| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: frs
Goo gone f***ed my life
So today my toy badge came and i went debadge the scion one, i took of the front badge and the goo is so hard to come off, i used alot of goo gone but the paint turned a bit yellowish now! i tried to wash it off but the paint is still ruined...
im really sad now.. maybe someone know how to fix it?
Drives: 2013 Scion FR-S Firestorm Red MT
I'm really confused on how your paint turned yellow. I've used Goo Gone to debadge my Si, granted it was black, without issue. I did it to the other day on the FR-S badge and plan to do similar with the Scion ones once I get Toyota badges.
Are you completely sure it's not just the lighting? Can you get some closer pictures of where it starts/stops?
Drives: 1995 Nissan Sentra
I dont see anything in that picture, I used Goo Gone on a friends white chevy cruze and have no issues, are you sure you used goo gone or goof off? If I remember correctly Goof Off will just eat your paint
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
Claybar. Goo Gone won't eat your paint. Like stated above - Goof off will screw you over.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
Drives: Moped
Goo gone is not needed to remove residue after debadging...simple wax and some elbow grease will do it if the surface is warm.
Drives: frs
it looks really yellowish in person, im pretty sure its not the lighting.
well the label says goo gone, i got it from canadian tire, the color of it is yellow tho. i think i will try to clay it does it make sense that iron x might be able to fix that? |
hmm pretty sure goo gone is supposed to be orange.
Drives: frs
Re-member
Drives: Toyota camry
did you try soap and water? Maybe goo gone left a residue. I have used goo gone on my silver 04 toyota with no ill effects, 2 years running, in S. CA.
Nothing decays like progress, and nothing preserves like neglect.
#10 |
Weird, maybe it stained your clear coat for some reason, try polishing it out yet?
#11 |
Drives: frs
#12 |
Drives: frs
#13 |
Pull my finger...
Drives: Silver Scion Slushbox
You shouldn't really "Goo" anything, it's really the wrong product to use for this sort of thing.
You can get Klean-Strip Prep-All at most auto parts stores or plain mineral spirits, or heck, you could even use WD-40 in a pinch. WD-40 is more for removing small amounts and will take forever to cut through the adhesive. Especially if there are gobs of it. I've used 3M Adhesive remover but that is a little more aggressive and I've had mixed results. WD-40 probably the least aggressive and you probably have some on hand. It you're careful, after the badge is off, you can roll/rub the bulk of it off with your fingers and then use a mild solvent to treat, wait a about 30 seconds and wipe off with a microfiber towel. Rinse and repeat until clean. The aforementioned solvents will not harm or discolor your clear coat. You'll just have to apply wax again. As for a clay bar, I'd really be surprised if that would work. This looks as if the clear has been discolored and may take something a little more aggressive to buff that out. If that's even possible at this point. You'd really have to have a pro look at it to determine how deep it went before attempting something like that. I would suggest taking it to a professional paint shop or a high end boutique type detailer for some suggestions. Ninja Edit: A little booger 101: (I know you have experience with this)Another little trick is if you can get a ball of the adhesive going with your fingers, you can use that ball to pick up more adhesive by pressing it into the stuck adhesive and pulling or rolling the ball across it. And to OP, I am sad with you too
#14 |
Drives: frs
oh, that's a bad new for me then. another hole on my wallet .. =(
| NYC BRZ: Life in the Big Apple with a BRZ | NYC BRZ | Member's Car Journals | 36 | 08-14-2012 12:25 AM |
| The life of my FR-S thus far! | srt4_night_rider | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 65 | 08-13-2012 03:23 PM |
| I will probably only have this sort of luck once in my life... | joshua | BRZ First-Gen (2012+) — General Topics | 9 | 07-11-2012 08:08 AM |
| Life is good! | RKC | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-23-2012 07:54 AM |
| 86/FR-S Real Life Spottings | CSSM | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 04-03-2012 12:40 AM |
