Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2022 GR86 Premium, Red, Auto Trans
OEM Brake Pads
How good are the OEM brake pads on a GR86? Are they suitable for events such as time trials and TNiA? I've used them for AutoX, but that's only a minute or so on the track and they seemed to work fine for that. For time trials and TNiA should I switch to a pad such as DS2500 or Endless MX72Plus?
#2 |
Drives: '13 Whiteout
Need better pads and fluid for the track
The Following 5 Users Say Thank You to TommyW For This Useful Post: | CSG Mike (09-27-2022), finch1750 (09-20-2022), gcmak (09-15-2022), Racecomp Engineering (09-07-2022), x808drifter (09-07-2022) |
#3 |
Drives: GR86
The NASA event I went to, they held up surprisingly well. But, the organizers said they had a few extra pads for people just in case. Our track only had two heavy brake points though
#4 | |
Drives: '23 BRZ
I don't have experience with the Ferodo or Endless pads. If you will be doing a fair amount of track usage you should consider CSG pads. I'm running Spec C2 and they are by far the best pads overall for my usage (track, time trials, plus a fair amount of street useage between events). They are a bit pricey but they are lasting me a frankly unbelievably long time, like 18 track days! I do have the big Brembo brakes but still I have to think even dinky-braked FT86s should get quite long life out of them. For fluid I've never had any issues with off-the-shelf parts store DOT4 so IMO you don't need to do anything fancy there. |
#5 | |
OEM Brake Pads
My Endless MX72Plus pads arrived from Japan and I've installed them. Will see how they work at TNiA on Sep 22 at Thompson. |
#6 |
Drives: 2012 BRZ Premium WRB 6MT
OEM pads are not designed for track use. Please see our article about all the reasons why on the Essex Blog: Can I Run my OEM Brake Pads on the Track?
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
#7 |
Drives: '13 FRS - STX
No. I boiled my fluid and glazed my pads at my second ever track day, it probably would have happened on my first if it wasn’t wet most of the day at a track I had never seen before. If you take it super easy you might be fine for a TNIA but if you want to be quick for a TT they won’t last a lap.
Ds2500 are good autox/street pads but I’d only track them if I had no other choice. Might be fine for a newb and they’ll survive, you won’t die but be aware they’re not bulletproof. Last edited by strat61caster; 09-27-2022 at 03:57 PM. |
#8 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
You will outgrow non-track compounds very fast. I ran Project Mu HC+800 daily and for my first TNIA they were ok. My second event I melted them. Just invest in proper track pads from the get go to be safe. |
The Following User Says Thank You to finch1750 For This Useful Post: | CSG Mike (09-27-2022) |
#9 |
Drives: Gr86
I could get 3 laps out of the stock pads before they completely faded. Would not recommend tracking them at all.
#10 |
Drives: 2022 GR86 Premium Track bRed
I feel like the gr86 pads get brake fade on the street tbh. one hard stop and they smell horrible.
I recommend swapping to a better pad like raybestos st-43 for track days, then swap back to street pads otherwise. AP racing has some good videos on bedding/cleaning rotors. |
#11 | |
Check out the reviews of CSG pads on this forum, and check out: https://www.counterspacegarage.com/csg-spec-brake-pads |
DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 05:27 PM |
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff | IBill4You | Want-To-Buy Requests | 2 | 06-13-2015 03:02 PM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
