Old 08-01-2012, 06:01 PM   #15
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Only the best. Motul.
We have been recommending and using this in a couple local BR-Z's. We stock it so if anyone needs it come by or you can call and order it.
No Limit Motorsport is offline   Reply With Quote
Old 08-01-2012, 06:09 PM   #16
HKS Australia
Australia HKS Distributor
HKS Australia's Avatar
Drives: Fast One
Originally Posted by Draco-REX View Post
I just noticed they got the direction of the oil flow wrong. The center hole is the EXIT not the intake of the filter. Oil flows through the outer ring of holes to the outside of the media then out through the center.
I can see how you have read this but they meant Intake into the engine.
Cheers
HKS Australia
HKS Australia is offline   Reply With Quote
Old 08-01-2012, 06:31 PM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Cheers
HKS Australia
Ahh. That makes more sense.
Old 08-01-2012, 10:57 PM   #18
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
My vote would go to Amsoil 0W-30 or 5W-30 synthetic.
Entropy is offline   Reply With Quote
Old 08-02-2012, 12:39 AM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I picked up a case of 12 qts of 0w-20 amsoil for $45.
I thought that was a good deal.
Old 08-02-2012, 01:50 AM   #20
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Running 0w-20 Redline at the moment. Have about 1000 miles under it so far. Car seems fine. Will get a UOA in a few more thousand miles.
FrX is offline   Reply With Quote
Old 08-02-2012, 02:22 AM   #21
Hanakuso
Originally Posted by Opie View Post
Idemitsu....
Is this the same oil Toyota/Scion uses?
Hanakuso is offline   Reply With Quote
Old 08-02-2012, 03:08 AM   #22
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
0w-40 Mobil 1 with k&n filter for summer since i track it in 100+ temps
In winter i prob will be running 0w-30
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-02-2012, 03:17 AM   #23
coyote
coyote's Avatar
Drives: Slowly
I'd be paying more than that .... just for the postage.
coyote is offline   Reply With Quote
Old 08-02-2012, 08:58 AM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
that is an amazing deal
Old 08-02-2012, 09:09 AM   #25
rice_classic
Well, I did pay another $18 in "entry fee" to get into the GoodGuys Car show at the fair grounds (wrote it off as work expense) but yeah, I bumped into an Amsoil distributor who had a sign that said "OE 0w-20" $3.99/qt.
My line of questioning was:
1: Why is it only $3.99/qt? (That's his "show" pricing for events)
2: How many quarts do you have? (He had a case which he sold to me for $44.95)
edit: I would have bought 3 cases if he had that much.
Old 08-02-2012, 11:43 AM   #26
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I'd like to use Amsoil Signature as well, but its bloody hard to find any locally. Where does everybody buy theirs?
Might default to Pennzoil Platinum or get Redline.
F1point4 is offline   Reply With Quote
Old 08-02-2012, 12:19 PM   #27
UncleFester
Online. You won't find legitimate Amsoil signature for less than $10 a quart.
UncleFester is offline   Reply With Quote
Old 08-02-2012, 02:41 PM   #28
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I buy Amsoil 0W-20 Signature straight from Amsoil, and make sure that I plan ahead to have some on hand. I have never seen any local store to carry any in stock. You may contact Amsoil to see if there is an independent dealer in your area, but you will likely still have to order it then from them and wait for the shipment.
I am an Amsoil Preferred Customer and I just bought a case of 12 quarts of Amsoil 0W-20 Signature for $7.74 per quart direct from them, the total was $8.35 per quart with shipping. You can find out about the Amsoil Preferred Customer program on their website. If you order several cases a year or a combination of other products, it saves you money.
Originally Posted by empower-auto View Post
This has only been scraped at over a few threads - I think we need a good resource.
What's out there for good 0W20 oil and how will the car react to different weight oils such as Castrol 0W30 or other oils in 5W20/5W30?
I may switch to Amsoil 0W-30 Signature for summer track days on a long track. 5W-anything should not be used as the thicker base weight will cause more wear at startup, where much of the wear occurs in a modern engine. The 5W oil is just too thick when cold, especially since our engines were designed to use 0W oils to avoid this problem. The 0W indicates that the oil is thinner at startup where this is needed. The second number is the weight of the oil when warm, so 30 weight makes sense for hard driven track cars in hot weather. The owners manual suggests that a thicker weight may be desirable for this use, but I am sure they are referring to the second weight number.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
U.K. People Pants EUROPE 345 04-01-2016 03:59 AM
People are mad now! Tsinoy Scion FR-S / Toyota 86 GT86 General Forum 1 11-30-2011 11:55 PM
I need some help here and I really think there are people on here that can. Spencer Strayer Engine, Exhaust, Transmission 35 11-02-2011 12:01 PM
Need some more people! bofa Off-Topic Lounge [WARNING: NO POLITICS] 4 08-13-2011 10:16 PM
How many people will fit in FT-86? Dark Scion FR-S / Toyota 86 GT86 General Forum 52 09-07-2010 07:49 PM
