Old 10-11-2022, 09:10 PM   #1
JP2332
Drives: Silver Scion FR-S, Stock
FR-S has been sitting for two years
For the last two years my FRS has been sitting collecting dust outside in Cleveland, occasionally being started, but not driven, every 3-6 months. I am looking to restore it back to working order, appropriately. The goal is to have it back on the road by May '23. I am looking for recommendations for what I should address. I already know that I will need to replace brake pads, rotors and tires but I was wondering what else I should address in case anyone else has experience with this.
JP2332 is offline   Reply With Quote
Old 10-11-2022, 09:49 PM   #2
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
2 years is not that bad. Change all fluids. I would not worry about pads and rotors they may clean themselves up. Check date on tires. If they held air the entire time the flat spots will work out with some heat cycles.
Grady is online now   Reply With Quote
Old 10-11-2022, 10:06 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
it's totaled.
Old 10-12-2022, 01:28 AM   #4
Grady's on point. Drive it a bit and change fluids.
Old 10-12-2022, 01:08 PM   #5
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Only thing I’d add is a brake and maybe a coolant flush.
Edit. Actually, Grady covered that.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 10-12-2022, 01:13 PM   #6
Implied. Trans and diff as well. Honestly, I probably wouldn't follow my own advice. I'd just drive it.
Old 10-12-2022, 01:20 PM   #7
I'd just drive it.
This^
Drive it a bit and THEN change fluids.
If tires don't round out THEN get new ones
If rust doesn't clear off brakes THEN replace what needs to be replaced.
Old 10-13-2022, 11:56 AM   #8
Kaotic Lazagna
Drives: GR Corolla
I'll add...might want to remove the intake box and hose to clean and inspect for signs mice/squirrel living in it (feces, nuts and other food, debris, etc). Inspect the cabin filter for the same. And inspect any wiring you have access to in the engine bay for being chewed up by mice.
Old 10-13-2022, 02:59 PM   #9
chipmunk
Drives: _
+1 for intake filter. Not sure how sensitive the FA20s are, but my motorcycle died a couple of times 2 weeks ago. Turned out to be a dirty air filter.
Also, run some fuel additives like PEA cleaners, or ethanol neutralizer/cleaner, etc.
chipmunk is offline   Reply With Quote
Old 10-13-2022, 08:34 PM   #10
OH OH OH I forgot about that step. Yes this is very important even if the car was stored indoors.
Old 10-13-2022, 09:37 PM   #11
Kaotic Lazagna
Drives: GR Corolla
Yup. My friend didn't drive his Q50 for a month or two and left it in the garage. Mice chewed up one of the harnesses.
Old 10-13-2022, 11:02 PM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
What otherwise might be mistaken for crickets might actually be mice squeaking as they squish through the intake valves, sliced and diced as they pass thru, only to be smeared on the cylinder walls until fully incinerated.
TL: DR
The engine might run a bit rough for the first while.
Old 10-15-2022, 10:08 PM   #13
JP2332
Thank you to everyone that responded. This has been quite helpful and gives me a great starting point.
Old 10-15-2022, 11:53 PM   #14
daniloneil8
Why was the car parked for 2 years? Do you have another car?
daniloneil8 is offline   Reply With Quote
fr-s, frs, maintenance, restore, scion
Car sitting at dealership-does this matter? Veejayy Scion FR-S / Toyota 86 GT86 General Forum 7 08-28-2015 06:40 PM
Long sitting maintenance? dragonwiddd Scion FR-S / Toyota 86 GT86 General Forum 8 08-13-2014 01:17 AM
Stocks sitting in the lot longer now... Iixii Scion FR-S / Toyota 86 GT86 General Forum 38 09-13-2012 02:44 PM
Firestorm sitting on lot for 3 weeks FirestormFRS Scion FR-S / Toyota 86 GT86 General Forum 6 09-10-2012 05:30 PM
What's Everyone's Mileage Sitting At Right Now? IchigoIchie CANADA 28 08-11-2012 11:56 PM
