Old 09-20-2022, 07:03 PM   #1
dreamwonder
Drives: GR86 2022
Is there a oil filter design change from Gen1 to Gen2?
Does anyone know if there is a oil filter design change from Gen1 to Gen2?
Reason I am asking is because Toyota is potentially denying warranty because a genuine Toyota filter made for gen1 was used on a gen2. More as it develops.
dreamwonder is offline   Reply With Quote
Old 09-20-2022, 07:19 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
They are different filters. The biggest difference is filter area. Bypass pressures are the same.
130 13-20
170 22+
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
dreamwonder (09-20-2022), Tcoat (09-28-2022), Teseo (09-24-2022)
Old 09-20-2022, 07:31 PM   #3
dragoontwo
dragoontwo's Avatar
Under warranty, it is best to use stock sized or cross referenced filter so this doesn't happen.
It probably won't hurt the engine though.
Old 09-21-2022, 01:30 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Considering that if I got a Fram filter, the same filter is used for all 2013-2020 FA20 and 2022 FA24.... design change or not, it's all the same thing if you don't use a genuine Toyota filter...
Old 09-28-2022, 11:28 AM   #5
dreamwonder
Drives: GR86 2022
Toyota denied warranty. Goodwill denied as well.
Reason:
1. Previous gen oil filter was used.
2. 0w30 oil was used.
3. Car hit 129mph at 8300rpm on 5th gear ???
Car saw 32 days with 14k total miles before engine failed. If I was at fault, I will own up to it. But wow...this is my 3rd 86 and have hundreds of days on previous 2 cars.
Old 09-28-2022, 12:14 PM   #6
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Reason:
1. Kind of on the fence on that one, but at the end of the day I guess even if it fits and sits, doesn't necessarily means is the right one.
2. Don't see how using a different weight of oil would cause an issue unless they can tell it wasn't a certified one for some reason. You could request a lab diagnosis from Blackstone.
3. They can log onto your ECU and look at your driving habits. There's probably more to it, and what it really comes down to. Toyota has already come out publicly and said that even though you may track the vehicle, they'll look at claims in a case by case basis. Though yours might not be the case, if they can see an abuse habit, they can deny any warranty claim. Even in the event that everything else checked out (Oil, filter, etc)
What were your diving habits? Best of luck.
spcmafia is offline   Reply With Quote
Old 09-28-2022, 12:25 PM   #7
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Reason:
This isn't the first time I've heard of cars in general (more so WRX/STI, EJ and FA/FBs) having engine failures under high load in high gears.
In higher gears, winding it out to 115MPH+, you're at those higher RPMs for much longer than if you were in 2nd or even 3rd gear. Given it's at high load, high RPM, long duration... heat builds up, oiling may become an issue (RTV issues, prehaps), etc.
The push back I get from a lot of owners who have failures is that the car should be capable of being at WOT, at 125MPH, in 5th gear like a race car. I think we have to understand that yes, this is a sports car, but it's not a "race car". Even for track days, it should be unlikely you're WOT in 5th really on most tracks. 4th for sure, maxing out around 105MPH. Going from 105MPH to 125MPH through all of 5th gear is a different story.
These are production street cars. They're really intended to be at max speeds of 80-85MPH. Of course they're capable of going 100MPH+, but when you're asking it to do 125MPH+ at WOT.... get what I'm saying?
You can also get into some other things like was 91 or 93 octane used. 93 giving you perhaps a bit more buffer from detonation. The quality of the fuel too. Ambient temperature, oil temperature (270+ is getting into no-no territory), etc.
Also factor in that the large majority of 2022+ do have some RTV sealing blocking the oil pickup, so in 5th at high RPMs, high load, this might have come to play if it was blocking a larger portion of the pickup.
cmiovino is offline   Reply With Quote
Old 09-28-2022, 12:32 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Most of the tracks I have driven(5) have a 5th gear 120+mph straight, one has 2,
Old 09-28-2022, 02:14 PM   #9
cmiovino
cmiovino's Avatar
I might be biased towards our local race (Pitt Race) where if you're lucky, it might grab 5th for a second. ~110mph in a first gen twin at least.
Are these 120mph in a twin? Seems like a damn long straight.
Old 09-28-2022, 02:23 PM   #10
Code Monkey
Drives: Subaru BRZ
Road Atlanta's back straight you can hit 130mph, VIR both front and back straight.
Code Monkey is offline   Reply With Quote
Old 09-28-2022, 02:23 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes, 120mph NA First Gen. Was hitting mid 120's before adding aero.
Old 09-28-2022, 02:53 PM   #12
dreamwonder
Drives: GR86 2022
Garmin is saying 127mph max at the Glen on the Gen2.
Old 09-28-2022, 02:57 PM   #13
dreamwonder
Drives: GR86 2022
I highly doubt that I would downshift first before braking at the bus stop...lol.
Old 09-28-2022, 05:33 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
The v-min of the turn leading onto the straight plays a major factor in top speed. And the turn at the end of the straight is also a factor, albeit a smaller one.
Gen1 vs gen2 - car nut - detailed differences Stonehorsw BRZ Second-Gen (2022+) — General Topics 6 09-12-2022 10:14 AM
Boosted Gen1 vs. Gen2 MotoX16 FR-S / BRZ vs.... 12 04-05-2022 12:27 PM
Question regarding what parts from Gen1 will fit Gen2 370zBRZ GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 03-21-2022 01:52 PM
Choosing coilovers gen1 vs gen2 Ogt BRZ Second-Gen (2022+) — General Topics 1 02-04-2022 01:12 PM
Engine feel Gen1 vs Gen2 comparison Dylans47 BRZ Second-Gen (2022+) — General Topics 84 01-20-2022 07:26 PM
