Old 10-09-2022, 03:26 AM   #1
AnotherDude000
Drives: 2022 GR86 Neptune Blue!
LCA won't line up?
I have a GR86 and installed some Gen1 HKS Hipermax IV SPs on them. The install went fine, just took a little longer than I expected. Fast forward a few months and I'm getting some creaking noises from the rear. So I went back there and took the LCA down, inspected the strut and it all looked good.
Now comes the problem. For some reason the LCA won't line up correctly. It's as if the LCA is too long or the wheel hub is too close. I uploaded 2 pics, one showing the LCA connected at the subframe and another showing the LCA connected at the wheel hub.
I've gone through installation videos and from what I can tell, the wheel hub should be lower than the subframe at this point and I should be able to attach the LCA to both the subframe and the hub, then use a jack to raise it up to the strut and the endlink. That's what I did during the install. I can't figure this out! This is a 2022 also, but I believe the install is essentially the same.
AnotherDude000 is offline   Reply With Quote
Old 10-09-2022, 05:39 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
From pics wheel hub seems angled as with lots of positive camber, thus moving LCA inwards too much, no?
Old 10-09-2022, 11:03 AM   #3
norcalpb
norcalpb's Avatar
Do you have the parking brake on?
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
AnotherDude000 (10-10-2022), Code Monkey (10-09-2022), finch1750 (10-09-2022)
Old 10-09-2022, 11:49 AM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Undo parking brake, push wheel hub out to line up lca and put the bolt in.
Nothing in your photo looks wrong, that’s just what happens when you undo the lca, the wheel hub flops down towards the center of the car.
Also I’ve never used a jack to do this part of the assembly, just pushed things into place by hand.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
AnotherDude000 (10-09-2022), DarkPira7e (10-09-2022), DocWalt (10-14-2022), finch1750 (10-09-2022)
Old 10-09-2022, 01:02 PM   #5
AnotherDude000
Yes, parking brake is on! Didn't even think about that. I'll try it today.
Old 10-09-2022, 03:02 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yup. I left my parking brake on and had the same issue when I first installed mine years ago. Took me 2 days to figure out what the problem was lol
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
AnotherDude000 (10-09-2022), norcalpb (10-10-2022), soundman98 (10-09-2022)
Old 10-09-2022, 03:55 PM   #7
AnotherDude000
IT WAS THE FUCKING HANDBRAKE. thanks so much @strat61caster
The Following 8 Users Say Thank You to AnotherDude000 For This Useful Post:
bcj (10-09-2022), Code Monkey (10-09-2022), DarkPira7e (10-09-2022), finch1750 (10-10-2022), Racecomp Engineering (10-10-2022), soundman98 (10-10-2022), strat61caster (10-10-2022), x808drifter (10-09-2022)
Old 10-10-2022, 12:29 AM   #8
strat61caster
I still make this mistake at least once a year lol.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
AnotherDude000 (10-10-2022), finch1750 (10-10-2022)
Wait a sec...is it fine to park ON the line, so long as you're not BEYOND the line? tzhu07 Off-Topic Lounge [WARNING: NO POLITICS] 59 11-08-2020 08:40 PM
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
Where Should I Run Air Line? Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-14-2015 06:09 PM
What line is this? razo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-24-2014 12:51 PM
red line pr086 Scion FR-S / Toyota 86 GT86 General Forum 8 06-06-2012 09:15 AM
