Old 10-26-2022, 03:20 PM   #23955
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just remembered, I had a really loud ticking on start up, seemed to go away after 3-4 minutes, right now my assumption is that the valvetrain wasn’t lubricated well enough and it took awhile for oil to find its way into the lifters and roller rockers. Maybe I’m too tight on the valve lash, we ended up on the low end of the spec, will see when I cold start it later today.
Maybe the cam gears were finding their homes. You'll let us know in either case, I'm sure
Old 10-26-2022, 07:43 PM   #23956
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Good a guess as any
Engine feels great even at part throttle and under 4k rpm, highly recommend everyone disassemble and get some head.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
new2subaru (10-28-2022), RToyo86 (10-26-2022), soundman98 (10-26-2022)
Old 10-26-2022, 10:12 PM   #23957
Good a guess as any
Did you test compression? I bet it's cherry after valves lapped.
Old 10-26-2022, 11:14 PM   #23958
strat61caster
I didn’t but that plus some fresh rings and cleaning up the buildup on the valves is probably what I’m feeling.
ineedyourdiddly
Old 10-27-2022, 12:22 AM   #23959
Oh, damn.... I fixated on the heads and forgot that you replaced the whole short block.
strat61caster (10-27-2022)
Old 10-27-2022, 06:09 PM   #23960
Kaotic Lazagna
Drives: GR Corolla
Not sure why there was some gunk building up in the clutch reservoir, but removed the recently fluid I put in, and tried wiping off as much of the blackish gunk as I could, and put in new fluid.
Old 10-27-2022, 10:17 PM   #23961
It's fine particles wearing off of the piston's o-rings. Normal and harmless. Ends up in the reservoir because that is the net flow of fluid. As the clutch wears, the reservoir fills.
Kaotic Lazagna (10-27-2022), soundman98 (10-27-2022), Teseo (11-03-2022)
Old 10-27-2022, 11:31 PM   #23962
Kaotic Lazagna
Drives: GR Corolla
That's good to know. Thanks!
Old 10-30-2022, 03:59 AM   #23963
keenanok
keenanok's Avatar
Drives: 2013 Whiteout FR-S
just a picture of my engine bay because it looks clean for once
keenanok is offline   Reply With Quote
Old 10-30-2022, 04:11 AM   #23964
Sam86
Drives: Toyota 86 GTS
What was meant to be simply adding quad tip garnishes to a MY17 bumper turned into a lot more work. I bought a bumper online that had much more severe damage than described and shown in the pictures. I had 0 painting or body repair experience going into it but here is what I started with, and here is where I’m at now after getting the quad tips welded on today. Had to modify the diffuser to fit but I think it was worth it and don’t know that anyone else has done the same combo before.
Really happy with how the paint came out, did mess up in a few spots but for a first time and doing a paint blend with spray cans I can’t complain.
Sam86 is offline   Reply With Quote
The Following 6 Users Say Thank You to Sam86 For This Useful Post:
BirdTRD (11-01-2022), Busybee (10-30-2022), KMA KiCKz (11-02-2022), MJones_RB (11-01-2022), RToyo86 (10-30-2022), weederr33 (11-01-2022)
Old 10-30-2022, 05:56 AM   #23965
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Any feedback on the intake? Do you have to take the bumper off to clean the filter?
alex87f is offline   Reply With Quote
Old 10-30-2022, 10:23 AM   #23966
soundman98
ProCrastinationConsultant
soundman98's Avatar
Where are those exhaust tips from?
Old 10-30-2022, 04:34 PM   #23967
Sam86
Aliexpress, just keep in mind those particular tips significantly changed my exhaust tone, at least from what I hear inside the cabin. Don’t know if that’s due to it being a dual tip, the resonator “heat dispersion” holes or both
The Following User Says Thank You to Sam86 For This Useful Post:
soundman98 (10-30-2022)
Old 10-30-2022, 04:37 PM   #23968
soundman98
soundman98's Avatar
louder or quieter?
