Old 10-10-2022, 03:25 PM   #1331
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by ML View Post
just fyi for anyone about to build a swap in about a month I'm going to have some stuff for sale like my kpower trans adapter, flywheel, clutch, mount, starter (which is good my wiring was bad), IRP shifter and shift adapter for the swap, Grams TB, a rotrex c30 supercharger, and I have 2 OEM k24/k20 Crank pulleys.
Too bad I just placed my order. I might be interested in the clutch and starter though.
redlined600 is offline   Reply With Quote
Old 10-10-2022, 03:57 PM   #1332
Ebush
Drives: 2017 Hot Lava 86
For anyone having the issue of no vtec after the update, press f4 and look for the oil pressure sensor. Turn that sensor off and you'll be good. This is assuming you don't have the oil pressure sensor.
Ebush is offline   Reply With Quote
Old 10-10-2022, 06:30 PM   #1333
RedReplicant
Drives: None
Anyone have a link to the three hole exhaust gasket that goes between the header and the little mid pipe? Also, the bolt sizes?
I lost mine along with the three bolts and nuts on track over the weekend.
Starting to figure the car out, spent an entire day going the wrong direction on the dampers and wasted the golden first session the second day by realizing the exhaust had sprung a massive leak on the out lap. Car gets pulled on the straights by second gen cars which is kind of to be expected given there is a ~15whp deficit.
RedReplicant is offline   Reply With Quote
Old 10-10-2022, 06:30 PM   #1334
funkjaw
Drives: 16' WWB
What clutch/flywheel combo?
funkjaw is offline   Reply With Quote
Old 10-10-2022, 07:07 PM   #1335
ML
ML's Avatar
Drives: 13 White MT FR-S
Aluminum KPower flywheel with a six puck sprung mantic clutch
Old 10-10-2022, 08:24 PM   #1336
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
It's a standard 3 bolt 3" exhaust gasket. Vibrant 1463 should work but any off the shelf variety should do the trick.
captain awesome is offline   Reply With Quote
Old 10-11-2022, 11:24 AM   #1337
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
About to start my swap to CD trans.
What CD009 are you using? The 350Z version with a clutch fork or the 370Z version with the internal concentric slave cylinder? What adapter plate and transmission mounts are you going to use?
Old 10-11-2022, 11:50 AM   #1338
ML
ML's Avatar
its a 350z cd009, but converting it to hydro TB. Collins Adapter/flywheel/clutch with a GKTech shifter. Hoping to get the Kpower drive shaft shortened as well.
basically following this video
Mcleod Hydro TOB https://www.importimageracing.com/pr...n-x-24-1-250in turn 14 250
Collins Adapter/clutch/FW https://collinsadapters.com/swap-kit...ation-kit.html 1680
GKTech shifter https://www.enjukuracing.com/product...san-cd009.html 329
Sikky Trans Mount https://www.sikky.com/product/86-frs...n-crossmember/ 347
Old 10-11-2022, 01:31 PM   #1339
Irace86.2.0
@ML
Yeah I’ve seen that video and planned to do the same. I was wondering if the stock shifter with the Kpower kit would work. Also, why are you going with the hydro slave cylinder? You are doing the Collins clutches? What made you stick with their clutch kit and not something else, just curious? Tell me more.
Also, do you think modifying the existing driveshaft plus shipping both ways will be cheaper than selling the driveshaft and buying a new one?
Old 10-11-2022, 01:53 PM   #1340
RedReplicant
Drives: None
Anyone swapped to the 74mm Bosch TB and have some dyno data?
I was just talking to a K swapped Miata guy and I realized they run 74mm by default, then I looked at some dyno comparisons Honda dudes have done and it seemed fairly significant.
Not sure if crack pipe or not
Old 10-11-2022, 02:06 PM   #1341
Irace86.2.0
Here they lost 7whp going from 80mm to 72mm, but had improved throttle response, so he stuck with the 72mm. Skip to 27:00:
Old 10-11-2022, 02:26 PM   #1342
captain awesome
Wears Pants
I've got a 74mm waiting to install but was waiting to do it with the built block. Didn't think it would make a noticeable difference in power but if it does I may move it up the to do list.
Old 10-11-2022, 02:29 PM   #1343
RedReplicant
Drives: None
Thank you, I can imagine a very oversized TB being kind of annoying on a road race car due to the change in airflow to throttle body opening amount. With that said, we have the luxury of being able to adjust the pedal to TB curve right in Haltech, unlike the cable throttle guys.
I saw some people talking about 5-10whp gains, which would be one factor in explaining the lower numbers our cars make versus the swapped Miatas, if the numbers I saw were to be believed.
I am currently in a position where I am ballasting to make my power to weight number for classing so I won't be doing anything with it right now, just thought it was interesting.
Old 10-11-2022, 02:34 PM   #1344
FrickingReallySlow
Drives: 2015 FR-S
Would there be a problem to use the K24Z3 for this swap? cursory look at the engine mount locations look similar to K24A2 but Kpower website doesn't mention this engine block. Reason is just for a cheap turbo build since I figured combined exhaust manifold wasn't going to be a factor and I can just use the factory head.
For their miata kswap they say that the K24Z3 can just drop into the K24A2 swap but not sure if K86 would be similar.
FrickingReallySlow is offline   Reply With Quote
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
