#57 |
Drives: 13 BRZ Limited WRB
I have ordered some things now - and from a friend of mine who has this currently installed
Oil Temp sensor in top galley with a galley plug - seems to fit just fine ![]() Pressure sensor with an extended line in stock location (Sounds like no negative effects) ![]() Again - I'm not saying that I know for a fact that this works, but I will find out real quick.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#58 | |
Drives: Blue BRZ
#59 |
Yea, Photobucket took a shit on everyone and disabled 3rd party hosting on all accounts unless you pay - get this - $40 a month. Fuuuuuuuuuuck No.
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | BRZ RN (08-02-2017) |
#60 |
Drives: 2016 BRZ Premium
Photobucket is sucking a lot!
I have my oil temp gauge in an oil filter sandwich plate. It's going to be very near the pan temp as it's pumped straight from there and doesn't go through a cooler. I've used this method on 3-4 different vehicles. |
#61 |
billswebspace.com
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
I tried a few different things but ended up using a sandwich plate re-tapped for the senders for my gauge, after some months I think this is the best solution. Some pics here: www.billswebspace.com/FRSRS2.html
Bill
BillsWebSpace.com |
#62 |
Rust bucket enthusiast
Sorry to bump an old thread, but I wanted to add my info here as well. As Bill did, I used a TRD sandwich plate for the Defi pressure gauge and used a remote sender. Extremely easy, clean install.
I would recommend for anyone already using the gallery port as a turbo oil feed. Just make sure to use teflon tape on the fittings being threaded into the ports on the adapter plate Adding photos for future generations to see. Remote sender comes from sandwich plate and goes under the intake manifold. I attached the pressure sensor to a tab on the back of the intake manifold, and have the wiring routed back to the driver's side, behind the brake booster, through the grommet in the firewall to the driver's side footwell.
#63 |
Shameless plug here, but we carry a bunch of sender adapters for pressure and temp. The nice thing about using an adapter is that is adds the minimal amount of additional potential leak points vs remote or sandwich adapters.
Just a pic for reference, we make these in other sizes too... |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Ultramaroon (09-22-2022) |
#64 |
#65 | |
Drives: '13 Whiteout
#66 | |
You can view/log oil temp through any obd2 device that can read PIDs, but no pressure. I imagine bluetooth isn't really reliable enough yet to be piped through the firewall and be stable enough for popular companies to jump on board with it
| The Following User Says Thank You to DarkPira7e For This Useful Post: | TommyW (09-22-2022) |
#67 |
yes Harry’s lap timer you can. It’s just a drag that you can’t see it unless you go out of the timer and into the Real-time Analysis mode.
#68 | |
Drives: 2020 BRZ
I didn't see it on your website, but any chance you make/have: 1/8 PT Male to 1/8 NPT Female (for water temp sensor for an aftermarket filler neck); I am not sure what the thread for the stock oil pressure port is (where the dummy switch is), but whatever that is Male to M10x1 Female. If you have the above adapters (in stainless) please let me know, will buy tomorrow! |
#69 | |
![]() The OEM port is 1/8PT M10 x 1.0 is a very odd sensor thread. What brand? |
#70 | |
Drives: 2020 BRZ
Oil temp is 1/8 NPT, I bought the M18x1.5 adapter from you. Water neck (Greddy) is 1/8 PT, the Stack sensor is 1/8 NPT. Oil Pressure sensor is M10x1. From STACK website: ST3501 - Oil Pressure 0-7 bar (M10x1) ST3509 - Oil Temperature 40-140°C (1/8NPT) ST3507 - Water Temperature 40-120°C (1/8NPT) I think my only option is to contact a machine shop if I want them in stainless. |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 04:29 PM |
| Aftermarket gauge placement | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-18-2012 01:01 AM |
| Self-diagnostic busses? Specifically oil pressure? | Nezz | Electronics | Audio | NAV | Infotainment | 6 | 08-13-2012 08:34 AM |
| phantom tire pressure warning | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 06-04-2012 09:04 AM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) — General Topics | 17 | 12-12-2011 11:39 AM |
