502 | |
Wears Pants
Word from Kpower on the fuel pump relay has come in:
#1503 |
So what you are saying is I might need to pay for the cost of a new board (at cost to Kpower) and for the relay, and I need to pull the board out now. All this, so I can park the car for a while on accessory mode without it dying on me? Ugh. I don't know that the cost or time is worth it.
#1504 | |
Wears Pants
I might end up doing the wire patch to the board like RedReplicant. At this point I don't feel like pulling the board again, but after needing a trickle charger to tune last week I want the fix. I may wait to see what they consider "cost" on the board. Something tells me it's not going to be as cheap as their overpriced relay kit though. Last edited by captain awesome; 11-30-2022 at 08:24 AM. |
#1505 |
Drives: None
I would guess it'll be $100 or so.
I initially sent them a summary email of the issue after I tried to call and explain but I haven't heard anything back after sending a picture of the jumper and prime working on Sunday. Oh well ![]() Curious if the sensor ground was incorporated in a harness update or not, people wouldn't know there was an issue unless they were datalogging in Haltech or logging on the Haltech CANBUS rather than the chassis CANBUS (which doesn't expose oil temp). On another note, I went to pull my TB to test fit another adapter last night. I'd marked my TB bolts with the assumption that they'd back out before breaking, which none of them had done so far. Put the slightest pressure on one to remove it and it broke, so I am glad I found that now rather than it actually coming apart this weekend. Bolt size for BRZ TB is M6x1.0 60mm, bolt size for KPower adapter + Bosch TB is M6x1.0 45mm. Turned out that the spares I bought won't work due to the head shape, so I have some ordered from two places in hopes that I get some before this weekend. Finding actual grade 10.7 or 12.9 is a pain, I'm going to be preemptively swapping them every 4 or 5 events from now on. Easiest way to remove them is to take the adapter off the car, drill through the broken bolt with a smaller bit, then try to drill through it again with a slightly bigger bit. It'll drive the broken piece out the back of the adapter.
#1506 |
Drives: Many
Does anyone know if the Cusco engine mounts work with the kit? I remember reading somewhere that certain engine mounts don't mate up with the kpower brackets.
#1507 | |
Drives: None
I have IAG Street mounts in a box here that look similar to the Cusco ones and would work.
#1508 |
Drives: Many
Thanks, I missed that! I have an old pare of STi group N mounts laying around somewhere that will do the trick then.
#1509 | |
Wears Pants
Final word from Kpower.
I'm reluctant to mod my board because it's a v1 and I'm not sure what all the v3 received update wise other than the added fuel pump relay circuit. Probably just order the v3 and be able to swap out without much hassle. Other than removing half the damn dash again... |
#1510 | |
I suppose a kill switch would do the same thing, but it just wouldn't be automatic.
#1511 | |
Wears Pants
I have more tuning coming up with the head and cams swap it's going to get installed sooner than later. I'll keep you posted on it. |
#1512 | |
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
