Old 08-19-2017, 08:51 PM   #1
Code Monkey
Drives: Subaru BRZ
2017 Subaru BRZ hpde build
Just picked up a Series.Yellow BRZ, will mod it a bit for road racing while still keeping it stockish as much as possible.
Up-to-date mod list:
Code:
new engine @18,315 miles assembled by Controlled Motors
Killer B oil pickup
RacerX oil cooler kit with Setrab 619
pre-2017 airbox with Perrin filter
sound tube delete
OS Giken
MCS TT1 coilovers with 550/550 springs
Vorshlag camber plates
Vorshlag spherical rear upper shock mounts
STi flexible v-bar
Whiteline front endlinks
Whiteline camber bolts
RacerX rear upper control arms
MCA Suspension 86 Traction Mod
Hotchkis 25mm front sway bar
Hotchkis 19mm rear sway bar
Hotchkis rear endlinks
949Racing 6UL 17x9 +40
HPDE tire du jour 245/40/17
ARP extended studs
Brembo BBK
KNS front rotors
Ferodo DS3.12 brake pads
Castrol SRF brake fluid
GrimmSpeed master cylinder brace
new transmisison @22,062 miles
SouthBend stage 2 Endurance clutch
Verus clutch fork and fork pivot
clutch spring delete
MTEC shift springs
JDL 4-2-1 header
CSG Touring 86 Competition catback
tuned by Zach @CSG
STi motor mounts
STi transmission mount
STi ST41322AS010 & ST41322AS000
Whiteline KDT923
Whiteline KDT922
REAL leather steering wheel
2018 tS steering wheel trim
Overland Designs cluster visor
Beastronix V2 86Nanny
Verus throttle pedal spacer
Code Monkey is offline   Reply With Quote
The Following 7 Users Say Thank You to Code Monkey For This Useful Post:
bmxr (06-25-2018), Clipdat (08-23-2017), Elliotw (04-06-2018), HachiRokuX (10-08-2018), Racecomp Engineering (10-02-2017), Tokay444 (05-25-2020), weederr33 (03-13-2018)
Old 08-23-2017, 12:39 AM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Gorgeous!
The Following User Says Thank You to Lonewolf For This Useful Post:
Code Monkey (09-30-2017)
Old 08-23-2017, 01:33 AM   #3
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Such an awesome color
Drambeenie is offline   Reply With Quote
The Following User Says Thank You to Drambeenie For This Useful Post:
Old 08-23-2017, 10:57 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'm feeling those yellow seat accents.
Originally Posted by humfrz
I'm old and lazy
Old 08-24-2017, 12:04 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Welcome to the Series.Yellow club!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 09-25-2017, 04:32 PM   #6
Code Monkey
Drives: Subaru BRZ
The Perrin inlet tube for '17 models is not available for another month so I made my own sound tube delete.
A 1.5" flexible cap from Home Depot (part # PQC101), notched appropriately on the bottom so it slides completely onto the stock intake, $2.97.
On the firewall side, for the time being I reused the stock plastic connector with Gorilla tape on the engine side, works like a charm.
Also, got a Perrin license plate kit installed.
The Following User Says Thank You to Code Monkey For This Useful Post:
Elliotw (09-30-2017)
Old 09-25-2017, 05:00 PM   #7
Code Monkey
Drives: Subaru BRZ
Got a GrimmSpeed master cylinder brace installed. Super easy install, take your time to make sure the master cylinder is not moving, took me two tries to preload the brace with my helper operating the brake pedal.
Will crack 1,000 miles tomorrow and look into a few more mods.
Old 09-30-2017, 03:17 AM   #8
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Hello Fellow Banana owner!
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Old 09-30-2017, 03:18 AM   #9
Elliotw
Elliotw's Avatar
What does the sound tube do?
Old 09-30-2017, 11:11 AM   #10
Code Monkey
Drives: Subaru BRZ
Redirects some of the intake noise into the cabin.
Old 09-30-2017, 04:51 PM   #11
Code Monkey
Drives: Subaru BRZ
Next batch of mods:
Bridgestone Potenza RE-71R (done)
Motul RBF 600 (done)
Ferodo DS1-11 brake pads
Motul 5W-30 300V engine oil
oil filter
alignment
Both front and rear Brembo calipers have two bleeders per side, serious business!
Old 09-30-2017, 05:57 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
What size RE71Rs did you go with?
I'm old and lazy
Old 09-30-2017, 05:59 PM   #13
Code Monkey
Drives: Subaru BRZ
Stock size, 215/45/17. At some point I want to run 17x9 +35 with 245 or 255 tires.
Clipdat (09-30-2017)
Old 09-30-2017, 07:55 PM   #14
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
Totally understand doing the 3 year thing. I said screw it and did some NA modes early on, I'm so glad I did. The car now drives the way it should have from the factory. Of course if your running 205Hp and 4.3 gears, it's a bit better than mine was from the factory. If your staying stockish, also pick up a K&N airfilter....
PNW-BRZ is offline   Reply With Quote
The Following User Says Thank You to PNW-BRZ For This Useful Post:
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 05:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 09:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 07:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 06:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 11:53 PM
