Old 08-02-2012, 04:28 PM   #281
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Propaganda View Post
exactly what i was wondering. Posted about it too, lol.
looks like there were 2 different bases? 1st one has 1whp less for max.
Yeah, and a different curve even ignoring the 1whp.. same timestamp though.
Most have gained great power with the header, Agency Power's appears to lose power? Something can't be right here.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2012, 04:30 PM   #282
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by EsoBOFH View Post
what are you doing up with the resin/plastic - custom lip/spoiler?
I'd guess a fiberglass lip spoiler, or CFRP? Can't see much but some resin.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2012, 04:31 PM   #283
fenton
^Just looks like less smoothing was used on the second graph
fenton is offline   Reply With Quote
Old 08-02-2012, 04:33 PM   #284
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
I'm interested, because so far none of the lips/spoilers on offer appeal to me.. all of them seem too "bolted on" and after thoughts - would love a custom, integrated spoiler.. id' be willing to sand down and repaint the trunk for a nice integrated look.
EsoBOFH is offline   Reply With Quote
Old 08-02-2012, 04:35 PM   #285
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah filter value is different, changes the curve quite a bit, especially at the top.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2012, 04:49 PM   #286
celica73
Was there two baselines? The two Travis baselines look different on those two graphs?
How did the full exhaust lose power compared to just catback?
Me is cornfused.
Huge smoothing differences (45 on one, 90 on the other), also a change in the y axis.
I can see them being the same with those considerations.
Old 08-02-2012, 04:52 PM   #287
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah missed the filter difference at first, enough smoothing to go from losing power up top to not really for the same run.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2012, 05:13 PM   #288
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by vividracing View Post
So you're telling me I should buy your catback because it makes good power. Max power = 186; Avg power = 129
Ok got it, I can deal with that.
But you're also telling me I should not add on your midpipe or header because once I do I will lose power? Max power = 183; Avg power = 126
How on Earth could that be possible? Doesn't your midpipe get rid of the factory cat, not even replacing it with a high flow unit?
The header alone isn't picking up any power, but should easily once the engine is breathing a bit better. You would see similar result on most 4 cylinders in that case anyway.
So most 4 cylinders gain power from a catback but then lose it with the addition of a header, unless you also add an intake?
Color me confused. Maybe I'm ignorant or maybe I'm missing something. Please educate me.
mike2100 is offline   Reply With Quote
Old 08-02-2012, 05:18 PM   #289
E92M3Guy
Drives: BMW E92 M3
Ok so here we go!
This is:
Baseline
Stock w/ pulley only
Stock w/ catback only
The pulley run and the catback run pretty much overlap identically
Couple of questions:
Want to make sure these are whp numbers, not chp numbers. Charts imply it could be chp, but I'm not sure Mustang has a "crank horsepower" measurement mode. So please confirm one way or the other.
Second, what is the dyno correction type on this graph? SAE, STD, Uncorrected, etc.?
E92M3Guy is offline   Reply With Quote
Old 08-02-2012, 05:35 PM   #290
vividracing
vividracing's Avatar
+13whp delta from stock to catback and a +9whp delta from header, mid, and catback.
1)Do you think that's from the heat soak?
2) Josh, you mentioned the header alone won't show much gains, but wouldn't it at least show something? Lachute's showed what, a 10whp gain with just that alone.
I'm curious as to why a more free flowing header (from stock) would result in less of a gain
No worries man
Im not going to blame anything on it being heat soaked as far as power loss. I just wanted to let everyone know that a lot of the runs were back to back to back and the engine never really cooled off so there were no glory runs.
Even though the header is free flowing its just bottle necking into the rest of the stock exhaust so gains would be minimal. I can post the dyno if you want all it really did was smooth out the power band and netted 1 whp in the top end.
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
Propaganda (08-02-2012)
Old 08-02-2012, 05:35 PM   #291
SpeedR
First86 / boat thief
Drives: MKIV Supra
My experience with vivid.
I spent about 8K with them 3 years ago on a 2JZ-GTE BK 3.4 engine kit and accessories.
I had some minor parts problems that were not their fault they handled it quickly and professionally.
IMHO they have done the best they can to answer our questions and they are currently who I plan to get my catback and mid from.
SpeedR is offline   Reply With Quote
The Following 2 Users Say Thank You to SpeedR For This Useful Post:
CBR600RR (08-02-2012), TPO (08-03-2012)
Old 08-02-2012, 05:37 PM   #292
vividracing
Originally Posted by Hawaiian View Post
Mmmmm that wheel gap looks SEXY! (yes I know it's on a lift. I'm joking).
Once again, thanks for all of the hard work you guys have put into this.
yeah were taking it out to Moab then to the rubicon trail in a few months when it cools down just need some beefier tires!
Old 08-02-2012, 05:42 PM   #293
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No worries man
But in this case the graphs show the header and overpipe LOSING power with the AP catback?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-02-2012, 05:42 PM   #294
vividracing
Me is cornfused.
Ill be the first to say im not a dyno whiz and i look at numbers just like the rest of you. Ill assume the baselines look different from the smoothing used
Also ill assume the catback and the catback w/ header are due to heat?
I just said i wouldnt blame it on that but it is the likely culprit.
I have confidence in the header I just think it is going to be best suited once someone actually gets some time on a dyno and tunes the car.
Thats the biggest thing that is missing in my eyes is having the car tuned with these modifications.
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
Agency Power (headers) Polo Engine, Exhaust, Transmission 1 07-21-2012 06:27 PM
Enjuku Racing - Agency Power - New Products Released Enjuku Racing Engine, Exhaust, Bolt-Ons 0 07-16-2012 04:46 PM
FRS on a heartbreaker dyno (Vivid Racing car) Lonewolf FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 06-14-2012 06:29 AM
