Old 10-21-2022, 12:50 PM   #43
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Originally Posted by RToyo86 View Post
My 2017 is at 113,000km and counting. Curious how much longer the "revised" TOB is with the different grease they use.
My 2017 is at 112,000km and still OEM clutch and TOB.
I downshift with revmatching all the time, so there is plenty of clutch use. I like to think I drive it properly.
So far so good! I will obviously replace the TOB when it comes time to do the clutch, but at this point I'm thinking that the clutch will go first.
*knock on wood*
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
RToyo86 (10-22-2022)
Old 10-21-2022, 02:09 PM   #44
wbradley
Sarcastic SOB
wbradley's Avatar
My car squeals when first started but after a minute or so it stops. And the sound stops when the clutch is depressed. I guess I'll need to get the TOB repaired. Where to take it in the GTA and what should I expect it to cost? I've 80K km on the vehicle, maybe time to change tranny and diff oil too?
Might need to copy this post in the CANADA section.
Old 10-22-2022, 11:09 PM   #45
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
I did mine in 2020 in London. I want to say parts cost (OEM bearing, OEM bearing clip, Verus fork + pivot) was ~$300 CAD? And labour was ~3.5-4 hours of work ($90/hr, London mechanics are cheap ). All in like $700 I want to say, not 100% sure. This also included driveline fluid change (trans + diff) labor. I'd advise to swap the clutch while you're in there.
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
wbradley (10-23-2022)
Old 10-22-2022, 11:50 PM   #46
*knock on wood*
They changed to the new version TOB in mid 2016 so you should be fine.
Old 10-23-2022, 02:45 AM   #47
iag48st
Drives: 10Series 0945
Originally Posted by e_lunatic View Post
The Exedy OEM clutch kit i got comes with the updated TOB. I would think most of them would come with the good one now but best to check.
When I had clutch replaced I was on a time crunch and didn't end up getting the clutch fork. so far zero issues. If you have the time and the funds I would recommend it (always a good idea to replace weak point when you have things apart anyway) but it doesn't seem like its a must do if you aren't beating on the car and doing autoX and track days or things like that.
where did you order clutch kit from?
iag48st is offline   Reply With Quote
Old 10-23-2022, 03:32 AM   #48
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm pretty sure you can get it directly from exedy
This is the kit that fits our cars:
https://www.exedyusa.com/products/FJK1005
Old 10-23-2022, 11:36 PM   #49
iag48st
Thanks for link. I ordered it from 86Speed along with a new clutch fork and revised TOb for $311.
Welcome to my life with a BRZ SynrGG BRZ Photos, Videos, Wallpapers, Gallery Forum 11 12-10-2018 08:52 AM
Average life expectancy from Tein Basics? HatchirokuV2.0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 12-11-2015 08:24 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
The life of my FR-S thus far! srt4_night_rider FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 65 08-13-2012 03:23 PM
Goo gone f***ed my life frs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 56 08-02-2012 10:00 AM
