Old 05-07-2018, 05:56 PM   #113
CSG Mike
CSG Mike's Avatar
Originally Posted by Soloside View Post
Mike,
Are you using the base t518z turbo from like 2014? I currently have the T620z that I bought back in 2014, do you have an idea what the max boost these turbos can go up to?
Yes, the base T518Z kit from 2012.
Max boost on the 20G will depend on your engine, but is more than anything a stock engine can handle safely. I would expect to see anywhere from 16 to 24 psi, depending on your engine.
Old 06-12-2018, 02:53 AM   #114
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Out of curiosity. Do the GReddy kits require any welding to install?
Ryan GT86 is offline   Reply With Quote
Old 06-12-2018, 03:29 AM   #115
CSG Mike
CSG Mike's Avatar
Just the oil return
Old 06-12-2018, 04:09 AM   #116
Ryan GT86
Ryan GT86's Avatar
Just the oil return
I'm assuming it would be best to get that done by a welder? Also how much would it affect the mileage by? A friend of mine says he just messes with tunings and changed the exhaust header for more power since forced induction would kill the mileage.
Old 07-05-2018, 03:44 PM   #117
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hey Guys,
Just wanted to pop in and let all of you know that Phase 10 RaceROM is finally here for all model years and all regions of the world (Not just the initial 2013-2014 and 2017-2018 release), from 2013-2018 models on USDM, European, Asian, JDM (Yes it's different), and Gulf spec ECU's. Our entire tune library has been updated to accommodate the new software, and we are now rolling out these tunes to new and existing customers. A lot of our customers running Greddy kits have been asking about this update, so I wanted you all to be among the first to know that our Delicious tunes are all built up and vetted out for the new software.
The latest version is denoted as V25.00. Though RaceROM 10 is really a complete and utter overhaul of the way we do tuning on these cars, some of the more important changes are as follows:
- Improved tip in throttle response throughout entire rev range
- Completely overhauled closed loop correction outside of factory closed loop scenarios
- Completely overhauled boost control on turbo systems, implementing a variety of fail safe and target compensations to correct for and protect against overheating oil/coolant, poor quality fuel, AVCS being inactive, and more. We also have a lot more adjustment room to have features like boost by gear, ethanol content, map-switch mode, and more working in tandem with one another.
- Completely overhauled Flex Fuel implementation. Ethanol content, ethanol ignition advance, and more are now all dedicated parameters in EcuTek. The way Flex Fuel is programmed is also far superior in RaceROM 10, and allows much tighter integration into the tune. What this means for the end user is a smoother transition between fuel types, and a smoother ramp in power delivery as ethanol content increases or decreases.
- Dedicated custom map to warn you when your AVCS system has failed to activate in a timely manner, letting you know before you push the car and risk potential damage.
- Vastly improved control over fueling in medium to full load areas.
- Improved transition from low load MAF calculation to high load VE calculation.
- Improved drivability across all versions.
- Addressed a particular bug where some vehicles would experience a hesitation in high gear, partial (20-40%) throttle pulls. This was typically experienced when trying to pass on the highway, for example.
If you have any questions about this update, feel free to contact me via email at sales@delicioustuning.com.com. This update takes what is already a great turbo kit, and improves it more than we previously thought possible.
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Decimus (02-06-2019)
Old 09-01-2018, 05:32 PM   #118
saikat.saha
Drives: Toyota Gt86 2012 orange
Hello friends,
I am using greddy T518z on my gt86 . It doesn't comes with boost controller, i am planning to increase the boost by grimmspeed ebcs than the factory map with 7psi . But I couldn't figure out how to connect the female port ( electric port which is go to tge ecu for controlling the boost by tune ) to my ecu. If you know please share with me.
Thanks in Ad.
Saikat
saikat.saha is offline   Reply With Quote
Old 04-10-2021, 07:06 PM   #119
g.rz
Drives: '18 Subaru BRZ
Little bit of a late post, but joined the club with the kit! Here are the numbers, big thanks to Zach from CSG for the Tune, and Neal from the Racers Line for getting me set up!
g.rz is offline   Reply With Quote
The Following User Says Thank You to g.rz For This Useful Post:
CSG Mike (04-12-2021)
Old 11-12-2021, 10:01 PM   #120
PearlAozora
PearlAozora's Avatar
Drives: 2015 Subaru BRZ Aozora Edition
I have a t620 turbo with 16000km on it if anyone wants to upgrade.. looking for a t518 with quicker response
PearlAozora is offline   Reply With Quote
Old 11-18-2022, 06:29 AM   #121
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Hi everyone I just got a retune for my car and when I got it back it had a nice audible turbo flutter/compression surge, but after a few drives I noticed the flutter got weaker. Is this normal or is there an issue with my wastegate or solenoid?
Lucky21 is offline   Reply With Quote
Old 11-18-2022, 09:23 AM   #122
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Did you drive with the window down the first time, and now it's up? I doubt anything has changed
Old 11-18-2022, 10:19 PM   #123
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
No it's noticeably weaker now a few days after tuning,because it had flutter on downshifts before now it doesn't have it anymore.
Old 11-19-2022, 07:12 AM   #124
DarkPira7e
DarkPira7e's Avatar
If you want more peace of mind, go check and make sure non of the intercooler piping has come loose. Has the performance changed in any perceptible way? The only thing that would change is the sound is if there is less air stuck behind the throttle body when it snaps closed.
Old 11-20-2022, 09:21 PM   #125
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
EDIT:The weak flutter sound was due to a leaking exhaust manifold.
Thanks for the advice! Not really that worried just genuinely curious why the audible flutter got weaker.
Old 05-22-2024, 12:52 AM   #126
beevanka
Drives: BRZ, Miata, M2
Not sure why this kit is less popular in the United States,
I have a BRZ in China with T518Z on, I track the car often and never really had any issues and I have about 285 WHP
beevanka is offline   Reply With Quote
Greddy / Trust Turbo Kit (Video and Pictures) BPAuto Forced Induction 62 03-18-2016 06:04 AM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 02:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! NOTORIOUS.BRZ Forced Induction 17 07-29-2013 04:42 PM
