Old 07-27-2012, 11:03 PM   #43
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
Anytime,your welcome. As we specialize in Canadian customers we can supply faster and cheaper then our American friends. We stock all FRS and BRZ products, we don't drop ship.... It's in stock.
Stav is offline   Reply With Quote
Old 07-27-2012, 11:06 PM   #44
fatoni
Originally Posted by EvoFanatic View Post
False, you can never have too much camber. Wheels must be at -90 camper at all times!
calm down its not a delorean
The Following User Says Thank You to fatoni For This Useful Post:
MObrz5 (08-16-2014)
Old 07-31-2012, 12:19 PM   #45
EvoFanatic
Drives: Evo X
Of course not, it wasn't designed by Doc lol.
EvoFanatic is offline   Reply With Quote
Old 08-02-2012, 01:16 AM   #46
Paragon
Guest
Posts: n/a
Originally Posted by FT-86 SpeedFactory View Post
Rear Camber kit...http://ft86speedfactory.com/index.ph...roducts_id=215
Will pull +/- .75 camber. Bring you back to a -1.25 give or take a bit which is much more manageable. You could always raise it up a bit as well. Looks a bit too low. Holler with any questions.
The whiteline camber kit seems to be some bushings but the Cusco solution is an adjustable arm? Whats the diff?
Old 08-02-2012, 08:21 AM   #47
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You nailed it on the head. Whiteline is just bushings. The Cusco is an entire replacement arm that is adjustable and has more adjustment in the range.
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-02-2012, 10:04 AM   #48
Paragon
Guest
Posts: n/a
Which is the better was to do it though?
Old 08-02-2012, 11:39 AM   #49
white86
Drives: Whiteout FRS
judging from the fact that mine was lowered 2.6 inches and has 2.7 degrees camber, if you went with the whiteline you would have AT LEAST 2 degrees camber left, so unless that was your goal I would go with the cusco arms or wait till a <500$ solution rises to lower your car.
white86 is offline   Reply With Quote
The Following User Says Thank You to white86 For This Useful Post:
Keith@AIRAID (08-31-2012)
Old 08-02-2012, 12:05 PM   #50
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Genuinely curious how it handles at that ride height and with that camber. Nobody has really mentioned it yet so it'd be interesting to hear.
In your place I'd go with the Cusco arms since you'd be pretty guaranteed to have all of the adjustment range you'll need.
Some Whiteline camber bolts for the font too perhaps, so you can get it juuuust right.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-02-2012, 12:52 PM   #51
FT-86 SpeedFactory
Depends on how low you are. The Arms will allow greater adjustment to sort out camber issues with extreme low settings on coilovers. The bushings will probably work out well for those only an inch or so lowered to get some extra camber for race applications. Then again it all depends on the use.
How low are you? How long do you want tires to last? etc...
Old 08-28-2012, 05:17 PM   #52
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Originally Posted by Stav View Post
Hi project.sth,
Yes the rear has no factory camber, it is the same as a GRB WRX/STi rear suspension so much so that the Cusco part number is exactlly the same part to fit the GRB/FRS/BRZ to correct your camber issue.
It will easily correct the -2.5 degrees of camber and give you a nicer piece and looks much better especially from the rear.
very helpful. can we assume that all/most rear control arms made for the 08+ STi can be used on the FRS/BRZ ? For people not willing to dish out the high price tag for the cusco arms, Although I havent found too many options for the STi .
SLICVIC is offline   Reply With Quote
Old 08-28-2012, 05:47 PM   #53
Synack
Boosted
Synack's Avatar
Drives: Sideways
Hmmmm, my rear camber is expected to be at about -2.0 to -2.25 after I drop it. Cheapest way to bring it back to -1.25?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-29-2012, 10:06 PM   #54
Stav
Stav's Avatar
You can also use the sti rear upper bushing from Whiteline, they are also installed and will correct 1.5 degree of camber in the rear. Not a full lower control like the Cusco piece, but definetly cheaper.
Old 08-30-2012, 12:43 AM   #55
Synack
Boosted
Synack's Avatar
Drives: Sideways
This piece alone corrects up to 1.5 degrees??
Link please?
Sent from my Nexus 7
Old 08-30-2012, 01:47 AM   #56
melon
melon's Avatar
Drives: Toyota 86
Originally Posted by project.sth View Post
So this weekend I've installed my BC Coilovers. The only complain I have is I've got a lot of unwanted negative camber. I've lowered my car app. 2.5"
Since we can't ajust the rear camber OEM on our car I want to know if with the same or other suspension setup you got the same problem. Pictures are welcome.
So my wheels are 17X8 +38 on OEM tire.
The option could be the Cusco rear control arm but theirs is no spec of how much degre we can correct camber... I just don't want to spend 500$ and still have the same problem.
Same idea on how big the wheels I want and how LOW I want my car to look like. Hope it has a comfort like the stock or atleast close to the stock... Is it?
I'll be waiting for the reply regarding how the cusco arm will fix the camber...
melon is offline   Reply With Quote
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
