Old 08-01-2012, 09:01 PM   #15
Shagaliscious
Drives: Firestorm FR-S (MT)
Originally Posted by SkullWorks View Post
how about anodized sill then machine the engraving afterwards? give some contrast and reduce the glare, this would also allow color options.
Another idea is a bead blasted surface with the engraving afterwards to provide contrast.
last idea, apply lacquer stick in the engraving to make it stand out
and FWIW I liked the driver/ navigator but would prefer a Pilot/ Co-Pilot nomenclature.
Anodizing can get expensive. But, I agree it would look good. I do like the brushed aluminum though.
Bead blasted, I would like to see that. I like bead blasted stainless steel, i'm sure this would look just as good.
The etching needs to stand our more, definitely. Maybe make the "driver/navigator" the personalized portion of the door sills. Allow people to request what they want (if that's not too much trouble).
Out of curiosity, what type of laser are you using?
Old 08-01-2012, 10:25 PM   #16
yospeed
yospeed's Avatar
Drives: Coming Soon
It's looking like driver/navigator and pilot/co-pilot will be options, but not standard. Once they're available, you'll be able to completely customize the engraving if you don't like the standard pattern. I'm just trying to gauge what the "standard" should be for now, though.
I'm using carbide endmills to engrave. As much as I'd love a laser, they're outrageously expensive and high maintenance.
I prefer anodizing actually, but you're correct about it being pricey, and every additional color option multiplies that high cost. Powder coating will provide a solution for people who prefer a textured finish, and if enough people want I might try to do a small batch of gunmetal grey anodized sets. The anodized sets would probably be priced a bit higher though.
I appreciate the feedback!
yospeed is offline   Reply With Quote
Old 08-02-2012, 06:12 AM   #17
Shagaliscious
Damn, that looks great for being milled! No doubt on lasers being expensive, the one we just got at work was well over $100k.
Powder coating is a great idea. My shift knob is powder coated and I think it looks great.
Old 08-02-2012, 12:50 PM   #18
SkullWorks
Drives: SSM LT MT BRZ
be careful with the powder coating as it softens all the edges and adds thickness in a less controlled manner, so if clearance to door is minimal you may need to decrease the thickness of the part.
anodize isn't too bad really, where are you located I can introduce you to some shops that do great work and if you know how to order the anodize it gets cheaper (i run an aerospace machine shop in carson ca that has been in business for 60 years...we know everyone)
Old 08-02-2012, 01:28 PM   #19
yospeed
yospeed's Avatar
Drives: Coming Soon
Impressive! Powder coat is a great solution for surface treatments, especially since it doesn't fade like anodize will when exposed to sunlight.
No worries there. I switched to ISO certified powder coaters a few years back and haven't looked back since. It's more expensive but the tolerances are much tighter and the variance in thickness is minimal. If door clearance ever does become an issue, for anyone who purchases a set I'll gladly refund them, but I've never run into that issue in the past.
I'm located in Anaheim. I use Ideal Anodizing at the moment, but I'm always willing to give new vendors a try. They've provided excellent service in the past, but their color choice is a bit limited.
Old 08-02-2012, 01:31 PM   #20
SkullWorks
good to know.
If you think you need anything drop me a line, I also have lots of spindle time available in house .
Old 08-02-2012, 01:42 PM   #21
subzero05
Drives: Fr-s
it has good possibility
subzero05 is offline   Reply With Quote
Old 08-02-2012, 03:29 PM   #22
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I would definitely buy it if it had the 86 piston logo. Also, and personalized engraving would be a plus!
Bg8780 is offline   Reply With Quote
Old 08-02-2012, 04:18 PM   #23
Shagaliscious
Plus it dissipates heat quicker then an anodized shift knob. Not sure that would benefit the door sills, but having more then 1 color will help you sell a lot more.
Old 09-14-2012, 06:17 PM   #24
yospeed
yospeed's Avatar
Drives: Coming Soon
Updated the first post with some new photos of the black door sills. Much better contrast than the original silver sills IMO!
The Following 4 Users Say Thank You to yospeed For This Useful Post:
Dadhawk (09-14-2012), kwood9000 (09-14-2012), Slartibartfast (09-15-2012), StarsGarrador (09-16-2012)
Old 09-14-2012, 06:22 PM   #25
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
The black powdercoated ones look sick, I want a set. I didn't see this in the first post, but how do they attach? I don't know how the OEM ones are attached, 3M tape?
The Following User Says Thank You to RedLeader For This Useful Post:
Old 09-14-2012, 07:20 PM   #26
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
The black option look's great. I would def consider buying a pair.
Luke.Cariveau is offline   Reply With Quote
The Following User Says Thank You to Luke.Cariveau For This Useful Post:
Old 09-14-2012, 07:30 PM   #27
yospeed
yospeed's Avatar
Drives: Coming Soon
They'll more than likely attach via 3M automotive adhesive, that way they're easy to remove. I like giving people the option of going back to stock should they ever want to sell their car.
Old 09-14-2012, 10:19 PM   #28
I didn't care for the chrome, but I really like those black ones. Definitely going to watch these particularly if we can customize them.
brz door sill garnish, fr-s door sill garnish, yospeed
Custom Door Sills danthedirt Cosmetic Modification (Interior/Exterior/Lighting) 13 07-23-2012 07:54 PM
Door Assembly Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-22-2012 12:58 PM
out the door pricing wallace03 BRZ First-Gen (2012+) — General Topics 6 06-12-2012 01:30 PM
Four Door 86 sedan? tlp Scion FR-S / Toyota 86 GT86 General Forum 11 03-31-2012 03:07 PM
