Old 11-06-2022, 08:49 PM   #1401
RedReplicant
Drives: None
Originally Posted by Kelse92 View Post
Darn, sounds like carrying a spare transmission is a great idea until it can’t really be done in the paddock at an event. I have a spare, but doesn’t seem to be worth bringing it in this case of the motor always needs pulled for it
I might have been wrong and it might not need to be pulled, but it seems like it might be somewhat of a pain to get the new transmission mated to the motor in the car. The annoying part is unbolting the slave, which I just popped the line off for by accident. Going to pick up a transmission now and all that is left to remove the transmission is remove the bell housing bolts.
We will see.
Upside is I can probably find an Exedy OEM clutch disk / pressure plate locally tomorrow and get rid of the Sachs time bomb at the same time.
Originally Posted by ML View Post
This was a Jack trans? those pieces look like the are from something more substantial than a syncro though. I'm pulling mine out this week, I guess if you were closer you could come get it.
Yeah, it was. I figured it was part of an inner hub, but looking at it again I am probably wrong. Maybe they could be part of where the 4th gear circlip is (and replaced with a collar on this)? I dunno, we will see. May as well open this one up like I did the last one I blew up since they're just paperweights.
RedReplicant is offline   Reply With Quote
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
funkjaw (11-06-2022), Kelse92 (11-07-2022), ML (11-07-2022)
Old 11-06-2022, 10:49 PM   #1402
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I pulled the transmission with the engine in. It was a pain. I had to clearance the mount brackets to drop it down, but essentially the engine and trans needs to be angled down to be removed. It wasn’t easy. It took a lot of finagling, but it is possible.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
captain awesome (11-07-2022), funkjaw (11-06-2022), Kelse92 (11-07-2022), RedReplicant (11-07-2022)
Old 11-07-2022, 06:18 PM   #1403
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Word from kpower on the fuel pump relay came in.
Yes, it can easily be added to the car after the fact, and no settings in the ECU need to be changed. We'll get it added onto the website this week if anyone else wants to add it. Give us until the end of the week to get it live and then you can grab one anytime.
captain awesome is offline   Reply With Quote
The Following 5 Users Say Thank You to captain awesome For This Useful Post:
endless_pain (11-08-2022), Irace86.2.0 (11-08-2022), Jdmjunkie (11-07-2022), Kelse92 (11-07-2022), RedReplicant (11-07-2022)
Old 11-08-2022, 12:52 PM   #1404
RedReplicant
Drives: None
It was pretty easy to get the transmission out of the car, the slave cylinder just sucked to deal with. I loosened off the motor mount nuts top and bottom, jacked up the front of the motor via the pan, and the transmission basically fell off the car on top of me.
My Sachs pressure plate looks fine, but pulled it anyway based on the failure pictures I've seen. It seems like the rivets that attach the friction surface strap to the pressure plate come loose and it tears everything up.
The Following 4 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (11-08-2022), Irace86.2.0 (11-08-2022), Kelse92 (11-08-2022), ML (11-08-2022)
Old 11-09-2022, 08:45 AM   #1405
captain awesome
Wears Pants
I thought the Sachs clutch setup was what Kpower recommended? Has there been a bunch of failures? I'm on stock Exedy so not worried but kinda surprised considering the difference in cost is fairly large.
The Following User Says Thank You to captain awesome For This Useful Post:
ML (11-09-2022)
Old 11-09-2022, 10:40 AM   #1406
RedReplicant
Drives: None
EndlessPain had one fail and so did one of the dudes that runs GridLife. You'll notice that KPower stopped selling them too.
I bought mine from a race shop in Germany, so it was a lot cheaper than what KPower was asking for them. Either way, there aren't a ton of these things being run and I figured the dots lined up in favor of getting rid of it since I already have the transmission off.
I opted for an OEM Exedy this time around too, I am hoping it reduces some of the shock load on the transmission.
The Following User Says Thank You to RedReplicant For This Useful Post:
captain awesome (11-09-2022)
Old 11-09-2022, 11:32 AM   #1407
captain awesome
Wears Pants
I'm happy with the stock clutch. Until I was supercharged and starting to slip on my previous car it held up super well. Pretty sure the Exedy torque threshold is still higher than what my planned built motor would put out. I do hear more chatter with this swap than I think I ever had with the fa20 though. Not loud but noticeable when in a drive through with the way the sound bounces off a building.
RedReplicant (11-09-2022)
Old 11-10-2022, 03:21 PM   #1408
ML
ML's Avatar
Drives: 13 White MT FR-S
Rack boot under the header is cracked and very hard to the touch. Any one else?
Refresh has begun
The Following 6 Users Say Thank You to ML For This Useful Post:
captain awesome (11-10-2022), funkjaw (11-11-2022), gt5759 (11-10-2022), Irace86.2.0 (11-10-2022), Jdmjunkie (11-10-2022), RedReplicant (11-10-2022)
Old 11-10-2022, 07:35 PM   #1409
redlined600
redlined600's Avatar
Drives: Fr-s
So some of you are running the OEM(exedy) clutch and pressure plate without issues? I didn't figure it would hold the extra torque.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
Old 11-10-2022, 08:24 PM   #1410
captain awesome
Wears Pants
I’ve read from reputable sources it will hold until around 230 torque. I think above that threshold is possible but that’s based on how my supercharged setup did under certain conditions.
Old 11-10-2022, 10:02 PM   #1411
Ebush
Drives: 2017 Hot Lava 86
I run the exedy 3 puck. It's been great for me. My car is mainly just a daily driver, with the occasional back road beating. Stock k24a2 so I'm probably not putting it under much stress.
Ebush is offline   Reply With Quote
The Following User Says Thank You to Ebush For This Useful Post:
Old 11-10-2022, 10:37 PM   #1412
RedReplicant
Drives: None
That boot thing happened to me with the Harrop/Ace A350/E85/FA20, I'll watch the new one I just put on.
Car is all back together, trans feels like butter, clutch feels super smooth and easy to drive. We will see if it holds up, put like 5 miles on it then right on the trailer for Chuckwalla on Sat/Sun this weekend.
Transmission mated to the motor right away first attempt, no idea how I got so lucky. I learned that the slave should be installed/removed with the motor / trans bolted down, rather than trying when it is tilted for removal.
The Following 7 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (11-11-2022), funkjaw (11-11-2022), Irace86.2.0 (11-11-2022), Jdmjunkie (11-10-2022), Kelse92 (11-11-2022), ML (11-11-2022), Pat (11-10-2022)
Old 11-11-2022, 03:14 PM   #1413
Irace86.2.0
FWIW, I have a stage 1 Exedy that is rated at 166wtq and 254 at the flywheel and is holding 300wtq for me. I don’t believe it would hold that on track for OEM longevity, but it held on the dyno pull after pull.
https://www.ftspeed.com/part/15806-e...toyota-86-2017
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 11-11-2022, 05:05 PM   #1414
redlined600
Drives: Fr-s
Yeah, that's actually why I was concerned. I'd love to use the oem clutch as it's very economical.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
