Old 09-08-2022, 10:57 PM   #1
rm4g3d0n
Drives: BRZ 14
KW V3 + Raceseng Camber Plates
Hi, I bought KW V3s and Raceseng Camber Plates. When I bought the plates I had to look at a chart so that I'd choose the correct perch spring (60mm) and bushing (15mm) sizing that would be compatible for the KW V3s.
When installing the plates onto the strut, I notice that the shock nut doesn't seem to thread all the way. Even when removing the upper spring to see if the nut will completely thread in, it still doesn't. It this normal?
I was looking at this thread, and noticed int he last photo of OPs post, you can see the threading of the strut. I can't even see that on mine, rather I see the threading on the nut.
I don't know if this is normal, or if Raceseng sent an incorrect sized piece? Or of KW had updated the sizing of the strut?
Thanks.
rm4g3d0n is offline   Reply With Quote
Old 09-09-2022, 12:26 AM   #2
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Maybe they changed the shock nut design over the years (I bought my Raceseng plates back in 2016), but yours definitely don't look like mine, so they may indeed the the incorrect part. Yours has a much smaller inner diameter than mine (also KW V3 before I upgraded to RCE T2, which are the same thing in that regard.) Based on your photo, I'm going to assume that the nut is bottoming out on the threaded portion of the shaft, which isn't allowing you to fully tighten it...? I'd reach out to Raceseng for clarification.
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 09-11-2022, 09:46 AM   #3
rm4g3d0n
Drives: BRZ 14
Was able to email a rep, and said it was normal.
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
RaceSeng camber plates Code Monkey Brakes, Suspension, Chassis 5 03-22-2018 09:50 AM
FS: Raceseng Caster/Camber Plates Deraj Brakes, Suspension, Chassis 3 06-28-2017 12:52 PM
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 10:28 PM
FS: Raceseng Cascam Camber Plates bombardius Brakes, Suspension, Chassis 0 04-12-2016 06:55 PM
