Old 09-25-2022, 07:17 PM   #1
an9311
Drives: 86
HKS Coilovers
Hey guys,
Just wondering if anyone here has any HKS coilovers and whats their damper setting set to?
I just installed the Hipermax S and no matter what adjustment it just feels weird. Like it understeers in some corners and on some corners the back sorter kicks out? Just seems like stock rotates a bit better...but this gives me less body roll...
On the website and manual it says 30 clicks but mine has 40?
Currently set on 25 front which is what it came in and 27 rear. (from soft to hard)
an9311 is offline   Reply With Quote
Old 09-26-2022, 12:47 PM   #2
StraightOuttaCanadaEh
Wes
Did you get an alignment done after you installed them?
Instagram: @gt86ws
Old 09-26-2022, 01:41 PM   #3
___LUNK
Drives: Laguna Seca Blue GR86
Where did you get it from that it came set at 25/30 clicks? The product page on HKS's website says the default setting is 15/30.
___LUNK is offline   Reply With Quote
Old 09-26-2022, 08:56 PM   #4
an9311
Drives: 86
Not yet im waiting on my wheels to come in and do it at once.
Old 09-26-2022, 08:57 PM   #5
an9311
Drives: 86
Got it from RHDjapan, ye it says 15/30 my rear coilovers has 40 clicks =S
Old 09-26-2022, 09:36 PM   #6
mcbat68
Drives: 2022 White BRZ manual
you can do the alignment with stock wheels. Shouldn't change much between wheels.
mcbat68 is offline   Reply With Quote
Old 09-27-2022, 09:10 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
40 clicks.
Would have returned that right away.
Old 09-27-2022, 09:39 AM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by x808drifter View Post
40 clicks.
Might be related to @humfrz, bubba could probably make 50 clicks.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Clipdat (02-15-2023), humfrz (09-27-2022), x808drifter (09-28-2022)
Old 09-27-2022, 10:13 AM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
As said previously don't bother waiting for the new wheels and the alignment will probably fix this issue. If it still doesn't feel right corner weighting might also help. But unless you're driving on tracks a bunch it probably won't matter as long as the collars are set the same left to right.
Old 09-27-2022, 10:45 PM   #10
bradsm87
Drives: It has 4 wheels
You start at fully screwed in (clockwise) and count backwards from that. Don't go past 30. It's not uncommon for it to be possible to keep going.
bradsm87 is offline   Reply With Quote
Old 09-28-2022, 08:19 AM   #11
x808drifter
LMGTFY
Unless manual says start at softest.
Not all coil overs are built the same. And with his doing 40 I'd say they may be fkd so return them ASAP instead of waiting.
Old 10-24-2022, 07:03 PM   #12
an9311
Drives: 86
Just FYI for those who ahs hks and wants to know.
Its actually says to go clockwise to the max stiffness, dial one click counter clockwise and this is now set to 0 clicks (max stiffness). Then continue counter clockwise to go softer.
The Following User Says Thank You to an9311 For This Useful Post:
x808drifter (10-25-2022)
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 11:34 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
