Old 10-07-2022, 06:16 PM   #71
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
wow, awesome build. I'm really interested in the breaks and oil baffle. I may do this in the spring. Love the wheels!
The breaks- Any cutting or grinding? I wanted to get OEM 2018-2020 STI front breaks. When I had my 2019 STI the breaks were phenomenal and I miss that breaking performance. I want to replicate that performance.
Your car would RIP at limerock. Lol
nice job.
autosenses is offline   Reply With Quote
Old 10-08-2022, 01:44 PM   #72
Code Monkey
Drives: Subaru BRZ
No cutting or grinding, sometimes you get a little bit of a whoosh sound when driving, probably the wind hitting the rotors at some specific angle.
Bled the brakes yesterday as well and will be testing wheel fitment later today.
Code Monkey is offline   Reply With Quote
Old 10-08-2022, 08:30 PM   #73
Code Monkey
Drives: Subaru BRZ
Some quick pictures from the garage. It looks like the rear will not require shaving but we will see.
Old 10-11-2022, 01:32 PM   #74
Code Monkey
Drives: Subaru BRZ
Took the car out on a test drive, drove all over the shitty roads in the neighborhood and very spiritedly over speed bumps. Looks like there should be no rubbing whatsoever in the rear, the picture is with the wheel on a 4x4 and the other one on the ground.
Old 10-11-2022, 05:17 PM   #75
redlined600
redlined600's Avatar
Drives: Fr-s
Cool Build!
redlined600 is offline   Reply With Quote
Old 10-26-2022, 02:39 PM   #76
Code Monkey
Drives: Subaru BRZ
The fronts are rubbing the wheel liner at full lock, especially on driver side so switched to 20mm spacers and replaced the wheel liner with a new one, still plenty of clearance on the fender side.
Old 10-26-2022, 10:08 PM   #77
dreamwonder
Drives: GR86 2022
https://www.verus-engineering.com/sh...pra-1042#attr=
That is my remedy for liner rub.
dreamwonder is offline   Reply With Quote
Old 10-27-2022, 04:52 PM   #78
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
The rubbing is normal and expected at full lock.
Lincoln Logs is offline   Reply With Quote
Old 10-31-2022, 05:20 PM   #79
Code Monkey
Drives: Subaru BRZ
2nd oil analysis.
Old 12-21-2022, 12:00 PM   #80
Code Monkey
Drives: Subaru BRZ
Not much to update. Finished my HPDE season the Thanksgiving weekend. Did a total of 9 HPDE weekends, May-November: 5 weekends at Road Atlanta, 3 weekends at Barber, 1 weekend at VIR.
A bit over 5,000 miles on the car. Another oil change is due but will wait until late February as the car will not be driven much until then.
Looks like 2023 will be quite eventful, probably close to 15 HPDE weekends.
Planning on swapping the OS Giken from the 4.3 diff into the 4.1 diff over the winter.
Old 12-21-2022, 03:47 PM   #81
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Care to give a review of the v730's? I have heard they are kinda inbetween an RS4 and super 200.
Old 12-21-2022, 06:03 PM   #82
Code Monkey
Drives: Subaru BRZ
I was really happy last year with the V730''s on my '17 BRZ, plenty of grip, even 30 minutes into a session. Did not particularly excel in any performance metrics, think of it as being good at everything though, a Goldilocks of performance tires. Would cycle out in a predictive manner, the car would start feeling a bit looser and those were fun sessions too. However, once I tried the V730 on my '22 BRZ, I felt like they were not as grippy as I remembered. The first set I ran 225's on OEM rims so I chalked it to running a narrower tire. The second set was 255's, a little bit more grip than the 225's but nothing mind blowing. I will be running something stickier next season, most likely the new RE71 compound or the Eagle F1 Supercar 3.
As for other contenders, I ran Falken RT660's on my '01 Boxster and was not impressed and Yoko A052's are just too expensive and I do not see a good value vs lap time. I really need a tire trailer and slicks.
Old 12-21-2022, 07:34 PM   #83
dreamwonder
Drives: GR86 2022
I transitioned over from v730 to supercar 3r. A lot more grip (2ish seconds for my local tracks) but they seem to wear twice as fast. Best place to buy them is on goodyear.com, when on sale, it's $750 installed for a set of 245/17/40. Prod date on the ones I bought is mid 2021.
Old 12-26-2022, 05:40 PM   #84
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Cool build. I also wrapped my ball joints in front when I installed Brembo BM4 fronts and GT backs. I'm not baller enough for Radi-cals The rear heat shield was a pain to remove the first one, since I didn't realize they were welded. The second one went much faster with a big hammer to identify the weld spots, and a chisel to knock them out, and a little grinding and paint to make it look reasonable.
Wangspeed is offline   Reply With Quote
2017 Subaru BRZ hpde build Code Monkey Member's Car Journals 207 04-18-2022 10:11 AM
2022 BRZ JDM Spec build at HKS USA for SEMA2021 143 BRZ Second-Gen (2022+) — General Topics 5 02-14-2022 12:27 PM
redSerpente’s HPDE/86CUP Street build redSerpente Member's Car Journals 10 04-26-2021 06:50 PM
LS3 HPDE / Time Attack Build RavioliG Member's Car Journals 17 02-11-2018 03:56 PM
86_Freak - Build for DD/C Street/HPDE duties 86_Freak Member's Car Journals 3 03-07-2016 09:15 AM
