Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-10-2022, 07:53 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by X25 View Post
Right, but if the oil is no longer lubricating sufficiently, then you'd also see elevated presence of metals in oil as evidence of wear in bearings. I definitely plan to get some analysis done on this platform, too.
Which, UOA already shows and has been proven time and time again over many decades.
x808drifter (10-11-2022)
Old 10-10-2022, 10:16 PM   #16
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Does it mean oil analysis? Anyway, I've got multiple samples tested on '16 C7 Z51 with multiple track days and below mid 280s degrees F on 0W-40, and multiple tests on '14 Camaro SS 1LE at temps below 290s degrees F, and there was no abnormal wear item whatsoever.
C7 Z51 thread:
https://www.corvetteforum.com/forums...ack-build.html
Camaro SS 1LE thread:
https://www.camaro5.com/forums/showthread.php?t=375406
My BRZ does not have enough miles on it yet, but I'm definitely planning on getting it tested, too. I'd love to share the results. I do not exceed 270s degrees F at the track, similar to pretty much every other car I've used at the track, except perhaps the '06 C6 Z06, which ran cooler.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
The Following User Says Thank You to X25 For This Useful Post:
Dzmitry (10-12-2022)
Old 10-11-2022, 10:49 AM   #17
quikag
Drives: '22 BRZ Limited 6MT - Ignition Red
C7 Z51 thread:
Same, I've rocked a C5, a C6 Z51, and my current (going on 12 years) '10 ZR1 with a ton of track time using 5W-30 Mobil 1 synthetic and oil temps regularly in the 270-295F range and have had zero engine issues over the past 20 years tracking.
Synthetic oil is fine at 270F IMHO. Those who want to potentially compromise warranty coverage and get oil temps down some by going aftermarket cooler, go for it! I'll sleep like a baby knowing my BRZ can get up to 270F-ish with synthetic oil on the track.
quikag is offline   Reply With Quote
The Following 2 Users Say Thank You to quikag For This Useful Post:
Dzmitry (10-12-2022), ZDan (10-11-2022)
Old 10-11-2022, 11:09 AM   #18
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Wondering if Jackson Racing will release a dual radiator / oil cooler like they have for the 1st gen. Could be a decent compromise for NA folks, should def be the cheapest option.
Robertw is offline   Reply With Quote
Old 10-11-2022, 11:50 AM   #19
OkieSnuffBox
Drives: '23 BRZ Limited
C7 Z51 thread:
Those are much more robust engines.
As for an aftermarket cooler, I'll be if you lunch a bearing with an aftermarket cooler on the car they are going to blame it and deny the claim.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 10-11-2022, 12:39 PM   #20
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
They already have - I ordered last week and will pickup soon from their shop. But I don't believe it is the cheapest option ($999).
Re_Invention is offline   Reply With Quote
The Following User Says Thank You to Re_Invention For This Useful Post:
Robertw (10-12-2022)
Old 10-11-2022, 02:03 PM   #21
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
On a good oil, yes it can take the heat without damaging the engine. BUT, you know how much power you are losing from the ECU pulling all of the timing because it is seeing oil that hot? Takes all of the fun out of a track day, unless you are already slow and don't notice it.
JDMChris is offline   Reply With Quote
Old 10-11-2022, 02:26 PM   #22
X25
X25's Avatar
I have not seen ECUs pull time based on oil temps. It's usually done based on intake and coolant temps. There's usually only a "limp mode" that can be triggered with too high oil temps.
Don't know much about BRZ's specific ECU, though.
Old 10-11-2022, 02:38 PM   #23
JDMChris
Drives: 2016
I have not seen a modern ECU that doesn't pull timing when Oil temps get too hot.
Old 10-11-2022, 03:09 PM   #24
Pat
Pat's Avatar
Drives: 2023 BRZ
Well this is an interesting point. I'm hoping someone smarter than me (or JDMChris and X25) can tell us for sure how the second gen cars manage timing with relation to oil temps.
@CSG Mike
Old 10-11-2022, 06:08 PM   #25
JDMChris
Drives: 2016
@CSG Mike
In all fairness, I haven't dealt with a muscle car ECU. Maybe American car companies just say SEND IT! FRS/86/GR86/BRZ, ND Miata, Civic Type R all DO pull timing based on oil temp.
Old 10-11-2022, 06:51 PM   #26
DarkSunrise
DarkSunrise's Avatar
FWIW I never saw any timing compensation tables on the 1st gen that referenced oil temps. Coolant temps, yes. IAT, yes. But not oil temps.
This was using romraider and OFT. 2nd gen may be different.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
ZDan (10-11-2022)
Old 10-11-2022, 06:53 PM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
I don't notice timing being pulled on my '17. Terminal speeds at ends of straights are same on lap 4+ at fully developed oil temps (270-275F) as on 1st hot lap at 225F
Old 10-11-2022, 08:58 PM   #28
CSG Mike
CSG Mike's Avatar
Rear world example.
2nd gen pulls on a S2k on a roll race. 8 roll races later, the 2nd gen is now losing to the s2k.
Alternatively, many back to back pulls of a 2nd gen on a dyno reveals a consistent drop in output.
Is it the oil temp or something else? Who knows.
2022+ oil coolers CSG Mike GR86 General Topics (2nd Gen 2022+ Toyota 86) 17 05-15-2023 03:29 PM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 11:44 AM
Oil Coolers AldoRaine Forced Induction 4 05-31-2020 01:10 PM
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
