#29 | |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Nice commentary, keep up the good work. And yeah, don't swap out your subframe. I'll take the bonk on that advice considering parts move labor costs.
| The Following User Says Thank You to jeepmor For This Useful Post: | norcalpb (09-01-2022) |
#30 |
Pissin off regressives
Drives: They have engines.
@7:42 They start talking about the differences in the brackets. |
| The Following User Says Thank You to endless_pain For This Useful Post: | norcalpb (09-01-2022) |
#31 | |
Drives: Toyota 86
GR86 brackets which welded at the subframe move freely within the play allowed by the subframe bushes, but the BRZ bracket is secured with the chassis. When the LCA of GR86 moves up, the bracket also moves slightly and the position difference between the LCA and the sway bar reduced. When the LCA of BRZ moved up, the bracket position is not changed so the sway bar can do its role fully. You can find the old subframe movement with its sway bar bracket in the below video.
| The Following User Says Thank You to makinen For This Useful Post: | norcalpb (09-18-2022) |
#32 |
Small update:
Rear sway bar had much more preload than I had originally thought. In the first picture it’s clear why things wouldn’t line up nicely with the stock endlinks. I bought whiteline KLC182 with the intention of stacking both spacers on the same side of the link. Turns out even this wasn’t enough but still fits much better than before. The 2022 brz rear sway bar has a different part number than the 13-21 cars while still being 14mm like the 13-16 cars. I wonder if there is a slight bar shape change at play here but I am doubting it. I also installed a new mount for my rear diffuser as the original Verus bracket wasn’t fitting well after this whole modification. Plus it’s nice to have that sway bar bushing sitting flush with its bracket for the first time in 6 years. ![]() ![]() Old diffuser mount: ![]() New diffuser mount:
| The Following 3 Users Say Thank You to norcalpb For This Useful Post: |
#33 |
Drives: None
Are these the Professional Awesome splitter support rod parts or did you stumble upon a place to get them somewhere else?
#34 | |
I find this setup kinda busy so I'm talking with some companies about ordering some new shortened splitter rods. Most likely will end up with FS Performance rods. The needed total height is 6" from clevis to clevis. |
| The Following 2 Users Say Thank You to norcalpb For This Useful Post: | NoHaveMSG (09-18-2022), RedReplicant (09-18-2022) |
#35 | |
Drives: Crapcan
Question on removing rear sway bar brackets
Cool setup. I was looking at doing something similar. I imagine you need at least one mounting point to locate the diffuser and keep it from moving on the clevis.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | norcalpb (09-18-2022) |
| Rear sway reinforcement brackets necessary? | dutchman1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-07-2018 10:23 AM |
| rear sway bar question | kravi | Tracking / Autocross / HPDE / Drifting | 11 | 11-28-2016 07:38 AM |
| WRX rear sway bar: good front sway bar combo? | LerpK | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2016 06:02 PM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
| Sway Bar Mouting Brackets/Bolts Integrity | sw20kosh | Tracking / Autocross / HPDE / Drifting | 3 | 01-16-2013 06:36 PM |
