Old 10-07-2022, 12:04 PM   #3543
Sort of like JIS instead of Philips? The shape is just different enough that they cam out when mismatched. One of these days I'll sack up and order a set of JIS drivers.
Old 10-07-2022, 01:59 PM   #3544
Not really. Just a #1 Robinson with slot extensions on the side. I don’t know how much torque you would have to use to cam it out. Probably break the head off before that would happen.
Ultramaroon (10-07-2022)
Old 10-07-2022, 03:15 PM   #3545
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Originally Posted by Takumi788 View Post
TIL there is a specific screw driver meant for wiring housing outlets and light switches called an ECX driver.
Great! Now I can tell my dad there's something else I've been doing wrong for 40 years.
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
Takumi788 (10-07-2022)
Old 10-07-2022, 10:35 PM   #3546
soundman98
ProCrastinationConsultant
soundman98's Avatar
sort of. it's a newer design, but isn't universally accepted. square d started using it on breakers, but not their neutral bar screws-- which is still a square/flathead, but the square portion is rotated 45 degrees from the ecx style.
siemens maintains the same square/flathead style, with the square portion rotated 45 degrees from ecx style.
there's also most conduit fittings that use the ecx style screws, which is where i really started using the bit style the most--it offers a little more torque than phillips, and still maintains the self-centering feature.
i keep an ecx bit in my 11-in-1, but really prefer to use it as a last resort.
i generally use the flathead most times so then i can screw the cover plate on afterwards without changing bits.
I just use a #1 Robby which fits just fine without slipping but that is cool.
Sort of redundant but cool.
depends on the screws. they're churned out of the plants so fast in a lot of cases that sometimes the 'square' portion of the screws are more of a 'rounded oval' it does work, but imo, doesn't give any better torque than the flathead option.
i ran one of the ecx bits in my impact for about 6 months. i stopped because i got tired of breaking the bit, or snapping screws.
it really doesn't cam out, ever. unless you're going at the screw head at an odd angle, then it'll strip the top of the screw off to the point that nothing else really gets it back out.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (10-08-2022), Ultramaroon (10-08-2022)
Old 10-08-2022, 01:22 AM   #3547
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Speaking of checking the battery....
TIL that you should always check the battery first...
Battery story.
Spoke to my brother this morning who is traveling way up north. He overheard a conversation from a guy on his mobile. Guy had been on phone organizing car freight. After the guy finished talking on the phone my brother asked what was going on. The guy told my brother that his late model BMW had had a flat battery. Guy called battery installer. Battery installer replaces battery. Car tells guy his car is dead and has to go to an authorized BMW service center. It turns out to replace the battery one has to attach a auxiliary battery so the car always has some power. So, attach aux battery, remove car battery, fit new car battery, remove aux power battery.
Modern cars.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
Boomerang (10-09-2022), NoHaveMSG (10-08-2022), soundman98 (10-08-2022), Spuds (10-08-2022)
Old 10-08-2022, 12:42 PM   #3548
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
TIL deer can get zoomies like a dog. Was drinking coffee with my buddy on his front porch and these two deer were playing for 15-20 minutes. Alternating from bounding around to a full sprint. It was pretty comical.
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (10-08-2022), pope (10-08-2022), Sapphireho (10-08-2022), soundman98 (10-08-2022), Spuds (10-08-2022), Ultramaroon (10-08-2022), x808drifter (10-09-2022)
Old 10-08-2022, 01:20 PM   #3549
soundman98
soundman98's Avatar
Battery story.
Modern cars.
#bmw problems
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (10-08-2022), Spuds (10-08-2022), Ultramaroon (10-08-2022), x808drifter (10-09-2022)
Old 10-09-2022, 02:30 PM   #3550
TIL what really happened to the Hummer above. Short version, it was a known software issue. 45 minute video mostly about the Lightning, but in the first 3 minutes explains what happened.
Old 10-09-2022, 03:20 PM   #3551
soundman98
soundman98's Avatar
yea, not going to watch that crap.
Dadhawk (10-09-2022), MyHybridBurnsGasAndTires (10-17-2022)
Old 10-13-2022, 07:40 AM   #3552
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Today I learned that we can have 2 pages of spam in the "new posts" section and I have no motivation to report every one of them.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
Dadhawk (10-13-2022), soundman98 (10-13-2022)
Old 10-13-2022, 07:45 AM   #3553
Just need to report one. They will go to the source and delete them all. Once one of them get's out of bed that is.
Dadhawk (10-13-2022), soundman98 (10-13-2022), Wally86 (10-13-2022), x808drifter (10-14-2022)
Old 10-17-2022, 09:52 AM   #3554
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I wake up once every month. Go away troll.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 6 Users Say Thank You to Dave-ROR For This Useful Post:
Dadhawk (10-17-2022), soundman98 (10-18-2022), Spuds (10-17-2022), Tcoat (10-17-2022), Wally86 (10-19-2022), x808drifter (10-18-2022)
Old 10-17-2022, 11:06 AM   #3555
Ok Sleeping beauty
Dadhawk (10-18-2022), MyHybridBurnsGasAndTires (10-17-2022), soundman98 (10-18-2022), Spuds (10-17-2022), Wally86 (10-19-2022), x808drifter (10-18-2022)
Old 10-18-2022, 03:50 PM   #3556
Ok Sleeping beauty
Always make me think of this...
OFT KC learned Nah Software Tuning 3 03-17-2016 12:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 02:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 02:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-15-2014 11:37 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 08:15 PM
